Hannibal's thread into DIY motion platform
Discussion in 'DIY Motion Simulator Projects' started by hannibal, Feb 15, 2019.
  1. hannibal
    hannibal Active Member
    4,489Coins
    Im trying to create my own anti rotation adapter...
  2. Pierre Lalancette
    3D teacher
    Quebec, Canada
    7,683Coins
    3DOF, DC motor, Arduino, 6DOF
    Will it use friction?
  3. hannibal
    4,489Coins
    trying not to, rather ride the edge of the v-slot on 5mm x 10mm x 4mm bearings...
  4. hannibal
    4,489Coins
    Reinforcing the motor mount by additional 3/16 steel strap with 2x 6-32 bolts.. why so small ampflow??
  5. Flymen
    Montreal, Canada
    2,416Coins
    DC motor, 6DOF
  6. hannibal
    4,489Coins
    its ok. the anti rotation.. i changed and went the conventional route, like everyone else... using 3d printers v-slot wheel.
    hey at least you can weld!
  7. hannibal
    4,489Coins
    Trying to finish the bottom section while figuring how to build pulley and pot assembly.. waiting for 22mm u bolts to come in.
    Shot of bottom assembly
  8. Pierre Lalancette
    3D teacher
    Quebec, Canada
    7,683Coins
    Woah! Those look big and though. And I'm only talking about your feet. ;)
    • Funny Funny x 2
  9. hannibal
    4,489Coins
    lol.. it was late night.. i am now embarrassed... @Pierre Lalancette you just called me big foot! :p
  10. Pierre Lalancette
    3D teacher
    Quebec, Canada
    7,683Coins
    LOL. Get use to it, because soon you'll be filming yourself on that thing. And since you look like you work late at night, you'll be filming yourself in your pajama...
    Just like me. :)
    • Funny Funny x 3
  11. hannibal
    4,489Coins
  12. hannibal
    4,489Coins
    Waiting for 22m u bolts for my pot assembly along with hall sensors.
    Starting to build my power systems as well waiting for hdpe boards to mount the components on... i wasnt keen on wood boards like sixdegreesoflfight..
  13. hannibal
    4,489Coins
    its come to my attention that one of my actuator v-slot rail is not aligned with the ball screw...
    looking at shimming the bearing block...
    i dont think the screw is bent because there is no deflection when i rotate it.
    checking the v-slot rail, it seems more or less square 90 degrees..
    anyone has ideas to align screw parallel to screw besides shiming? perhaps i have a bad bearing block BK12?
    @wannabeaflyer2 @Pierre Lalancette @noorbeast @SilentChill @Flymen
  14. SilentChill
    20,403Coins
    Have you a picture what you mean ? Mine arent alligned properly infact they are all skewiff but hey it works :D
  15. hannibal
    4,489Coins
    One of my actuators dont align to the top.. but checking 2 others they are pretty much around center...
    @SilentChill
  16. hannibal
    4,489Coins
    from looking at it, i feel it is the bearing block wasnt machine correctly to fit bearings. the base with motors and plates are with in my measurements.
  17. dmcmd
    dmcmd New Member
    118Coins
    How are you planning on attaching the carbon fiber tube to the ballscrew? I'm having a hard time getting my head around how people are doing that...
  18. hannibal
    4,489Coins
    img going to use the nut housing. it will be epoxied with 3M 2216 A/B epoxy and using another piece of carbon tube 28mm OD 25mm ID as a shim... at the moment i am working on the power section, and the pot /pulley housing..
  19. dmcmd
    dmcmd New Member
    118Coins
    Thanks! At the rate you're going on this, you'll be on that soon. Please take lots of pictures so I can see how you do it.
  20. hannibal
    4,489Coins
    im going at snails pace.. but i want to build it right the first time. if i dont have to go back and forth later, ill deal with it now. definitely need patience for DIY.
    right now 3 actuators are lined up properly, where as the other 3 are not.. trying to figure out what is the misalignment issue between V-slot and ball screw.
