Request (Feature) Game Plugin Requests
Discussion in 'SimTools Plugins' started by value1, Sep 21, 2014.
  1. Need for Speed series
    57 vote(s)
    21.0%
  2. GTA
    31 vote(s)
    11.4%
  3. Burnout Paradise
    16 vote(s)
    5.9%
  4. Grand Prix Legends
    20 vote(s)
    7.4%
  5. Nascar series
    11 vote(s)
    4.0%
  6. Battlefield series
    16 vote(s)
    5.9%
  7. D Series
    3 vote(s)
    1.1%
  8. F1 2014
    19 vote(s)
    7.0%
  9. The Crew
    15 vote(s)
    5.5%
  10. … (post your wish)
    155 vote(s)
    57.0%
Multiple votes are allowed.
  1. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    Unfortunately there isn't telemetry output in WRC8.
    Motion for this game (since WRC 5 and on) is a D-Box exclusive.
    Unless there's a way to tap in and convert that info to something usable by SimTools, I'm afraid there won't be any motion support.
  2. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    grid 2019 will be nice
  3. Kranky Pantz
    Canada, Eh!
    1,288Coins
    But is there telemetry output?
  4. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    Yes there is telemetry. I believe it's the same telemetry as in Dirt Rally 2.0 or F12019.
    It may well be a case of simply re-using one of those plugins. Give it a try, it certainly works with Simcommander using that method, so the same should apply here.
  5. Sarge
    - 181Coins
    Here is the hardware settings config for Grid 2019:
    Code:
    <?xml version="1.0" encoding="UTF-8" ?>
    <hardware_settings_config applyOOTB="false" version="9">
        <cpu name="Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz" processors="8" processorStride="1" processorBinding="1" />
        <graphics_card deviceId="0x1E07" rating="4">
            <resolution width="3440" height="1440" displayMode="2" vsync="true" maxFPS="120" vsyncInterval="auto" dynamicResolution="false">
                <refreshRate numerator="100000" denominator="1000" />
                <windowPosition x="0" y="0" />
                <outputMonitor index="0" />
                <aspectRatio auto="true" width="0" height="0" />
                <hdr mode="0" peakNits="1000" />
                <gamma adjustment="50" />
            </resolution>
        </graphics_card>
        <motion_platform>
            <dbox enabled="true" />
            <udp enabled="false" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
            <custom_udp enabled="false" filename="packet_data.xml" ip="127.0.0.1" port="20777" delay="1" />
            <fanatec enabled="true" />
            <device_manager ledTrueForGearsFalseForSpeed="true" />
        </motion_platform>
        <antialiasing smaa="false" taa="true" checkerboard="false" />
        <ssao enabled="true" algorithm="3" />
        <ssrt enabled="true" quality="4" />
        <ssrt_shadows enabled="false" />
        <texture_streaming sizeInMiB="2048" texelDensityBias="0.0" concurrentTextureSwaps="1" />
        <led_display fanatecNativeSupport="true" sliProNativeSupport="false" sliProForceBrightness="127" />
        <anisotropic_filter level="16" />
        <lighting quality="2" />
        <postprocess motionBlur="true" godRays="true" depthOfField="true" lensStreak="true" lensFlare="true" lensDust="true" bloom="true" />
        <shadows enabled="true" skyShadowMapSize="2048" skyShadowCascadeCount="4" skyShadowLowLod="false" worldShadowMapSize="2048" skyShadowMap32Bits="true" nightShadowMapSize="2048" nightShadowCharacterCast="true" nightShadowSourceCount="4" sampling="2" spotShadowMapSize="1024" spotShadowSampling="2" crowdInShadows="false" />
        <smoke_shadows enabled="true" mapSize="512" opacity="1.0" envOpacity="0.45" updateRate="2" />
        <advanced_smoke_shadows enabled="true" />
        <particles enabled="true" distanceScale="1.0" rate="1.0" high="true" />
        <crowd quality="high" globalDensity="1.0" grandstandGlobalDensity="0.9" />
        <vehicle_reflections cubeMapScale="2.0" cubeMapUpdateMode="all" dashMapEnabled="true" dashMapScale="2.0" dashMapUpdateMode="everyFrame" />
        <mirrors mirrorsUpdateMode="everyFrame" mirrorsRenderMode="carsAndCharacters" treesInMirrors="true" crowdInMirrors="true" highDetailMirrors="true" highDetailTyresAndCar="true" particlesInMirrors="true" showUIMirror="true" />
        <weather_effects rainSplashes="true" rainSheets="true" rainBeads="true" rainHigh="true" trackHeatHaze="true" planarReflectionsEnabled="true" planarReflectionsRTScale="1.0" planarReflectionsMipTailBlur="true" proceduralCloudRTScale="2.0" proceduralCloudTiling="7" proceduralCloudQuality="1" />
        <ground_cover enabled="true" grassFlattening="true" drawDistance="120.0" />
        <dynamic_hair quality="1" />
        <skidmarks enabled="true" parallax="true" />
        <skidmarks_blending enabled="true" />
        <audio radioDeviceId="" />
    </hardware_settings_config>
  6. Xcrosz
    Xcrosz New Member
    60Coins
    Some one have Grid 2019 plugin ?
