News Alluminium rig with prosimu 3dof kit
Discussion in 'DIY Motion Simulator Projects' started by Giorgio73, Oct 2, 2018.
  1. Giorgio73
    Giorgio73 Alluminium rig with prosimu 3dof kit
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Hy guys I have a static rig and I want to update with the scn6 actuators.
    Now the rig structure is on wood material.
    The next step is to convert this in alluminium structure.
    I want use some free software for the project, like my cad or similar.
    For the alluminium component I want to use motedis component.
    Is the cheaper alluminium component that I find in this moment.
  2. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    153,119Coins
    +11,117 / 56 / -2
  4. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Ok Noorbeast thanks for the information
  5. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    I decide to use the designer software FrameDesigner, free software anfd very easy to use
  6. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    I attached some picture of the progect
  7. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    For adjust the position of the pedals is possible move the red parts (angle regolation) and blu parts for front and rear regolation
    See attached
  8. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Same job for regolation of the steering wheel and the seat
    Now the next step is tu buy the alluminium components
    I want buy from Motedis in germany
    https://www.motedis.it/shop/
  9. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    The alluminium component camping from motedis and I building the new rig.
    I installed shims as feet to support the entire structure while waiting for the purchase of scn6 actuators
  10. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    some details of the pedal zone
    The pedal support can be move in all direction
    With the angolar square I fix the pedal
  11. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Steering wheel details
  12. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Now the support of the seat
  13. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    compared to the initial configuration I had to review the tv supports. in this way they are wider in order to receive the bracket that supports the actuators
  14. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    everything in place, only the actuators are missing, next step to buy the scn6
  15. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    after having designed with autocad I have made a support colleague for the actuators. Must be painting.
  16. noorbeast
    153,119Coins
    +11,117 / 56 / -2
    Have you mounted the actuators yet and do you have a video of your rig in action?
  17. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Not yet, before buying the actuators, since they are not cheap, I wanted to test simtoll with the f1 2018 plugin and assetto corsa competizione.
  18. jharps
    jharps New Member
    140Coins
    DC motor
    this looks sick!!
  19. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    sorry I did not understand, what seems sick. would you be so kind to explain yourself better?
  20. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Hy norbeast why you ask me this?
