vthinsel
Assetto Corsa UDP (Consoles) - Manual plugin start 1.0
Assetto Corsa UDP plugin for consoles
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    vthinsel submitted a new resource:
    Assetto Corsa UDP (Consoles) - Assetto Corsa UDP plugin for consoles
  2. Leandro Kemp
    Brasil
    - 10Coins
    Hi.
    Already tried everything and could not make it work on my ps4.
    Could you tell what I should configure in the game and in the Assetto corsa UDP XML file? Pictures or video please.
    Thank you.
  3. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    nothing to configure in the game.
    xml content: put the IP@ of your PS4
  4. FrancescoRoberto
    FrancescoRoberto Member
    Italia
    92Coins
    I try to connect my playseat and the Assetto Corsa game for PS4 but i didn't success becuase after I completed the actions that you described, when the Game Engine start I find an error message. I think I execute the copy file and the edit of .dll with the PS4 IP.
    This is in attachment.
    May you help me.
    Best regards
  5. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Anyone with this problem?
    In the PS4 Assetto Corsa.
    When o change track or car the crash Simtools.
    I have already reinstalled plugin, patch, and replaces the ACPlugin.xml file.
    It did not work.
    Any idea what to do to fix it?
    Thank you.
  6. Leandro Kemp
    Brasil
    - 10Coins
    Error picture.
  7. FrancescoRoberto
    Italia
    92Coins
    The same error, I think.
    The problem is that I haven't any solution.
    I try to contact vthinsel
    153,914Coins
    +11,156 / 57 / -2
  9. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Hum. Strange. Probably a value goes out of normal range when changing lane (going to the pit lane you mean ?), and thus crash occurs.
    It is going to be difficult to debug this as I do not have the game anymore......
    A capture using the UDP tool I made could help somehow I guess but I cant promise anything.
  10. FrancescoRoberto
    Italia
    92Coins
    Sorry, but I don't try to make the test with a new pc setting to solve the crash problem.
    I'm going to try this next days.
    I hope to tell you good news.
  11. Leandro Kemp
    Brasil
    - 10Coins
    Change track or car. No pit lane.
  12. ludo22420
    ludo22420 Member
    206Coins
    I also can not run my simu with assetto corsa udp help please
  13. FrancescoRoberto
    Italia
    92Coins
    Sorry but all my tests failed.
    I've changed the local country and language, I've changed the car and the truck, I don't understand what do you mean about "pit lane".
    Anyway I don't succeed to start the playseat and Assetto Corsa.
    I attach the text that I watch on pc monitor when I start the plugin in Game manager.
    Is there a precise comands or actions sequence that I make to obtain the correct functioning? For example:
    1^ Start Assetto Corsa
    2^Start Game Engine
    3^Start Game Manager
    4^Start the plugin UDP in Game Manager
    5^Start the race
    Is there any setings that I need set up on AC menu before I start to play?
    Regards
  14. ludo22420
    ludo22420 Member
    206Coins
    the game to the udp already active there is no setting to do
  15. Leandro Kemp
    Brasil
    - 10Coins
    Simtools works normally.
    The error occurs when I change track or car in the game and I go to the track.
  16. FrancescoRoberto
    Italia
    92Coins
    Hello Lenadro,
    Happy New Year to everyone.
    I've red again the posts and I don't unaderstand why doesn't the playseat start?
    You said that I need start the game, chose the car and the truck, then start Game Engine and Game Manager.
    So I need start the plugin UDP and finally I start the race, but then I can't change car or truck otherwise the simtools crashes.
    Might I re-start all softwares to play with another car or truck?
    The problem is that my palyseat doesn't move in any situation and I don't know the reason.
    Another question:
    May I play at the same time with a wheel T300 RS and a controller, for example?
    I'd like to try to play with my wheel and change the gear by a DIY sequential shifter connect to the console with USB, like a controller.
    In the AC option menu, I can select the wheel:
    set up 1
    set up 2
    G29
    Or I can select different set up controller
    Is there a procedure to make it?
    Regards
  17. FrancescoRoberto
    Italia
    92Coins
    I'm loosing the hope about PS4 Assetto Corsa , because after a lot of tests I don't menage to start the palyseat.
    Is there anyone to help me.
    Leandro, Does you playseat work? Migth you explain to me How did you solve the probem?
    Regards
  18. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    Have you tried doing a capture to aid troubleshooting, as @vthinsel suggested using his UDP tool: https://www.xsimulator.net/community/threads/udp-record-and-playback-in-python.8686/
  19. FrancescoRoberto
    Italia
    92Coins
    I'm just an inability, I downloaded phyton but I did not understand what to do. I tried to start two applications, but the palyseat does not move. Perhaps the problem is related to the version of the game? Somebody help me.
    Thank you.
    See the attachments.
  20. FrancescoRoberto
    Italia
    92Coins
