diy 2 dof seatmover, diy hshifter and handbrake
Discussion in 'DIY Motion Simulator Projects' started by mimi67, Nov 11, 2019.
  1. mimi67
    mimi67 New Member Gold Contributor
    france
    176Coins
    Hello
    I present you my rig with diy seat mover and diy handbrake and diy H and squential shifter...
    • Like Like x 5
    • Winner Winner x 4
  2. Sebj
    Sebj Active Member
    Canada
    492Coins
    Nice work, passion shows
  3. mimi67
    france
    176Coins
    thank you
    I also worked on a second gearbox pototype, and on an analog handbrake.
  4. Sebj
    Sebj Active Member
    Canada
    492Coins
    Yikes. That's a monster shifter
  5. mimi67
    france
    176Coins
    yes he is a little big...:)
  6. Sebj
    Sebj Active Member
    Canada
    492Coins
    Roughly how much did it cost you to build each
    They look great
  7. mimi67
    france
    176Coins
    Not very expensive, the laser cutting and machining are made at my job in falls, the only things I bought are the switches, the knob and the card leo bodnar, about 60 euros in all.
  8. dieser
    dieser Member
    372Coins
    hey mimi,
    i really like your build.
    especialy the creative way to build the u-joint for the seat.
    are the blue parts in the controlbox 3d-printed or metal?
    (motorarm)
    is it a crank style like simukit uses?
    can you please provide details on this.
    I´m looking for a solution here for my own build.
    thank you!
    again, great work! :)
  9. mimi67
    france
    176Coins
    hello
    The parts in blue are all in metal (laser cutting).
    I designed the cranks myself, but they are inspired by those of simukit.
    I still have the plans if you want...
  10. dieser
    dieser Member
    372Coins
    hey mimi,
    yeah, that would be great! :)
    finding a right motorarm is harder as i thought it would be...
  11. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    That some slick looking work. Curious if you have the schematics for the DIY H shifter?
  12. mimi67
    france
    176Coins
    I have made the plans of the first H shifter, with the curved lever, if you want...
  13. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    That would be great. Always looking for a new project.
  14. dieser
    dieser Member
    372Coins
    hey, it‘s me again ;)
    i found your simulator in a video by randomly browsing youtube searching for 2dof seatmover.
    it‘s great! you should really link it in your startingpost
    i‘m impressed how smooth and direct the movement is.
    would you mind to share your simtools settings here?
    are you using the 120w or the 400w motors from simukit?
    thank you for building this.
    it‘s such an inspiration! :)
  15. mimi67
    france
    176Coins
    hello
    I use the 120 w motors, they are sufficient for a seatmover, they don't heat.
    My settings (for Assetto Corsa) in Game Engine are : surge 45%(with 10% smoothing), sway 35%, heave 20%, roll 15%, pitch 15%
    in tunnig center: roll 15/-15, pitch 15/-15, heave 1/-1, sway 1/-1, surge 1/-1
    I have a potentiometer which adjusts the effects in game from 0 to 200%.
  16. dieser
    dieser Member
    372Coins
    hey!
    thanks for sharing your settings! :)
    are you using smc3 code for arduino?
    i‘m thinking about switching to your design...
  17. mimi67
    france
    176Coins
    hey
    the code i use is made by Wanegain on PCSHM Forum...
    good luck for the design, and if you have a question, maybe i can help.
  18. dieser
    dieser Member
    372Coins
    hey!
    i followed your idea here and rebuild my sim setup these days.
    we talking about stealth materials in my thread.
    can i ask you what you used and what your experience with it?
    seat platform is steel, right?!
    how thick is it?
    and the ground platform?
    steel or wood?
    thanks for helping me again ;)
  19. mimi67
    france
    176Coins
    Hello
    the seat platform is made of 5 mm steel then above a 16 mm wooden panel (to reduce the vibrations of the buttkicker) and another 3 mm steel plate, the bottom platform and the sides are made of wood. everything has been working fine for several years, nothing has broken, just check that everything is tight, once a year (I put tread lock).
    For the construction, I followed a tutorial from Momoclic on the pcshm site (thank's to him), it is necessary to not implement everything any way to have the best feeling possible, but it is complicated to explain, the best is to watch the tutorial ...:)
    good luck;)
  20. dieser
    dieser Member
    372Coins
    hey buddy!
    i‘m in movement settings right now.
    if i get it right, you have an additionally potentiometer to tweak the ingame settings in acc?
    how did you do that?
