Showroom 6DOF racing platform 12v dc 3.6kw arduino and mm/SMC3
Discussion in 'DIY Motion Simulator Projects' started by bruce stephen, May 3, 2016.
  1. DreamsOf2DOFw/TL
    DreamsOf2DOFw/TL New Member
    Solar Photovoltaic / LED Video Wall Foreman
    Sacramento
    169Coins
    Hey Bruce, do you still plan on using the e30-150 motors?
    Also, do you plan on uploading your enclosable carrier bearing design? Im curious to see it :cheers
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    yes i'll use the 150's to start. I can upgrade to the e30-400's if necessary. I've got a couple small revisions then i'll post more files for sure.
  3. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Any news about it? Would be nice to see your 6dof running!:cheers
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    soon... i received some more parts the other day but havent had any time off yet to work on it. the next part is the u joint mount for the bottom.
  5. Flymen
    Montreal, Canada
    2,432Coins
    DC motor, 6DOF
    hello, I wanted to know if the encoders work well, and if you use the controller Arduino uno? Because the encoders that I have worked well but the values are not stable!
    thanks
  6. lromaniuk
    lromaniuk bny
    Software Programmer
    Poland
    366Coins
    Recently I have experimented with STM32F1 (blue pill the same that Thanos is using on his Encoder2Position module) on my 3000 RPM servo with 2500 PPR encoder (which gives 10000 positions per revolution) and I recommend it. It works flawlessly! Not even a single miss. It is relatively easy to program - you can use arduino IDE. And it is really dirt cheap :)
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    I am using a rs232 connected to a kangaroo and sabertooth 2x60. The encoders work flawlessly
  8. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
  9. Gadget999
    11,983Coins
    was this using the 50 ppr encoders ?
    be interesting to see the difference with more resolution
    that is bad ass actuator :)
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    Ty for the kind words. Yes same motors although for the rear I'm thinking of using the e30-400 because of heat. But the motors are the same size except for length. This only requires longer spacers.
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    The older one is still using the 50ppr and the newest design used a 200 ppr. Although there were many more references points I could not see a noticable difference in movement.
  12. Gadget999
    11,983Coins
    Bruce - i may have asked this before but what do you think the budget for 6 actuators is ?
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
    my best guess is about $500 each so i would say $3000.us should build the actuators(including kangaroos and sabertooths). there are some ways of getting the bearings for free from igus and ordering the encoders and other items in bulk to save money. also shipping on some of the items may cost more or less. I am only about 4hours drive from Dimension Engineering so shipping is really cheap from them. the encoders ship from us also.
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    I also took advantage of an openbuilds free shipping weekend for the rails.
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    summer is almost over here so I will restart building on my sim when I can no longer stand the weather outside.
  16. Gadget999
    11,983Coins
    what is the cost of the motors ?
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    Prices are here
  18. Flymen
    Montreal, Canada
    2,432Coins
    DC motor, 6DOF
    Hey , my mine have 1250 ppr and each time is not stable with arduno uno ( skipe some number ) may be is my code who is not correct … which is yourss ?thanks
  19. Gadget999
    11,983Coins
    Try less pulses 360 is plenty enough
  20. lromaniuk
    lromaniuk bny
    Software Programmer
    Poland
    366Coins
    Hello! I'am using different micro controller (STM32F1) which has hardware timer with encoder interface. On Arduino you could try to use interrupts to read encoder pulses but still it might loose some pulses with 1250 PPR at high speeds.
