Hannibal's thread into DIY motion platform
Discussion in 'DIY Motion Simulator Projects' started by hannibal, Feb 15, 2019.
  1. hannibal
    hannibal Active Member
    4,490Coins
    is this your setup? thanks for sharing...
    so you have (2x) 12v batteries in series with (4x) 24v power supplies in parallel?
  2. Thanos
    Electronics Engineer
    2,854Coins
    Not unless he has 48v motors... you must place the batteries in parallel to the power supply.
    Also you should connect the batteries via relays to disconnect the batteries from the PSU if the PSU is off...
  3. hannibal
    4,490Coins
    yes.. batteries parallel to power supplies, thats what i meant! :)
    for relays, i was planning to follow @wannabeaflyer2 and have relays between motors and sabertooth, but you are saying we should have between Power supply and battery? i like to show you a sketch wiring diagram when i have it ready @Thanos ! :)
  4. hannibal
    4,490Coins
    it would be nice to hear you guys critique of my power...
    i still have to figure out what size batteries, and finalize the wiring sizes.
  5. hannibal
    4,490Coins
    just when i settled on going on direct shaft drive motors after seeing @CHEOPHUS design.. after reading more about going this route, im learning that people are adding gas pistons or pneumatic rods to offset the load...
    i happy chosen the 24V route... with my apartment environment, i am undecided for going the linear actuator route.... still hunting for a good motor for a NON linear actuator based 6Dof setup...
  6. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    3DOF, DC motor, Arduino, 6DOF
    For the batteries, I put a kill switch between the two batteries. It's simpler and it cuts the batteries from the system in one go.
  7. hannibal
    4,490Coins
    i need a huge throw switch? kill switch will have to handle 200A?
  8. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    Mine is rated 200 Amps.
  9. hannibal
    4,490Coins
    thank you. i posted a question on your thread! wow.. i really depend on ppl like you on this forum!
  10. wyoben
    wyoben New Member Gold Contributor
    USA
    86Coins
    Hannibal,
    The progress you are making looks good. I will definitely be following your build.
  11. hannibal
    4,490Coins
    thank you @wyoben it will be a slow build. im going to start off slow, im just enjoying the journey. im going i hope to complete 3 linear actuators and the power equipment. im pretty much following @wannabeaflyer2 @SilentChill and sixdegreesofflight. i am obssessed now.. i guess i have to go all the way.
    the only thing i worry about is the state of VR.. the upcoming headsets do not have sensors, so im not sure how thats going to unfold for motion cancellation..
  12. hannibal
    4,490Coins
    ordering linear actuator parts..
    learned something interesting about carbon fiber tubes!
  13. hannibal
    4,490Coins
    my two sim chairs have been collecting dust for the last 3 years. i will have to say RIP at some point when my 6DoF is developed.
    wont have the space. ill modify the custom built pedals for the 6Dof.. but my cyclic will most likely be not be part of the 6Dof project... good memories building. i just wish DCS had a glove for hand track, or just by camera hand tracked, using a hand controller and hotas just was cumbersome.
  14. hannibal
    4,490Coins
    currently learning about everyone's linear actuator builds...
    trying to understand the anti wobble ring problem and the fastening of hardware together..
    was able to see @SeatTime 's recommendation of "nutserts" to attach to the carbon fiber tube
    havent seen the most ideal way to attach the carbon tube to the ball screw.. research continues..
  15. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    Just to say. After reading SixDegreesOfFlight thread and the problem he had with anti-woble ring inside the carbon tube. I decide to not use any. My ballscrew's rod is free inside the tube (that sounded weird).
  16. hannibal
    4,490Coins
    ok thank you so much for clarifying what happens with the screw and the carbon tube.
    ok! i feel like every day i am trying to solve a different problem that everyone has done.
    i know one side of the screw has a thread hole.. im going to see if i can find one round metal ball and try to attach it
  17. hannibal
    4,490Coins
    looking to order the plates for the actuator..
    i see a few of you guys using aluminum
    sixdegreeofflight used 6mm aluminum plates..
    @Flymen used 7/16 aluminum plates
    im trying to figure out the plate material and size from @SilentChill and @wannabeaflyer2 's photos
    @Pierre Lalancette you are using aluminum i see as well
    so far i am seeing that acquiring 3/8" x 5" x 5" A36 steel plates are possible for me..
    not sure which is stronger A36 steel or aluminum...
    comments? :) :) :)
  18. Flymen
    Montreal, Canada
    2,432Coins
    DC motor, 6DOF
    3/8" x 5" x 5" aluminium plate is perfect !( no more than 3/8)
    the top one are 3'' x 4 1/2''
  19. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,034Coins
    Aluminium is lighter. Steel is stronger. Carbon is expensive.
  20. hannibal
    4,490Coins
    awesome. just ordered 20 plates... (extra 2 just in case i make a mistake..)
    appreciate the reply!!
    my next step to figure out what size bolts and rods.. i was able to figure out the obvious ones, like the M12 rod at the top of the carbon tube.. i think i will use 1/2 rod for the plates... it was 6mm bolts for the bearing sleeve.. i have home work to do!
