Started my scn5 cockpit
Discussion in 'DIY Motion Simulator Projects' started by njracer, Dec 22, 2008.
  1. njracer
    njracer Member
    2Coins
    whats up guys, i ordered a bunch of stuff today for my cockpit, pretty much everything i need i think? here is a run down of everything that i got so far, if i'm missing something let me know
    what i ordered so far:
    2x 150mm scn5 actuators with 5m cables
    8 heim joints
    2x 24v ac-dc power http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0125629218
    2x rs232 to rs485 converters http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0298949916
    2x serial cables
    pci serial card http://www.tigerdirect.com/applications ... Port%20DB9
    corbeau fx1 seat
    side mounts for the seat
    universal joint
    what i still need:
    something to hold the scn5's in place, some square tubing
    bolts, nuts, washers etc
    mount brackets
    threaded rods
    custom mount to attach the universal joint to the seat's mounts.
    i'm also gonna make a wooden rectangular frame, something similar to the cxc motion pro II
    if i'm missing anything to get the motion going let me know, i'm still a little confused about what is needed. i'll be sure to post pics as i go forward, can't wait :cheers:
    dave
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Mirai sells mounting brackets for the SCN5's that include the required screws for somewhere arounf $30 if I rememember correctly.
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    I wouldnt recommend a psu without overvoltage protection
    regards
  4. njracer
    njracer Member
    2Coins
  5. njracer
    njracer Member
    2Coins
    hey ego, it says on the ad of the psu that it has overload protection, is that the same thing?
  6. bvillersjr
    Ohio, USA
    438Coins
    Yes, they appear to be the same mounting brackets, although I'm not sure if the set you linked to includes the screws. Finding the screws for the bottom side mounts may be a little bit of a pain depending on your local hardware store.
  7. Mr Burns
    Mr Burns New Member
    0Coins
    Those are the same ones I use, I didn't have any problems so far.
  8. Mr Burns
    Mr Burns New Member
    0Coins
    Yes, those fit around the scn5. But they might not find on whatever you mount them on, so you might have to do some work on that. For me they were too short on the sides and I had to drill through the aluminum and put long screws through it and the bracket.
  9. njracer
    njracer Member
    2Coins
    well i FINALLY finished my simulator. :yippiee: its been a while but i can finally say its done. i've been at it all day. :lol: this thing is wicked. i love every minute of it. really takes sim racing to the next level. sweepers and fast chicanes are awesome in this thing. the cork screw @ leguna seca is taken to a new level with this seat, really crazy throwing you left and then right so fast, almost feels like the car is loose. its amazing. once again thanks to everyone for their help and continued support. special thanks to sirnoname, you are an awesome dude. and the community as a whole. i'm hoping once i learn how to make profiles, i'll share them with the community so we can all have something from each other. here are a few pics, its not completely finished, eventually i wanna put these through usb so i can hook them right up to the frame. i'm gonna put red plastic around the whole base with yellow inserts. then i'm gonna put a piece of clear plastic on the top section and put racing decals of the sims and gear i'm running. right now still testing all the fittings and making sure nothing gets loose. sim feels perfectly balanced and really throws me around good.
    heres a few pics. i'll post more updated pics when i complete the project, shouldn't be to much longer. i'll should be testing this thing like crazy from here on out :D
      63.7 KB
      1,097
      51.3 KB
      1,182
      46.1 KB
      1,191
      48.7 KB
      1,234
      37.3 KB
      1,148
      37.9 KB
      1,016
  10. RaceRay
    Hamburg, Germany
    23,884Coins
    Wow, looks really superb!
    From where where you got that pivot pivot?
    Nice idea to encapsulate the PSU within the hole frame with the PSU connector! :eek:
  11. Fahim
    Fahim Member
    553Coins
    Really nice simulator with 3 screen set up. I was wondering what is the max size you can have triple screen. Can you do 40inch x 3?
  12. njracer
    njracer Member
    2Coins
    cxc simulations uses 3 46 screens. they're using softTH though. i think with the matrox its 24 native. max settings are 5040x1024, something like that.
    i got the universal joint, the pivot joint @ http://www.mcmaster.com/#
    they have almost everything you'll ever need. its a grown ups toy store :D and shipping is REALLY fast.
    and thanks on the sim, took a while, still not done, but proud of it none the less :yippiee:
  13. Fahim
    Fahim Member
    553Coins
    Those two brackets on back of the seat where the actuators hang from. Did you make them yourself or can you buy these from a shop?
    I need 2.
  14. danknee
    danknee New Member
    0Coins
    Great execution. I wanted to second the question about your source for the two brackets on the back of the seat. Also, would you mind indicating the exact u-joint and the specific brackets you utilized with the joint? Thanks in advance.
  15. njracer
    njracer Member
    2Coins
    hey guys, i got the back brackets made at a local machine shop. they're a little expensive though, 375 for both of them total. the guy did one helluva job imo, but they are designed around the corbeau fx1 seat. they match the curve of the seat. if you guys are interested let me know, he kept all the dimensions on file so if anyone wanted i could have them made up and send them. they are expensive though, so idk, it'd be cheaper to just do the t-slot way prob, idk if it makes a difference having the bracket directly on the seat. i'm sure it helps somewhat as there is no play in there. i'm in the process of getting a furnace to melt metal, once i have it up and running i'm gonna try and make my own brackets, if all goes well i'll be sure to post them. will be a helluva lot cheaper to as i'll be making them myself, and they won't be hand made every set.
    as for the universal joint, i'll post back tomorrow, i have to look it up all the dimensions of everything, you gonna need the u-joint, the rod to link them, and the mount to but it in on both sides. i'll post everything tomorrow. its a little late, i'm a little drunk from celebrating july 4th. be sure to post tomorrow.
    dave
  16. egoexpress
    422Coins
    @Fahim
    You need a hardcase seat for such brackets. Afaics, your seat has a softcase...
    regards
  17. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Hi! M8!
    Very nice project you have there! Congrats!
    BTW, where did you get this info CXC used SoftTH from?
    Chris was very vague when I asked him about his triple screen.
    I don't even know if they use HD (720p) or full HD (1080p)?
    Cheers,
    MY
  18. CXCSimulations
    CXCSimulations Member
    - 9Coins
    I was? :)
    1080p BTW
  19. njracer
    njracer Member
    2Coins
    darren gangi from srt said it somewhere.
  20. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    You see?
    Again...
    Do you guys use SoftTH, or not? :?
