24V Motor controller recommendation
Discussion in 'Motor actuators and drivers' started by cnupa4ka, Mar 17, 2019.
  1. cnupa4ka
    cnupa4ka Member
    385Coins
    Hi guys! Which controllers you will recommend to use for these motors? Thank you!
  2. BlazinH
    16,691Coins
    Sabertooth 2x32
  3. cnupa4ka
    cnupa4ka Member
    385Coins
    thanks mate. Do I need only one board for both? Also is it difficult for settings? Thanks! :)
  4. MarkusB
    4,215Coins
    Yes, you need one Sabertooth for both motors, plus an Arduino.
    And no, it is not difficult, because @BlazinH has created a fantastic tutorial.
  5. cnupa4ka
    cnupa4ka Member
    385Coins
    Markus, thanks my friend. Which arduino I have to order? Uno?
  6. MarkusB
    4,215Coins
    Yes, Arduino Uno is fine. Just have a look at the tutorial, which also explains the wiring and includes the required software.
  7. cnupa4ka
    cnupa4ka Member
    385Coins
    Is chinese clone works or I have to buy genuine?
  8. MarkusB
    4,215Coins
    I don't have experience with these clones. If they are not faulty, they should work I guess.
  9. BlazinH
    16,691Coins
    If you want to try on the cheap you can also use two IBT- 2 h-bridges. But their quality is generally poor and they are easy to damage. Sabertooth quality is top notch and have a rock solid warranty too.
  10. cnupa4ka
    cnupa4ka Member
    385Coins
    I think better Sabertooth :) I just ask is anybody had experiance with the arduino clones :) I have one clone for sim dash. Its working without issues :)
  11. BlazinH
    16,691Coins
    I don't use them but at least one commercial outfit uses them on their rigs. I've seen some driver issues since theirs is different and a few bad boards but other than that I think they're okay.
  12. cnupa4ka
    cnupa4ka Member
    385Coins
    Sabertooth Dual 2x32A where from can I buy it on English seller? Thanks.
  13. ghidossi
    ghidossi Member
    - 12Coins
    3DOF, Arduino
    hi, yes chinese clone are working well. I use it many time to build 3d printer without any issue
  14. yobuddy
    51,543Coins
  15. cnupa4ka
    cnupa4ka Member
    385Coins
  16. yobuddy
    51,543Coins
  17. cnupa4ka
    cnupa4ka Member
    385Coins
    I found Sabertooth Dual 60A 6V-30V Regenerative Motor Driver for £100
    How do u think is it good driver? Is it easy to setup?
  18. noorbeast
    153,926Coins
    +11,156 / 57 / -2
  19. My.stAr
    My.stAr Active Member
    Engineer
    1,065Coins
    DC motor
    If you use the Sabertooth 2x60 you will need to use batteries. There is no option to get rid of the regenerative current with resitors. Keep that in mind.
    Instead of an arduino you can use Kangaroo X2 Motion controllers. They are much easier to handle. And you can use encoders. It looks like yours motors have a brake. If you don't want to use the brake, you could use the shaft to mount the encoders. You can use the brakes with the Sabertooths controllers.
    I recently bought my Controllers here: https://www.robotshop.com/uk/
    You can also order the kangaroo x2 there.
    It's up to you, which way you want to go. Sabertooth 2x60 or 2x32 will work. Arduino and kangroo should also both work fine:)
  20. cnupa4ka
    cnupa4ka Member
    385Coins
    So my friend are you telling me that I cant use 2x60 with my pcu power supplies?! :(
