Showroom My 6DOF with DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by Vitalius, Sep 1, 2018.
  1. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    550Coins
    Motion platform, 6DOF
    Thanks, can you help me with the Elite Dangerous question?
    152,646Coins
    +11,088 / 56 / -2
  3. Vitalius
    Bonn
    550Coins
    Cool! Thank you. Everything works now!
  4. Vitalius
    Bonn
    550Coins
    Hello everybody.
    Can someone please help me with this problem?
    When I load my ring, he becomes restless and begins to tease.
    Here is a video of it:
  5. SilentChill
    20,596Coins
    In SMC3 UTILITY set Fpid to 3 or 4 ;) hopefully that works if not post screen grabs of your settings
  6. Vitalius
    Bonn
    550Coins
    Here are my set
    Already have FPID at 10.
    I had to set Deadzone to 5 to minimize engine additions. But I arrived today at 10. I probably have "slack" as described in SMC3 Windows Utilities.
    "Deadzone This creates a hysteresis zone for the engine feedback If you need more than 1, you probably have too much slack in your mechanical setup."
    Unfortunately, I do not miss a where to look for me.
    All my feedback pot are soldered firmly and I use shielded cables at motors and pots.
  7. titomaky
    titomaky Member Gold Contributor
    181Coins
    Motion platform
    Hello, try to upload the PWmin and PWMax values
  8. Vitalius
    Bonn
    550Coins
    Hello I tried, unfortunately, the vibrations generated were even stronger.
    PWmin have already been at 60.
  9. Vitalius
    Bonn
    550Coins
    "Its possible its the 50k pots. It's recommended to use 10k or less with arduino." from Link
    Which potis do you use?
    I use 50k pots
  10. SilentChill
    20,596Coins
    You should have PWmin at Zero and no deadzone.
    Use hall sensor pots if you can they are far superior to normal pots for interference.
    I use cat5 cable for my HallEffect pots and never had a issue.
    And probably using 5k or 10k pots if not hall effect ones may help I dunno
  11. Vitalius
    Bonn
    550Coins
    Thank you for the answer. Can you please tell me the name of your hall sensor pots? BI 132 I could still see in the photo. Thank you in advance
  12. SilentChill
    20,596Coins
    I use a gear box on my 360 degree hall sensor which isnt the best way
    These are probably what you want https://uk.farnell.com/bourns/amm20b5a1clasl380/position-sensor-multiturn-42mm/dp/2292033
    Edit: or buy some really high quality wire wound pots
  13. titomaky
    181Coins
    Motion platform
    Those potentiometers are very difficult to tame, you should use 10k linear pots
  14. SilentChill
    20,596Coins
    What do you mean by hard to tame ?
  15. Vitalius
    Bonn
    550Coins
    Sorry guys, I made false statements. I have the 10K Potis. Sorry. I just saw:(
  16. Vitalius
    Bonn
    550Coins
    I will try to change PWm to zero and test it.
  17. Vitalius
    Bonn
    550Coins
    At the moment I'm busy repairing the ball joint mount. The first parts I made from PLA. The new ones are currently being printed from PET-G.
  18. Vitalius
    Bonn
    550Coins
    152,646Coins
    +11,088 / 56 / -2
    The video does not play, perhaps it is set to Private on YouTube instead of public.
  20. Vitalius
    Bonn
    550Coins
    But now has to go, forgot last button "publish" click. Thanks
