FlyPT 6DOF/Stewart/Hexapod Interface for linear and rotating actuators
Discussion in 'FlyPt Mover' started by pmvcda, Jan 2, 2019.
  1. BlazinH
    16,671Coins
    Its completely at his discretion of course what he wishes to do and how far to take it but if he wishes it I have no doubts he can accomplish it :). I just crave a little diversity which is lacking here imo. Of course every other developer isn't interested in or even know of motion software so its a rare thing. I think with all the "Simtools" stuff going on here though it gets lost this site is not just for Simtools but also open to other ideas and contributions which is a great thing.
    For 6dof only though I think things like axis assignments should not be hard. And the tuning center just scales telemetry which can be done with simple multiplication. I agree it would be nice to have compatibility with all games Simtools does but since its plugins aren't sharable we could ask plugin developers if they would also contribute to other software too. Maybe we could even turn some kind of open telemetry server idea into a community effort some day :!. In any case he has a Simtools plugin already for compatibility when necessary.
  2. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    Hello @pmvcda . I tried the version 1.8.1 with Asseto Corsa direct link (no Simtools). It sent two of my actuator to their max (before the limit switch) and did nothing else. I did not time to move the car. I reset everything and tried again. Same thing.
    Then, I tried with Simtools, for Elite and I got this:
    I went back to version 1.7.3 and all went fine (exept for the Lock to lowest position).
  3. Dirty
    All the way up front.
    7,957Coins
    Hey @pmvcda :)
    may I ask how you create the pose for the platform? I assume that for every frame you create the platform at the origin and then apply translations and rotations using the motion data. Is that correct?
    I am asking, because I am considering different orders in which those transformations (to create the pose) are being applied. Initially I thought: 1. translations, 2.rotations (rotations dependent on translations)
    ...then I realised some problems with false cues and changed to 1. rotations, 2. translations (translations dependent on translations). And again, I realised different problems with different false cues.
    I came up with an unorthodox solution as I discussed with @hexpod using an intermediate pose, but I am still unsure. So can you do me the favour and describe in what order you apply these transformations? That could help me a lot.
    Dirty :)
  4. pmvcda
    15,547Coins
    Your bit range is 8 bit?
    I thought it should be 10 bits for the SMC.
    In your topic, you had 10 for bit range.
    Please try :)
  5. pmvcda
    15,547Coins
    I'm using two solutions:
    1st rotation
    2nd translation in world coordinates
    Or:
    1st rotation
    2nd translation in top platform coordinates
    You can select witch one to use.
    Transform swap checked is translation in platform coordinates
    unchecked translation in world coordinates
    Compound is hard to to.
    I have it in a build, but it's drifting.
    The drift is caused, because I have to work with deltas, not absolute positions.
    I see @hexpod asked for this.
    I may take a look if I can make it better.
  6. pmvcda
    15,547Coins
    For translation/rotation, see above post.
    I will try to make it better.
    The filters, are basic stuff.
    No problem in sharing (my current c# filter class):
    Code:
    // Filter class - by the FlyPT
    // Last revision 15-03-2019
    using System;
    class ClassFilter
        // Public constants
        public const sbyte NONE = 0;
        public const sbyte EMALOWPASS = 1;
        public const sbyte EMAHIGHPASS = 2;
        public const sbyte EMABANDPASS = 3;
        public const sbyte EMABANDSTOP = 4;
        public const sbyte DEMALOWPASS = 5;
        public const sbyte DEMAHIGHPASS = 6;
        public const sbyte DEMABANDPASS = 7;
        public const sbyte DEMABANDSTOP = 8;
        public const sbyte TEMALOWPASS = 9;
        public const sbyte TEMAHIGHPASS = 10;
        public const sbyte TEMABANDPASS = 11;
        public const sbyte TEMABANDSTOP = 12;
        public const sbyte EMAWASHOUT = 13;
        public const sbyte DEMAWASHOUT = 14;
        public const sbyte TEMAWASHOUT = 15;
        // Public properties and respective private ones
        private sbyte _type = NONE;
        public sbyte type
            get
                return _type;
            set
                // Use values we had in the previous filter to avoid spike when we change filter type
                switch (_type)
                    case EMALOWPASS:
                        emaStoredHighPassValue = emaStoredLowPassValue;
                        demaStoredLowPassValue = emaStoredLowPassValue;
                        demaStoredHighPassValue = emaStoredLowPassValue;
                        temaStoredLowPassValue = emaStoredLowPassValue;
                        temaStoredHighPassValue = emaStoredLowPassValue;
                        break;
                    case EMAHIGHPASS:
                        emaStoredLowPassValue = emaStoredHighPassValue;
                        demaStoredLowPassValue = emaStoredHighPassValue;
                        demaStoredHighPassValue = emaStoredHighPassValue;
                        temaStoredLowPassValue = emaStoredHighPassValue;
                        temaStoredHighPassValue = emaStoredHighPassValue;
                        break;