  7. value1
    15,083Coins
  8. Xcrosz
    Xcrosz New Member
    60Coins
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    plugin are done, just pickup on downloads section
  10. paulopsx2
    brasil
    647Coins
    just open port on your firewall ( create a rule and put udp port in it )
  11. Xcrosz
    Xcrosz New Member
    60Coins
    Like this? I tried and still not working :(
  12. paulopsx2
    brasil
    647Coins
    nope. local port and remote cant be the same
  13. value1
    15,083Coins
    Hi Xcrosz
    After patching the plugin should be working without fiddling with the game. There is no need to change settings in the game or properties of the game. Unless there is an error in my plugin, of course!
    Can you please do some checks:
    • What is the exe-name of the game?
      Press
      <Ctrl>-<Alt>-<Del> to open the Windows Task-Manager
      Right-click on GRID 2019 and select Switch to details
      Let me please know the name of the exe-file (e.g. grid_dx12.exe)
    • Is there a subdirectory in C:\Users\Xcrosz\Documents\My Games\GRID (2019)\motionplatforms ? And is there a file SimToolsUDP.xml? (The name might be different but similar, I cannot remember by heart.)
    • Is there an entry in the file C:\Users\Xcrosz\Documents\My Games\GRID (2019)\hardwaresettings\hardware_settings_config.xml
      Code:
      <custom_udp
          enabled="false"
          filename="SimToolsUDP.xml"
          ip="127.0.0.1"
          port="4123"
          delay="1" />
    Thank you in advance!
  14. Xcrosz
    Xcrosz New Member
    60Coins
    Yes. I have that all. Actually i remember this issue. It's happen in F1 2019 either. I think the problem is Grid 2019 run in DX12. In F1 2019 it can choose to run with Dx11 and working with motion. I think if i can change to run Grid 2019 in DX11 it will working.
  15. value1
    15,083Coins
    So
    ✔ the exe name is correct.
    ✔ patching works as intended
    ✔ the files and the entries in the files are correct.
    • Does GameManager turn blue and say Game Running?
    • Do you see flickering data in TuningCenter?
    I have not found a DX11 exe in the GRID (2019) directory. If you can switch to DX11, please let me know the name of the exe.
  16. Sarge
    - 181Coins
    Hi @value1, I've just tested this plugin, worked 1st time for me, so I don't think it's a problem with the plugin itself.
  17. Xcrosz
    Xcrosz New Member
    60Coins
    Sadly Tunging Center not like you :(
  18. Xcrosz
    Xcrosz New Member
    60Coins
    Ok. I tried to change the Game Limits-Max/Min it's working now. Thanks for your help. So someone have a best setting in this part?
  19. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    Need For Speed Heat plugin
  20. Spiros K
    Spiros K New Member
    Freelancer
    Melbourne, Australia
    137Coins
    AC motor, Arduino, 4DOF
    This might be weird and not sure if it's been requested... but 'rocket league' would be fun on my 4dof.
