F1 2019 UDP from Xbox console
Discussion in 'Other Racing Games' started by KArijno, Aug 28, 2019.
  1. KArijno
    KArijno New Member
    - 1Coins
    Hello ! I have a dof reality 2dof . I tried use f1 2019 on Xbox and stream dip data to simtools using both f1 2019 and f1 2017 udp plugins but I have no success. I used a tool for be sure that udp data arrive in my pc and yes udp are correct on 20777 port but plugins f1 2019 doesn’t work and f1 2017 udp plugin doesn’t work also because use 5606 udp port . There are solution for my issue ? Thanks fabio
  2. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    hello, same on Pc
    151,668Coins
    +11,045 / 56 / -2
    Console support is primarily limited to the plugins created by @vthinsel, you can see the list of his plugins in the Download tab of his profile: https://www.xsimulator.net/community/members/vthinsel.15888/
    See the Console section of the FAQs for a theory and practical overview of UDP and console use, given SimTools is PC software: https://www.xsimulator.net/community/faq/consoles.27/category
