Showroom My 6DOF with DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by Vitalius, Sep 1, 2018.
  1. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    568Coins
    Motion platform, 6DOF
    Unfortunately I had to realize that my 4K-TV mount :) too big for the whole construction is so that I will not fit through the front door. I have to think now how I can fix the TV mount with screws. So tomorrow we go back to the hardware store.
  2. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,992Coins
    3DOF, DC motor, Arduino, 6DOF
    What is the size of that thing? I can't see the ruler. It's huge!
    I like the way you attached your seat to the platform. I might steal that idea for my carbon fiber platform.
    What 3D app do you use for the sketch?
    Keep on the good work!
  3. Vitalius
    Bonn
    568Coins
    Hello Pierre, I use SketchUP Make. Is free. Very easy to learn. There are many learning videos i youtube. I can really recommend the program.
  4. Vitalius
    Bonn
    568Coins
    I was really busy today.
  5. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,992Coins
    Ok, thanks. I know SketchUP even though I have not used it a lot.
  6. Vitalius
    Bonn
    568Coins
    I was really busy today.:)
    Only the slider can not be moved.
  7. Vitalius
    Bonn
    568Coins
    Hello, here are the dimensions of my platform
  8. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,992Coins
    Well, my platform triangle is almost identical to yours. So, either yours is not that big, or mine is huge too.
  9. Vitalius
    Bonn
    568Coins
    Main thing just fits in the room that you can sit next to it. :)
    The mass I have determined more or less read here from the forum.;)
  10. Vitalius
    Bonn
    568Coins
    Unfortunately, yesterday I realized that my monitor mount is wobbly. So everything dismantled and taken to the garage. I planned that.Unfortunately, yesterday I realized that my monitor mount is wobbly. So everything dismantled and taken to the garage. I planned that. The TV mount is now firmly welded!
  11. SilentChill
    20,582Coins
    How heavy is your platform now ? Looks like a lot of metal there
  12. Vitalius
    Bonn
    568Coins
    Frame = 18.1Kg
    Playseat Seat Slider = 2,3KG
    Chair = 11Kg (I wish you a carbon like in The Expanse:thumbs)
    TV = 16Kg
    Total = 47.4KG
  13. Vitalius
    Bonn
    568Coins
    hi, what will your carbon fiber platform look like? Have you already made designs?
  14. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,992Coins
    I have tried, using SolidEdge. I used something that I'm not used to use (assembly) and I had only one size of tube. This is why they are all the same size in my design.
    I did not show them because the sketches I made to start are bad, the design ain't that good and since I've seen yours, I change a lot of things. I really like the 2 bars on each sides of the seat that are parts of the main triangle in yours.
  15. Vitalius
    Bonn
    568Coins
  16. Vitalius
    Bonn
    568Coins
    Hello everyone.
    I have a question.
    My platform weighs 50 kg and kept off (no power) motors so that does not sink.
    Weigh 85 kg and must switch on engines before boarding!
    So now I want to compensate for my weight with gas spring. I thought of 350N per gas spring per side.
    So these are 3x350N total 1050N = 105kg. Am I right or wrong with my considerations?
    Maybe someone has another solution for my problem?
    Or is it enough for a gas spring under the platform to be exactly in the rent?
  17. Vitalius
    Bonn
    568Coins
    As I promised a long time ago here is the video with my platform. ED is even more fun now
    • Winner Winner x 3
  18. SilentChill
    20,582Coins
    Looking good dude :) well done !
  19. Vitalius
    Bonn
    568Coins
    Thanks, next test has to be done with VR headset.
  20. Vitalius
    Bonn
    568Coins
    Hi, I'm trying to solve problem with condyle. In the photos you can see that I have very little distance between the condyle and the axis. I tried to eliminate SketchUp problem in which I turn lower brackets for condyle about 60 degrees. Unfortunately, I am not so good at SketchUp and can not afford it. Does anyone have a tip for me as I get the problem under control?