                    case EMABANDPASS:
                    case EMABANDSTOP:
                    case EMAWASHOUT:
                        break;
                    case DEMALOWPASS:
                        emaStoredLowPassValue = demaStoredLowPassValue;
                        emaStoredHighPassValue = demaStoredLowPassValue;
                        demaStoredHighPassValue = demaStoredLowPassValue;
                        temaStoredLowPassValue = demaStoredLowPassValue;
                        temaStoredHighPassValue = demaStoredLowPassValue;
                        break;
                    case DEMAHIGHPASS:
                        emaStoredLowPassValue = demaStoredHighPassValue;
                        emaStoredHighPassValue = demaStoredHighPassValue;
                        demaStoredLowPassValue = demaStoredHighPassValue;
                        temaStoredLowPassValue = demaStoredHighPassValue;
                        temaStoredHighPassValue = demaStoredHighPassValue;
                        break;
                    case DEMABANDPASS:
                    case DEMABANDSTOP:
                    case DEMAWASHOUT:
                        break;
                    case TEMALOWPASS:
                        emaStoredLowPassValue = temaStoredLowPassValue;
                        emaStoredHighPassValue = temaStoredLowPassValue;
                        demaStoredLowPassValue = temaStoredLowPassValue;
                        demaStoredHighPassValue = temaStoredLowPassValue;
                        temaStoredHighPassValue = temaStoredLowPassValue;
                        break;
                    case TEMAHIGHPASS:
                        emaStoredLowPassValue = temaStoredHighPassValue;
                        emaStoredHighPassValue = temaStoredHighPassValue;
                        demaStoredLowPassValue = temaStoredHighPassValue;
                        demaStoredHighPassValue = temaStoredHighPassValue;
                        temaStoredLowPassValue = temaStoredHighPassValue;
                        break;
                    case TEMABANDPASS:
                    case TEMABANDSTOP:
                    case TEMAWASHOUT:
                        break;
                _type = value;
        // Private parameters
        private double alpha1 = 1;
        private double alpha2 = 1;
        public double emaStoredLowPassValue = 0;
        public double emaStoredHighPassValue = 0;
        private double demaStoredLowPassValue = 0;
        private double demaStoredHighPassValue = 0;
        private double temaStoredLowPassValue = 0;
        private double temaStoredHighPassValue = 0;
        // Class constructors
        public ClassFilter()
            _type = NONE;
            numberOfSamples(1, 1000);
        public ClassFilter(sbyte type_of_filter)
            _type = type_of_filter;
        public ClassFilter(sbyte type_of_filter, UInt16 numberOfSamples1, UInt16 numberOfSamples2)
            numberOfSamples(numberOfSamples1, numberOfSamples2);
        // Changing the number of samples used in the filter
        public void numberOfSamples(UInt16 numberOfSamples1, UInt16 numberOfSamples2)
            alpha1 = 2 / (1 + (double)numberOfSamples1);
            alpha2 = 2 / (1 + (double)numberOfSamples2);
        public double numberOfSamples1(int numberOfSamples1)
            return alpha1;
        public double numberOfSamples2(int numberOfSamples2)
            return alpha2;
        // Call filter depending on current type of filter
        public double filter(double value)
            switch (_type)
                case NONE: return value;
                case EMALOWPASS: return emaLowPass(value);
                case EMAHIGHPASS: return emaHighPass(value);
                case EMABANDPASS: return emaBandPass(value);
                case EMABANDSTOP: return emaBandStop(value);
                case DEMALOWPASS: return demaLowPass(value);
                case DEMAHIGHPASS: return demaHighPass(value);
                case DEMABANDPASS: return demaBandPass(value);
                case DEMABANDSTOP: return demaBandStop(value);
                case TEMALOWPASS: return temaLowPass(value);
                case TEMAHIGHPASS: return temaHighPass(value);
                case TEMABANDPASS: return temaBandPass(value);
                case TEMABANDSTOP: return temaBandStop(value);
                case EMAWASHOUT: return emaWashout(value);
                case DEMAWASHOUT: return demaWashout(value);
                case TEMAWASHOUT: return temaWashout(value);
                default: return value;
        // EMA based filters
        private double emaLowPass(double value)
            emaStoredLowPassValue += alpha1 * (value - emaStoredLowPassValue);
            return emaStoredLowPassValue;
        private double emaHighPass(double value) // HIGH = VALUE-LOW
            emaStoredHighPassValue += alpha2 * (value - emaStoredHighPassValue);
            return value - emaStoredHighPassValue;
        private double emaBandPass(double value) // BAND = LOW_FOR_HIGH - LOW
            return emaStoredHighPassValue - emaStoredLowPassValue;
        private double emaBandStop(double value) // STOP = VALUE - LOW_FOR_HIGH + LOW
            return value - (emaStoredHighPassValue - emaStoredLowPassValue);
        // DEMA based filters  DEMA = 2*EMA-EMA(EMA)
        private double demaLowPass(double value)
            demaStoredLowPassValue += alpha1 * (emaStoredLowPassValue - demaStoredLowPassValue);
            return 2 * emaStoredLowPassValue - demaStoredLowPassValue;
        private double demaHighPass(double value) // HIGH = VALUE-LOW
