looking for advice on mounting the timing pulley (for linear actuator)
Discussion in 'DIY Motion Simulator Projects' started by hannibal, May 30, 2019.
  1. hannibal
    hannibal Active Member
    4,490Coins
    i can not for the life of me find anything ideal for my actuator, when it comes to mounting the timing pulley and the potentiometer.
    i am not keen on the 3d printed parts, especially looking at sixdegreesofflight's build, i feel like in time, the 3d parts will be subjected to wear, since the shaft rides on the 3d printed part, instead of on a bearing....
    i like to find a bearing housing for a bearing that has a 6.35mm bore, im also looking for a part number for a bearing with 6.35mm bore.
    at this time im just trying to affix a GT2 Timing Pulley 40 teeth Bore 6.35mm to a pot (or hall sensor)
    any suggestions appreciated :)
  2. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    Plenty of 6.35 id bearing exist.
    Search for " bearing 1/4" id ".
  3. hannibal
    4,490Coins
    bearings exist, how ever only one bearing assembly / block looks remotely feasible.
    searching miniature bearing block yield one descent result, and that option is not easy for me to affix to my actuator without more precision holes
    i came here to see if anyone had better ideas..
    only found this https://www.sparkfun.com/products/12333 , may use this or just develop something from scratch
