Question shaking, waggle, vibration
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by peel, Nov 16, 2019.
  1. peel
    peel New Member
    mechanic of printing machines
    Martin Slowakei
    143Coins
    3DOF, Arduino
    Hi, I've been looking for a long time to remove the shaking, but I didn't find anything.
    Therefore, please help. How to remove it, or at least eliminate it to an acceptable level.
    I use a stepper motor and a 10-speed potentiometer.
    Thanks for help.
  2. Thanos
    Electronics Engineer
    2,908Coins
    Maybe not use steppers? Looks like step is too big on the video... It will confuse any PID algorithm like that.
    Maybe you could attach the potentiometer on the output of the gearbox, where there is smaller stepping?
  3. peel
    peel New Member
    Martin Slowakei
    143Coins
    3DOF, Arduino
    First I had such a solution, but it was not good.
    I have 10-turn potentiometer connected to the output of the gearbox, so I used almost the entire range of the potentiometer.
    Thank you, Thanos, you brought me to this idea.
  4. Ben Xie
    Ben Xie New Member
    70Coins
    Arduino, 6DOF
    Can steppers do quarter/smaller steps to increase the resolution? I'm pretty new to this so I'm not too sure.
  5. peel
    peel New Member
    Martin Slowakei
    143Coins
    3DOF, Arduino
    I connected the potentiometer with a simple three-wire cable and the values fluctuated greatly. Then I used a shielded cable and jumped values to an acceptable degree.
    I need to adjust the ratio between the rotor and the potentiometer so that the step size is an integer on the potentiometer (now it is 3.2 and I need 4.0).
    Waiting for this gear: https://www.aliexpress.com/item/32888549055.html?spm=a2g0s.9042311.0.0.63014c4dsCozKZ
    And I still have to fine-tune the programming code, so far I have errors.
    And I hope it will be ok then.
    The engine takes 1 / 16th of a turn. I know it's not ideal, but I still want to try it with the engine
