Lesson CHEAP CHINESE MONSTER MOTO CLONES AND PROBLEMS
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by SilentChill, Sep 12, 2016.
  1. Zed
    USA
    5,844Coins
    In doing the research to see if there was any benefit to cooling the JRKs from below (there is), I read the data sheet for the VNH2SP30 H-bridge that the JRK and Monstor Moto both use.
    (http://www.st.com/content/ccc/resou...df/jcr:content/translations/en.CD00043711.pdf)
    In there they discuss the thermal pads on the bottoms of the chip that are designed to remove the lion's share of the heat developed in the chips.
    I'm not in any way knocking the MM's but if you compare the circuit boards used in those with the JRK's you can see the Polulu takes full advantage of the thermal pads and vias the heat out to the bottom of the circuit board. The MM's do not.
    Cooling the VNH2SP30 through the plastic overmold with a heat sink and fan certainly helps, but the MM's probably need to have more care and attention paid to setting them up than the JRK's do even though their board area is probably greater (see the section on power dissipation vs. board area in the VNH2SP30 data sheet).
    Edit - @OZHEAT pointed out that MM's do indeed have thermal vias though not directly under the pads. They would be better if under the pads and filled with solder but better than not having them.
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    https://www.xsimulator.net/communit...cts-as-a-single-motor-driver-more-power.5482/
  3. Zed
    USA
    5,844Coins
    Yep. Pit wrote a great tutorial on paralleling them for more power. It's a way to use cheap MM's in higher power applications but it also adds boards, wiring, takes up space, and you generally would still need to cool them. And you can still have balance issues. It's not a perfect technique.
    And if you look at the last paragraph of what you quoted, I say that paralleling them is a way to get more power - exactly as Pit's tutorial explains how to do.
    You don't really say what you are replying to since all you do is quote me and add the link to Pit's tutorial, but I think that's it and I mentioned that but thanks for the link. It will probably benefit others.
    Edit - deleted part about MM's not having thermal vias since they do as @OZHEAT shows below.
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yes it replys directly to you just as intended. Its what happens when you press the "reply " button. You mention parallel. I was just pointing in the direction. Good day sir.
  5. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    @Zed
    Is this what you are looking for?
    MMS chips not attached.jpg SeatTime had a pic of a desoldered board.
  6. Zed
    USA
    5,844Coins
    @OZHEAT - yep, that is it exactly! Thanks! I had not seen those. So the MM's do have vias. Still not as many as the JRK's and not directly under the bridge pads, but they are indeed there. I'll correct my posts.
  7. Zed
    USA
    5,844Coins
    It's always pesky to delete the stuff you aren't commenting/replying to to make posts clear. I understand not taking the time to do that. Thanks for explaining how reply works, too. A proverbial wellspring of information! Good day to you.
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    Editing past posts for the sake of an argument.... Ok if that's your thing. I'm not sure what your intent is? Trolling the forum possibly? Everything you said has already been discussed here in great length. If you make a suggestion or bring up a subject that has already been solved or at least has a viable solution, please post a link so others can find the information. My purpose/intent for being here is not to re-discuss past issues or argue moot points. I can only repeat myself and regurgitate information so many times so occasionally you will only get a link. I am not sure why this would offend you? Furthermore, I would think someone who claims to do research would actually have some of the "research" equipment on hand to test. There are pics all over this forum of monsters without a chip showing the pads. I applaud your eagerness to contribute, it is what makes this place what it is..... A place to build and help others build DIY simulators.
  9. Mengxi
    Mengxi New Member
    Suresnes
    152Coins
    Beginner's question here:
    The starting current of my motor is 80A (rated current 20A).
    I wonder if it is safe to connect IBT_2 (43A) with the motor or the starting current would burn everything at the moment that the motor begins to move.
    Besides the unexpected behaviors of clone chips, theoretically.
    Thanks a lot!!
  10. Tim McGuire
    Canada
    2,209Coins
    3DOF, DC motor
    As long as you're not running your motors near stall during normal operation you should be fine. Look at page 6 of this document:
    https://www.mouser.com/ds/2/196/Infineon-BTN7970-DS-v01_01-en-785560.pdf
  11. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,065Coins
    The nature of motion sims means that the motors are running near stall for extended periods of time (every time the motor experiences a direction change, which is often).
    Run two IBT-2 in parallel and add active cooling to the chips.
    Also buy some spares as some chips may not reach the full performance stated and burn out.
  12. Mengxi
    Mengxi New Member
    Suresnes
    152Coins
  13. Tim McGuire
    Canada
    2,209Coins
    3DOF, DC motor
    True, the motor will consume stall current for a brief period of time during direction changes, but that's pulsed current, not continuous. It depends on how heavy your rig is in relation to how much load your motors are rated for, so we'd need specifics to give you a definite answer.
  14. Andrew Eccles
    Andrew Eccles aceinnz Gold Contributor
    New Zealand
    - 541Coins
    If you give the clones enough cooling - they seem to last ok. I've hacked an old intel CPU cooling fan. Keeps them nice and cool.
  15. SilentChill
    20,584Coins
    Has no effect if they are faulty when you buy them.
    If they work they work I have a few which still power my fans nearly 5 years on.
  16. Andrew Eccles
    New Zealand
    - 541Coins
    I just had a brand new faulty one - had a real strange problem - it drove the one motor fine, however, the other motor only worked well in one direction. It was after a recent rebuild to my sim. took a while to troubleshoot. Anyhow - I'm also adding to my pile and that one's on it :).
  17. SilentChill
    20,584Coins
    Yeah common issues, you could still use it as a single for something less stressing as one side is still working ok
  18. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    hi guys
    Just thought id mention that I purchased 4 MM's from Flux workshop on amazon 3 months ago. I only needed 3 for my smc3 half bridge that I'm using but thought id get all 4 that were available in stock at the time due to the failure rates that some members have seen. Now either I'm the luckiest member on here or the seller (Flux workshop) just sources good quality clones/copies or was just a good batch because all 4 are tested as per @SilentChill example video and 3 have been working for the last 3 months in my sim with no faults and temps no greater than 60 degrees. Not bad at only £8 each.
    Like I said may have been a complete fluke but I myself am not complaining.
