Question Dayton Audio TT25-8 Transducers
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Cartman_SP69, Jul 4, 2019.
  1. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Hi Everyone
    I need some help with getting an amp for 4 x Dayton Audio TT25-8ohm Transducers.
    I have 4 of them and they are the 8ohm versions but I do not know what amp to get I'm looking for something cheap as my budget is small what are your suggestions.
    Thanks and Regards
  2. BlazinH
    16,689Coins
  3. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    I'm looking at these Boards they are quite cheap i'm planning on running 2 pucks from each board at 8 Ohm. do you guys think it will work?
    DEVMO US TDA7498 2100W Digital Class D Dual Audio Stereo Power Amplifier Board
    I will really appreciate the assistance as i cannot afford to spend a lot of money.
  4. Twisted
    Twisted New Member
    - 5Coins
    Running 2 tacticle transducers here (buttkickers) in my couch.
    But for a amplifier with Tacticle transducers , I "Think" you need a amplifier with a cut/off filter.
    Becaue you want to sent only low signals to the transducers everything below 30,40,50Hz
    Otherwise your transducers would rumble also with voices/ high freqencies.
  5. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    I want to mount them on my motion rig and use sim vibe to simulate suspension and engine vibrations as far as i know sim vibe uses telemetry and converts them to audio signals for vibration.
  6. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Ok so i'm starting to play around with sim vibe but i must honestly say it is not really user friendly but apart from that i'm fialing to understand the manual on the manual it shows RPM chassis ect on my it only shows Gamevibe1 Gamevibe 2 ect can anyone explain to me why. The game I'm using is project cars 2
    153,788Coins
    +11,150 / 57 / -2
    Can you please verify what version of SimTools and Game Vibe you are using and also post pictures of all of your settings.
  8. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Hi Noorbeast I'm currently using sim tools 2.4 and game vibe 2.0 I will post pictures shortly :)
  9. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Hi Noorbeast please see the attached pictures as requested
    153,788Coins
    +11,150 / 57 / -2
  11. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Yes it has been sim tools works with the 2 Dof rig that i made and works perfectly the only thing is on game vibe i do not know what is what as it only indicates Game vibe 1 and Gamevibe 2 etc. Not RPM Chassis etc in the game vibe app so you don't know what you are changing if you change gamevibe 2 for example.
    153,788Coins
    +11,150 / 57 / -2
    Seeing Game Vibe instead of RPM and the like suggests PC2 is not running.
  13. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Ok new problem when project cars 2 starts gamevibe closes
  14. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Ok i have figured it out Game vibe crashed if you use the following settings on project cars 2.
    Shared Memory : Project Cars 2
    UDP Frequency : 2
    UDP Protocol Version : Project cars
    It Works Perfectly if you use the following settings.
    UDP Frequency : 2
    UDP Protocol Version : Project Cars 2
  15. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
  16. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Hi guys i have received my transducers they work like a dream in sim hub but i cannot get them to work with game vibe. I thought i will settle for Sim hub for transducers and sim tools for motion but sim tools does not work when sim hub is open no movement on the motors. do you guys have any suggestions.
    153,788Coins
    +11,150 / 57 / -2
    Have you excluded the com ports used by other devices in the SimHub settings?
  18. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Nope i have not forgot about that I use to have a few devices connected to it but forgot to remove them i'll try that tonight and see what happens the game i'm running is project cars 2. just as some info I will exclude and or disable all the devices in sim hub and try again will let you know thanks for getting back to me :)
  19. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    I have also just realized i'm using an old version of SimHub as on the new version you can select what ports SimHub will can and ignore the old version did not have that option, i'm sure that will sort out the issue :)
