Question Power supply tripping
Discussion in 'Electronic and hardware generally' started by Pino Pistolidas, Feb 28, 2019.
  1. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    I don't think a 0.7v voltage drop is going to make much difference, you may loose a small amount of speed from the motor but otherwise should be ok. Any voltage bellow 12v is undesirable so if your concerned you could switch to using led power supplies, they have an adjustable voltage trim pot on them and go up to 13.5v so you could adjust it to get 12v after the diode. My 480w 12v supplies were £22 each on ebay and perform well.
  2. BlazinH
    16,677Coins
    If you need full power often your motors are probably under powered for your rig and its weight anyway. I use 85% max power to my motors and you will notice many members that use SMC3 don't set pwmmax to max of 255.
  3. Arazok
    Arazok Member
    Computer scientist
    783Coins
    you are right. With my MM pwmmax was set to 125, so enough room for increasing
  4. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Pino, are you using the KBPC5010 and as well two power clamp resisitors ? Or only the bridge rectifier ?
  5. Pino Pistolidas
    Pino Pistolidas New Member
    Netherlands nijkerk
    174Coins
    Hello Arazok,
    Sorry for my late reply. Yes, I'm using power resistors I have 4 pc. of 6 Ohms and 100w. I have put these 2x2 in parallel so on each voltage clamp I have a 3Ohms 200W.
    And I'm using the KBCP5010, which helped the most.
  6. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    Thanks @Pino Pistolidas ! That helped my PSU not to shut down all the time.
    Interestingly the resistor seem to do nothing... Using the diagnostics in DEScribe the P2 shows -100 % all the time (atm only motor 2 is used for testing).
    Are your resistors used?
  7. Pino Pistolidas
    Netherlands nijkerk
    174Coins
    Hello My.stAr,
    To be honnest I didn't see any difference in the proformance of the sabertooth or the tripping of my powersupply when I added the power resistors. And what I can recall I also had these kind of readings from the diagnostics in DEScribe. I did leave the power resistors on, they might still do some good:confused:.
  8. My.stAr
    Engineer
    1,064Coins
    DC motor
    OK thanks:thumbs
    as long as the system works I don't care if the resistors do something or not. It's just wasted money if I would need the resistors someday in another project.
  9. Arielnac
    Arielnac Member
    Argentina
    240Coins
    [QUOTE = "Pino Pistolidas, post: 181364, miembro: 29368"] Hola My.stAr,
    Para ser honesto, no vi ninguna diferencia en la potencia del sable o el disparo de mi fuente de alimentación cuando agregué las resistencias de potencia. Y lo que puedo recordar también tuve este tipo de lecturas de los diagnósticos en DEScribe. Dejé encendidas las resistencias de potencia, aún podrían hacer un poco bien :confuso:. [/ QUOTE]
    Hi. I will use this solution for my project with BTS7960. It has happened to me during the tests with SMC3 that the power supply is turned off when the motors are required.
  10. Arazok
    Arazok Member
    Computer scientist
    783Coins
    I am fine with my solution without the resistors (even if I bought them). Works fine with KBCP5010 only.....
  11. My.stAr
    Engineer
    1,064Coins
    DC motor
    For me it also works without the resistors:)
  12. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    using resistors doesn't make sense to me.
    increasing the resistance only reduces the control of an engine.
    damping.
    the very low internal resistance of the H bridges is excellent for keeping the precise rotation of a motor under control, if we weaken this brake we also lose control of the motor.
    I would certainly take care of the power supply side, even if necessary for a powerful non-controlled linear power supply, ie a large toroidal transformer, a suitable diode bridge, and capacitors to level the alternating ripple.
    these power supplies do not turn off.
    Marco
  13. Kass55
    Kass55 Member
    PC support
    315Coins
    Thank you for this. I will try the KBPC5010 Bridge Rectifier Diode
    I am using similar motors (12V version)
    90ZYT155-12-MCP4 with 1:50 gear box 370W from Motion Control Products
    Connected to the new JRK G2 board with a PC 750W 62A PSU
    and I am getting getting constant power supply tripping out
    when moving the motor quickly forward and reverse. (with no weight on seat yet).
    Runs fine if I go gentle slow up & slow down
    or set PID to 0.399, Max. power down to 100 and Max. acceleration down to 6
    But this gives slow response.
  14. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Hi. Wait for testing with simtools when you have a functional platform to draw conclusions about it. The same thing happened to me during the tests with SMC3.
  15. MarcoMade
    italy
    157Coins
    if I understand your problem correctly.
    the psu atx power supplies bear the emf badly.
    you could try with a schottky diode to protect the outputs of the power supply against the voltage returns caused by the motors during braking
  16. Stefzouille
    Stefzouille Member
    595Coins
    2DOF, DC motor, 4DOF
    thank you for this information. Do you happen to have a connection plan or diagram?
    the sunet is a little dated but with a little luck and kindness?!? ;)
  17. Stefzouille
    Stefzouille Member
    595Coins
    hello, do you have a diagram or a plan with the correct components pls?