            demaStoredHighPassValue += alpha2 * (emaStoredHighPassValue - demaStoredHighPassValue);
            return value - (2 * emaStoredHighPassValue - demaStoredHighPassValue);
        private double demaBandPass(double value) // BAND = LOW_FOR_HIGH - LOW
            return 2 * (emaStoredHighPassValue -  emaStoredLowPassValue) - demaStoredHighPassValue  + demaStoredLowPassValue;
        private double demaBandStop(double value) // STOP = VALUE - LOW_FOR_HIGH + LOW
            return value - (2 * (emaStoredHighPassValue - emaStoredLowPassValue) - demaStoredHighPassValue + demaStoredLowPassValue);
        // TEMA based filter TEMA = 3*EMA - 3*EMA(EMA) + EMA(EMA(EMA))
        private double temaLowPass(double value)
            temaStoredLowPassValue += alpha1 * (demaStoredLowPassValue - temaStoredLowPassValue);
            return 3 * (emaStoredLowPassValue - demaStoredLowPassValue) + temaStoredLowPassValue;
        private double temaHighPass(double value) // HIGH = VALUE-LOW
            temaStoredHighPassValue += alpha2 * (demaStoredHighPassValue - temaStoredHighPassValue);
            return value - (3 * (emaStoredHighPassValue - demaStoredHighPassValue) + temaStoredHighPassValue);
        private double temaBandPass(double value) // BAND = LOW_FOR_HIGH - LOW
            return 3 * (emaStoredHighPassValue - demaStoredHighPassValue - emaStoredLowPassValue + demaStoredLowPassValue) + temaStoredHighPassValue - temaStoredLowPassValue;
        private double temaBandStop(double value) // STOP = VALUE - LOW_FOR_HIGH + LOW
            return value - (3 * (emaStoredHighPassValue - demaStoredHighPassValue - emaStoredLowPassValue + demaStoredLowPassValue) + temaStoredHighPassValue - temaStoredLowPassValue);
        // Washout filter
        public double emaWashout(double value)
            return emaLowPass(emaHighPass(value));
        public double demaWashout(double value)
            return demaLowPass(demaHighPass(value));
        public double temaWashout(double value)
            return temaLowPass(temaHighPass(value));
  7. pmvcda
    15,547Coins
    @BlazinH,
    I'm just enjoying myself.
    This is leisure (well, I might put a donation button on the program, had people saying they would donate, and I'm not an idiot.... I think:confused:).
    I'm not sure where I go with the software. The idea is not to replace SimTools.
    But,
    I have many ideas and I will put them in practice as time allows.
    I'm already working in a new program to replace the current interface.
    And I hope people like it. Might give some ideas for future updates in SimTools.
    Don't want to say much, not because I want to make mystery, but because I'm not sure when I have it ready to show or if it will work as I expect.
    The day I post the program, it will be already working, at least in a basic way. And yes, it will have direct input from games.
    Stay tuned!
  8. BlazinH
    16,671Coins
    Thanks pmvcda. It's been a while since I've been this excited about an announcement here so I'm really looking forward to seeing what you come up with :cool:. I'm mostly into racing so a 6dof has not been a priority for me thus far but since I have a lot of what is needed already its time to start one me thinks :p (rotational).
    I do love Simtools but I have a lot more left to share. :cheers
  9. SilentChill
    20,596Coins
    I'm getting the same error with latest build. Error no data from sim tools ?
  10. pmvcda
    15,547Coins
    Found the problem, making a new build.
  11. pmvcda
    15,547Coins
    Version 1.8.2
    Bug corrected (I think)
    Download in first post.
  12. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    Sorry about the error in bit rate of my other pics. I use arrows to test Asseto Corsa and I put hexapod interface over to change value. But, arrows does drive the car in asseto, but it also change the value of the last parameter I used in hexapod. Still, version 1.8.1 was not working at 10 bits.
    Version 1.8.2 does.
    Direct link to asseto corsa does work too, but I have to put the gain at 0.1 because of the too strong signal. Yaw with washout works really well. I will definitively test it more.
    Lock at lowest position uses the main gain. At 0.1, it does not go really far down.
  13. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    yes yes! you have it already. only "small" issue I see is that in "local mode" your center of gravity moves laterally and should move according to "local Platform" translations.
    If the Surge "lifts" the platform because of Pitch, the CoG should follow
    https://youtu.be/WmtAohWiYn4
    Am I right?
  14. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    erased
  15. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    The HPF brings back the platform but not the slider so it’s blocking the cue data
    Any solution how to overcome ?
  16. pmvcda
    15,547Coins
    I'm looking at it right now.
  17. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    @pmvcda , Can you see this Center of rotation issue here?
  18. pmvcda
    15,547Coins
    The axis representation is corrected in the last version.
    Or do you mean that rotation should be made around the point affected by translation?
    EDIT:
    Well it's around that point, but not on the axis.
  19. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    It can be it is my wrong usage of SimTools scaling which blocs the data and not the FLYpt slider/model discrepancy issue.
  20. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Sorry I missed this fix. Seems all fine in the last one.
    Congrats!
