VR rollercoaster to flight sim comversion
Discussion in 'Commercial Simulators and Peripherie' started by Al T, Nov 5, 2019.
  1. Al T
    Al T New Member Gold Contributor
    163Coins
    Motion platform
    2C21D7A3-E278-410F-8E3F-57EE2A5BE355.jpeg 7E7D877B-5F76-4A49-8856-ED5DF7BF0E1D.jpeg 7E7D877B-5F76-4A49-8856-ED5DF7BF0E1D.jpeg F1A99F33-0F3E-4DB4-B952-C8D4DAB97F0A.jpeg 64A8F64F-5CD2-4FAB-A352-4E973A173612.jpeg Hello! I have a VR rollercoaster which I want to modify for flight simulator. My main challenge is to find a way to connect a joystick to the system (for example Thrustamaster T Flight Hotas4).
    525EAF99-53F1-4F22-88D7-04EB8E66E419.jpeg D1D669C1-EEDE-47DE-9088-4B836E028A01.jpeg
  2. Al T
    163Coins
    Motion platform
    No. 1 (capsule 1) computer calls the value in the MBD database, sends a command to the control card through Rj45, and then the control card sends a command to the servo drive. Then the servo drive controls the motor.
  3. Al T
    163Coins
    Motion platform
    Hello! My name is Al, and I’m a newby to IT & electronics. I have a VR rollercoaster which I want to turn into VR flight simulator. My major challenge now is connect joystick to the rig. Just to make the rig move in accordance with joystick movement. Where to start? 7C9AAB26-1E5C-4A87-BD38-848E4BA13781.jpeg 817DECE4-208A-47E6-B940-8BB1C0E14D41.jpeg A57E31F0-926F-4C85-BA57-BA7F85EB1C58.jpeg 95088A38-756D-4040-8C36-43EA9F093C8B.jpeg 6D584BA6-6EB5-40D2-92A3-6EF4AF4C95FC.jpeg 5EF03CD0-B7E9-49FD-A7BF-FFBD9CBD864F.jpeg
    153,065Coins
    +11,117 / 56 / -2
  5. Thanos
    Electronics Engineer
    2,907Coins
    Are you looking for a way to interface this to Simtools?
  6. Thanos
    2,907Coins
    Oh, I see.
    I have tested my AMC-AASD15A servo controller with Dorna M1, but haven't tested it yet for compatibility with Dorna EPS-B1, although the parameters should be the same:
    https://github.com/tronicgr/AMC-AASD15A-Firmware/tree/master/DornaM1_interface
    The AMC-AASD15A controller will replace the Vegafu RS485 interface, by connecting to each servo drive directly on their 44pin connector.
    Can you take a photo of the 44pin connector on the Dorna EPS-B1 drives you have??
    Thanos
  7. Al T
    163Coins
    Motion platform
    Yes Sir. I wanted to understand if I buy SimTools, can I make rig to move in accordance with joystick movement for flight simulator? Thank you!
  8. Al T
    163Coins
    Motion platform
  9. Al T
    163Coins
    Motion platform
    Hello Thanos, I’ll go there today to make photo. Thank you!
  10. Al T
    163Coins
    Motion platform
    please see below a picture
  11. Thanos
    2,907Coins
    Gosh, its not the simple 44pin connectors. Do you happen to have manual for this Dorna servo drive that to see what the pins assignments should be?
  12. Al T
    163Coins
    Motion platform
  13. Thanos
    2,907Coins
    Ok, got it. I'll compare the pin assignments and let you know.
    Thanos
  14. Al T
    163Coins
    Motion platform
    There are 3 Dorna here:
    EPS-B2-0003AA-A300 (roll movement)
    EPS-B2-04D5AA-A300 (tilt movement)
    EPS-B2-0001AA-A300 (pan movement)
    they are connected consequently after SMC x_24.
    Each previous dorna is connected to the following via Port 1 cn 1 (RJ45). Output cable (Rj45) from Port 2 (cn 1) goes to next Dorna’s port 1 (Rj45)
  15. Al T
    163Coins
    Motion platform
    Thank you Thanos!
  16. Al T
    163Coins
    Motion platform
    Thanos, meanwhile we are brainstorming on advances joystick connection, what do you think. If we could use simple joystick like this (picture below). How I could connect it to make an experiment?
  17. Al T
    163Coins
    Motion platform
    Example of the file which makes VR Rollercoaster move. Ups, website does not allow .mdb (Microsoft Access Database) upload.
    Is it possible to emulate Joystick commands
  18. noorbeast
    153,065Coins
    +11,117 / 56 / -2
    Simtools has record and playback capability:
    https://www.xsimulator.net/community/marketplace/simtools-v2-video-ride-recorder.203/
    https://www.xsimulator.net/community/marketplace/simtools-v2-video-ride-player.175/
    https://www.xsimulator.net/community/marketplace/simtools-v2-video-ride-creator.180/
    And a universal joystick plugin: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
    Plus a dedicated plugin for NL2: https://www.xsimulator.net/community/marketplace/nolimits-rollercoaster-simulation-plugin.31/
  19. Al T
    163Coins
    Motion platform
  20. Thanos
    2,907Coins
    Ok, finished with the pins assingment for the 50pin connector on the EPS-B1 servo drive. See schematic:
    Thanos
