Arduino Leonardo SIM Wheel
Discussion in 'DIY peripherals' started by Sieben, Nov 27, 2018.
  1. Sieben
    Sieben Active Member
    2,241Coins
    Guess BTS needs a better cooling, to how it is done on default. The radiator seems not joined properly, at all, to that.
    [​IMG] [​IMG]
  2. Sieben
    2,241Coins
  3. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    @Sieben
    you could put the bts in an atx case and use its 12cm fan to keep it cool.
    in addition to spreading thermoconductive paste between heat sink and pcb (not too much)
    this and photo of the 2 dof drive, but for the steering wheel ff I did the same thing and it has been working for more than a year without any failure or thermal block
  4. MarcoMade
    italy
    157Coins
    another example of a first attempt, then moving on to bts 43a
    cooling below and above
  5. Sieben
    2,241Coins
    MarcoMade very cool. Thanks for sharing. Have got some prepared fans too to be attached too.
    Yes BTS needs some additional work with thermo paste and some fans too. That’s true.
    I decided to make own couse curious. ) And one can make with realy a good powerfull mosfets. With "whatever amperage". Like 180 Amps, or even 300. Guess may be will need even no cooling for them).
    Also there is, as some misconcept or what, conserning the use of two bts it parrallel. Was confused also with all that stall curents etc. and realy diff info on it. One BTS should coupe with the currents it is made for to handle. So no much need to add another one. Seems that must all depends on the power supply Amperage only.
    Checked the STM32 board I've got, and it is 3.3 volts compared to Arduino's, that is used, with ~5V controlling signal. Some mosfet gate drivers should be made additionally. If not go to the Logic level Mosfets to work with STM32. Seems to be not the very best option.
    Also fired up IRacing, and it gives good FFB. One side for now. But it works allright absolutely. And no heat, at least in a short run. Don't know how will cope with full version, when both pins attached. Hope will be no conflicts, and fried mosfets due to that. But it is also, all is a sorted out issues.)
  6. Sieben
    2,241Coins
    As p.s. on why double/triple BTS are used, guess only due to the fact that it on continuous load can handle 10-12amps only. 43A only on a very short terms. But also then someone use it in 12/24V and even 20-50amps power supply.... Maybe reducing the FFB amount. )
  7. MarcoMade
    italy
    157Coins
    personally, on my ffb system with arduino leonardo, I use 2 of 43b bts in perfect parallel (short and equal cables in order to have an almost perfect parallel and take advantage of all the current supply).
    feed the ffb system with a 66A 12VDC server power supply.
    I can assure you that after an hour of driving on a run set the cables become hot 10 sq. mm x 2 m length.
    perhaps with H motomonster bridge and very poor in current.
    bts 43A are very solid. I also use them for the 3 engines of the dynamic station with extreme success :)
  8. Sieben
    2,241Coins
    MarcoMade, that's great but may depends. Yes they can run good no doubt, but there are other reports on there performance and qualities etc.
    I guess get good ones BTS too, with all that nice packaging, as if to be the reason to judge on there origin, as described also, on ebay etc o_O. I run'em tough, (allright 12.5A not that tough, but still as it appeared to be :D, without good cooling quite a faire determination) But they give away with this)
    It's cool to make the driver DIY, 'cause U can fix it, peace of cake, if smth. And U'are set with it. Change a single MOSFET, u know, and so on. With faulty BTS it's a more tough thing to work on this matter. Also as a nota bene )
  9. Sieben
    2,241Coins
    MarcoMade what sim do you run and with what soft? Because, with Arduino Leo and EMC for example, it's bug less only with Iracing. AC brings some issues there. Don't try much others but curious of you experience. :)
  10. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    what you mean emc bug on assetto corsa..??
  11. Sieben
    2,241Coins
    Need to be switched on and off. Constantly. Iracing are without it.
    Take another arduino and now it is much better with h-bridge diy driver. But, wheather need to take another mosfet or make mosfet gate driver for one side of ffb. A bit weaker with pin 9.
  12. MarcoMade
    italy
    157Coins
    my station and a 3 dof self-built, two dof for dynamic movement with power steering motors opel corsa , and a wiper to pull the belts
    hello, I use mainly ride trim with oculus rift, and dirt rallye on the projector. I have read that someone has had problems with drop frame with iracing. with trim I am fine! I have a big 4-brush 13kg motor that produces good torque, :)
  13. Sieben
    2,241Coins
    MarcoMade thanks, but what is ride trim? ) Dirt rally, ok, will add to the list of compatibility with arduleo)
    Nice!
  14. Sieben
    2,241Coins
    New mounting stuff.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  15. MarcoMade
    italy
    157Coins
    I'm sorry, the translation, I'm Italian and help me with translate to communicate. I wanted to write Assetto corsa with oculus rift. I wish you a good continuation with your beautiful project, have fun
    Marco
  16. Sieben
    2,241Coins
  17. Sieben
    2,241Coins
    Made some adjustments with min force for the wheel for the step test 2. To eliminate the zero responce zone.
    For the game have got some other set ups on it.
    And new link to encoder.
  18. Sieben
    2,241Coins
    Made some corrections on the "gear to the shaft connection".
  19. Sieben
    2,241Coins
    Noname wheel from oklick. 240mm 0.4 kg weight. )
    Step test.
    300/600
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Some current limiting tests with bulb 60/55w H4 12v.
    And linearity test with it. May be someone can find it useful) The FFB is less with it, but no motor overheat etc.
  20. MarcoMade
    italy
    157Coins
    A good solution against extra current.
    unfortunately, tungsten filament lamps have resistance to cold wire close to 0, the moment they heat up the resistance increases greatly.
    so you find yourself a steering wheel that does not respond to transients effectively.
    some dyers drill holes and mount a rear fan to extract the generated hot air.
    heat is a price to pay.
    I use a 13KG DD engine weighing 0.75 hp (old 30 year old industrial scrubber) and generate nearly 16nm of torque at 12v. I drilled and used 12cm fan to extract the air, after 1 hour of driving I arrive even at 45 -50 degrees, which I think is a trifle for traction motors.
    how many degrees does your engine get?
