Showroom My 6DOF with DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by Vitalius, Sep 1, 2018.
  1. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    540Coins
    Motion platform, 6DOF
    I was a little inaccurate, in case of emergency or when driving over limit switch all SMC3 are de-energized.
  2. Vitalius
    Bonn
    540Coins
    Hello, yes I imagined it that way. When I'm done with basic build at some point I'll bring a gas damper under my platform exactly on midpoint. But first I still have to cope with building up Ring.
  3. SilentChill
    20,596Coins
    All I do is turn simtools off, battery off and psu's then remove and reinsert the usbs for each arduino turn it all back on and its good to go , only have to turn simtools on and away ya go :)
  4. wannabeaflyer2
    london uk
    8,349Coins
    Hi Guys . have to admit during the initial learning the system, and fine tuningto puch the platform speeds etc , resetting the position of the actuators by hand is a PAIN Grrrrr . but I have a crazy idea to use a low voltage battery and change over switch to power to each actuator and drive it back into safe zone without the need to get fingers in danger zone ...
    hear me out as im just thinking aloud and many minds make light work of crazy idea's .
    OK so the system im thinking about follows, I need to disconnect one Motor Lead to isolate it from the Sabertooth temporally so that im pot put power into the sabertooth Motor feed Terminals , then I could use the low voltage 7.2v 2s Lipo battery on both motor terminal to slowly drive the actuator back to working range.
    once in safe zone I would flip change over switch and allow the sabertooth to regain control of the motor , once the reset latching circuit is re-activated . (in my case the AMC and sabertooths are still powered Hmmmm on the basis that a reset would allow the sim to continue without having switched the system Off )
    ideally with FlyPT and the new Optical encoder setup this wont be required , but this idea is a crash backup only .
    Basically in e-stop or limit switch detection situation, the platform may backdrive affecting one or more actuators as we know it can ,
    This concept would allow me to switch out any actuator required and a allow quick hands free movement away from the offending limit switch, ironically this is where the dampers would have helped to minimise backdriving action after repositioning ,cos lets face it depending on the design the dam things can or may still backdrive while your resetting the latching circuit activation so this needs to be done before any actuator triggers the lower limit switch again .
    Im only thinking of this convoluted option because of the lack of access to the ballscrew when trying to manually reposition actuators .. ones bad enough but all 6 is what I call OFFS mode that'll be calvin speak for Oh for (expletive ) sake :) .
    I have seen somewhere Guys use Diodes across limit switch NO and Common to momentarily drive motors in the reverse direction back to a point if limit switch is activated, but not tried that yet .. im sure the diagram for that connection is here somewhere ... yesy I know once again with the rambling so Im Outta here for now LOL
    If this idea is already out there then you reading what had to be a Subliminal message repeated LOL so ignore the waffle
  5. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    I know that SeatTime has such a setup. He had momentary button in his cockpit to bring his platform up and running. I have no idea what's his circuit though.
  6. Vitalius
    Bonn
    540Coins
    hello together, I'm happy about every solution! For me, I thought to install an additional switch to bypass all connected in the series emergency stop switch or closes together. But you have to go through a checklist how to turn off the game and SimTool and then press this switch. Not perfect but without fingers :).
    Does any of you have a link to the circuit or its tread from SeatTime?
  7. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Hi ,
    When I hit a limit switch, all motors turn off like Pierre , depend the situation sometime all goes down but normaly it 's only one or two . I have a control box ( start and stop with emergency button ) that I can put standby all drives and replace the one who is down at the middle position, set at zero all actuator on Flypt and after this setting only push the start button to active all drive, and play again !
  8. hannibal
    hannibal Active Member
    4,491Coins
    not sure if u are willing to share control box diagram schematic.... :) :) :)
  9. Vitalius
    Bonn
    540Coins
    Interesting ! I hope you (@Flymen ) allow us to see your solution? But since we or most of the solutions here only switch off the power supply, I find the worst when the platform goes down because the engines are no longer holding! There is the danger that the lower limit switches will be triggered.
  10. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Hi ,
    I have 3 ballscrew( made japon) with low friction and 3 others with more friction ( good quality ) .
    That`s why when I hit the lower switch those one have more friction stay at the same position and some time the cheaper goes down because all motors are off and depend the position too . exemple : I like when I put gas or brake and the simulator goes fast front and back but with this situation , sometime I hit one of actuator back of me and all my rig have the weight on this one. My set up is not the same of yours . exemple I have diferent drive to control motors !
  11. Vitalius
    Bonn
    540Coins
    Hello, interesting solution that with ballscrew with low friction! Man never learn off! :)
  12. Vitalius
    Bonn
    540Coins
    :) I hope I get the joystick mount ready. Throttle is tightly screwed. Then I can finally fly loss. ED is already waiting
  13. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    It looks good. I can`t wait to see it flight in a video.
  14. hannibal
    4,491Coins
    videos! i like to see! as well... :)
  15. Vitalius
    Bonn
    540Coins
    Unfortunately, I have to disappoint you. Sorry
    In yesterday's test, I had to conclude that the kanze platform is unstable. Wakelt like jellyfish :(. So I start to dismantle again and will amplify that whole and a little differently designed.
    So go back to the garage. :)
  16. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    Two steps forward, one step behind.
    Design, construct, break, redesing, reconstruct, break...
    Have fun!
  17. Vitalius
    Bonn
    540Coins
    @Lalancelot thanks, I will have determined
    I will shorten the shelf for the pedals and connect it to the monitor holder.
  18. Vitalius
    Bonn
    540Coins
    Holder for chair I will weld firmly to the frame.
    Bishen weight is also saved by it
  19. Vitalius
    Bonn
    540Coins
    So my new frame is almost done. A few more weeks ;-) ... and
    I bought a useful Playseat Seat Slider at Amazon and integrated with drilling, cutting and welding.
  20. Vitalius
    Bonn
    540Coins
    I hope this construction holds. Or maybe you still have some bracing, wait and see
