24v 1000w 44A Switching Power Supply !!!!BARGAIN !!!!
Discussion in 'Marketspace - Marktplatz' started by SilentChill, Feb 6, 2019.
  1. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    I'm not sure if I understand what you're trying to say, @Anthony Morris. I guess you don’t mean the PSU has 44 A @ 240 V! That would rediculously mean it has >10.000 W...
    Btw: The PSU can deliver up to 51 A according to the manual.
    So, are you saying, that my voltage of 0 V at the output side depends on my voltage of the input side? No way!
    Do you own this PSU?
  2. Anthony Morris
    Anthony Morris Member Gold Contributor
    Multi trade
    Essex UK
    38Coins
    Hi
    51amps at what voltage ? Is it 240v because amps = (watts / volts) the watts hasn't changed so if your nominal voltage is less than 240v (industry standard to measure off this) you will have less than 51amps if your house hold supply or nominal voltage is normal at around 226volts
  3. Anthony Morris
    Multi trade
    Essex UK
    38Coins
    10,000 watts divided by 240 volts is 41.6 amps
    51 amps times 240 volts is 12,240 watts or 12.24 Kva
  4. My.stAr
    Engineer
    1,064Coins
    DC motor
    :confused: ?!
  5. My.stAr
    Engineer
    1,064Coins
    DC motor
    And how does that help me?o_O
  6. Anthony Morris
    Multi trade
    Essex UK
    38Coins
    It was fyi and the coins :thumbs
  7. My.stAr
    Engineer
    1,064Coins
    DC motor
    Why do you collect coins if you're a gold contributor?! :think
    And maybe you saw my occupation... I know how to calculate these things :p
  8. gingercat
    gingercat New Member
    Software Engineer
    Nr Lancaster, UK
    131Coins
    DC motor, SimAxe, Arduino
    Does your drive have the jumper lead on the back?
  9. My.stAr
    Engineer
    1,064Coins
    DC motor
    Yes, and it's pluged in in CN1.
  10. SilentChill
    20,592Coins
    Hmm seems strange, I don't know what to suggest to be honest. I will have to power mine up and see if they work as I have 3 of them. I can only presume you have read the manual and there is nothing special you need to do to get them to work, jumper or something ?
  11. gingercat
    Software Engineer
    Nr Lancaster, UK
    131Coins
    "High quality power supply certified for medical & military applications."
    Could be worse I guess, it could have been in use for its original purpose if/when it failed :)
  12. My.stAr
    Engineer
    1,064Coins
    DC motor
    Yes, I read the whole Manual. To find out, that everything is wired the way it should be. I have the jumper like it was deliverd +Vm to +S and -Vm to -S.
    As far as I understand this jumper setting makes it a „normal PSU” without any remote functions…
    LOL, yes. But I didn't use mine at all:mad:
  13. My.stAr
    Engineer
    1,064Coins
    DC motor
    Found the problem:
    the output voltage adjustment trimmer was put to max which caused the PSU to shut down. The green LED turned on and off again immediatly but the fans were working, so I didn't assume in first place, that the PSU did shut down.
    After turning the trimmer down I can measure the voltage. Hopefully I will be attach the actuators to my rig, than I can also test it the PSU delivers enough current.
  14. gingercat
    Software Engineer
    Nr Lancaster, UK
    131Coins
    Glad you got it sorted. Mine is spot on 24v so I didn't need to touch the trimmer thankfully or I'd have convinced myself I'd broken it :) Only thing missing is something to plug in to it now!
