Tutorial How to convert your Frex SCM to SimTools - Updated
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MasterYoda, Feb 21, 2009.
  1. jmpapichulo
    jmpapichulo New Member
    Palma de Mallorca
    377Coins
    I made a profile for X-Sim is almost equal to the PURE G Frex Simconmotion. It is made using a Frex Simconmotion converted for use with software Force Profiler. If you want to try it here if I may put administrators. Greetings and thanks for the tutorial. :yes:
    I worked more on the parameters of the profile Pure G, and I think I have achieved a high level of equality with Pure G Frex software, there is only one value that can not be added and that it is the coup marches. Here I leave the new profile better calibrated. You enjoy it. :thbup:
    Also put my configuration scn5 actuators as coming from the house Frex configured, so it is like I have to use the profile Pure G 2. :yes:
  2. SimonME46
    SimonME46 New Member
    Canberra, ACT, Australia
    421Coins
    Thank you jmpapichulo, that is a significant improvement onf the profile I was using - this one has very substantial lateral and longitudinal force - actually, I was running out of travel in the physical environment of my seat!. I raised the pivot of the seat with 3 washers, and also added 90% travel limits on the lateral force for both actuators
    One curiosity - the off throttle forward movement is as great as the brake movement. Any suggestions on why this might be/how to moderate slightly?
  3. jmpapichulo
    Palma de Mallorca
    377Coins
    You just have to put on this Axis Calibration offset value 0 Baquet to focus on the two actuators, the same stopping distance in acceleration. I like to note that more braking, hence the delay center.
  4. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Assuming effect 25 is longitduninal g-force in rFactor, then use these two values to adjust either throttle or braking seperatly. (split maximum has to be checked)
    Rising one of the max values causes minimizing the actuator action, lowering a max value causes more actuator action.
    AGAIN: Please use the proper forum sections for game profile related issues! This thread concerns the hardware conversion only!
    Regards
  5. GX7RAY
    GX7RAY New Member
    Addicto to rFactor
    Pontevedra
    294Coins
    Well,conratulation for X-Sim software :clap: ,i am very happy with the results obtained. :D
    here photos
    With regard to setup, I utilize that of my friend jmpapichulo :thbup: ,since this setup I find it very wise for my flavor. :highfive:
    I am going to continue testing and already I counted them.Congratulation again. :cheers:
    Saludos Bye bye
  6. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Hi! M8!
    Thanks for the profile.
    Actually, there is a sub-forum to post them, you should move it to there:
    x-sim-profiles-f60.html
    BTW, is your adapter giving only 35o/s???
    Cheers,
    Me
  7. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Hey! Guys, whoever is converting their SCMs to X-Sim...
    Let's post some pictures of the converted sim here! I want to see them! :brows:
    Let's cerebrate freedom. :cheers:
  8. michael haertsch
    michael haertsch Member Gold Contributor
    - 206Coins
    Please Help
    I have the USB to RS232/UART TTL/RS485 Converter Modul insall
    And Windows Periferie Manager write:
    But the X-Sim 2.0 cant find the SNC5 Actuators.
    Another Pics from Install;
    Actuators connect to RS485;
    -green plugin to B
    -white to A
    -black to GND
    -red to VOD
    Is that correct?
    And Jumpers from PCB Converter Moduls,i have all plug testet and the actuators cant find.
    What i make Bad?
  9. egoexpress
    422Coins
    Try to switch green and white
    regards
  10. Ferrari_Man
    Ferrari_Man Member Gold Contributor
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    I am not sure but it looks like your jumpers on the converter are wrong. They should be on rs485 and not rs232.
    The only picture I could find was this one. This is how not to connect them.
  11. michael haertsch
    - 206Coins
    I have the Jumper Postion now for the Converter Modul;USB to RS232/UART TTL/RS485)and Cable connecting
    Made Website:
    http://www.nbglin.com/485.htm
    Green Cable = B
    Withe Cable= A
    Black Cable= GND
    Red Cable= VOD
    Warning, the red Cable(VOD) not mistake with the Cable (GND)
    Jumper connect from Pic works good;
  12. NathanAV
    NathanAV New Member
    0Coins
    Need help...
    I am at stage where I am connect my SCN5 using x-sim..and its work, I can slide and moving two SCN5..so from here how I bring to motion?..I am already copy plugin to rfactor and load rfactor profile..It's not working.. :? It's need force sender? What's a next move?Sorry, I am already digging all thread..but still no result :(
    By the way..It's need unplug and plug sometimes to detect SCN5 in x sim ..It's normal? or a converter problem?It is safe unplug and plug while PC powered ON?
    Regards
    Me
  13. RaceRay
    Hamburg, Germany
    23,884Coins
    Did u use the correct plugin?
    Take the dll in c:\programm files\X-Sim\other stuff\rFactor\ when you own rfactor v.1.255
    Try to deactive PnP scan in the profiler
    regards
    René
  14. NathanAV
    NathanAV New Member
    0Coins
    Yes It's done..I have warning.It's said my left and right actuator it's not connected..but I can slide and moving? Can somebody explain about force sender? I am just using 1 PC..Do I need Force sender?
  15. RaceRay
    Hamburg, Germany
    23,884Coins
    You have to start Force Sender AND Profiler. Select rFactor in the sender and click try send data. Press START in the Profiler. Now it should works.
    Here is the same solution described:
    nixim-simulator-t1490-40.html
  16. NathanAV
    NathanAV New Member
    0Coins
    Thanks Ray for fast response....I will give a try :D
  17. NathanAV
    NathanAV New Member
    0Coins
    Hi..I am hit a brick again :sos:
    I already follow some tutorial and on the edge bring to motion..I am loaded Masteryoda profile and start force sender..everything fine until I press big green Start button..and appear warning error opening comport 5 and 6?
    When I checked in math setup I can see the graphic is working in Rfactor..
    also I can slide and move actuator..But if I am press Start Button is came up warning error opening comport
    What wrong? Am I miss something?
  18. NathanAV
    NathanAV New Member
    0Coins
    Solved, by reinstalling X-sim :rofl:
  19. RaceRay
    Hamburg, Germany
    23,884Coins
  20. NathanAV
    NathanAV New Member
    0Coins
    Thanks for this community and help from friends,I am done converting to Xsim .I think I am enjoyed my X-sim and never going back to old setup :D
    I think my actuator will more secure with X-sim..in my old setup I hear beeping from actuator when I seat in idle..but now it's oke..no overload beeping sound again.. :mug1:
    Btw I am still noob in making profile, some profile I am testing in math setup it's moving beyond of end my actuator..I think it's not safety really appreciated if someone make a profile tutorial :clap:
    Sadly I can not running iracing because I have 1.2.0.0 version..force sender crashed, Any way I can run this version?
    Here a video comparison Oldsetup and X-sim setup using MasterYoda profile..It's very good..I like rumble in straight line but very slow when turning fast and not rough when hit bumpy track..Thanks Master.. :cheers:
    Old setup with Horz 4500 vert 4500 and speed 9000
    http://www.youtube.com/watch?v=YtiTb99Wvw4
    Xsim with MasterYoda profile with speed 12000 and accel 800
    http://www.youtube.com/watch?v=1WHuckHNjoQ
    I cannot running Rfactor with my MMG display attach..MMG detect as a comport..I crash Rf when I start a game..It's a plugin or comport problem?
