Sabertooth, Kangaroo2, Encoder issues 2DOF
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by PaulB, Mar 14, 2018.
  1. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    Hi, Fairly new here. I wanted to build a 24v race sim, but so far ended up with a 12v bucking bronco and I need some help. I've have the rig built and running. I can tune everything, but when I run LFS or Assetto I don't get any consistent motion. The rig will center properly, momentarily work, then sometimes freeze start working again then kick to random angles.
    It's like someone is playing with a remote behind my back. Running 12v and game engine at 70% so it wont beat me up to much. Any ideas?
    153,938Coins
    +11,157 / 57 / -2
    Can you please post picture of all of your settings.
  3. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    try this for start up command
    1,start<10>1,home<10>1,units65535=6466<10>2,start<10>1,home<10>2,units65535=6435
    remove the <13> it isn't necessary
    you will want to also change the value for the baudrate to 115200 (serial tab in describe) then make it match in the game engine leave the sabertooth at 9600
    can you do a screenshot of the game engine interface tab?
  5. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    Is this what you need?
  6. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    I've changed the BitsPerSec to 115200 and removed the 13s
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    I believe you can change it to 16 bit. and the baudrate 115200. (same as it should be under serial tab in describe) :grin
  8. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    Working with 115200 and 16 output bit range, but now it homes near the second limit switch not centered?
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    hmm.... is set in describe, although I'm not sure where. I use the mechanical stops method of tuning the roo.
  10. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    Went back to 12 bit and everything works.
    Fired-up Assetto worked for a bit stuttered a couple of times then power supply shut off!?
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    what encoder/motor combo are you using? the 12 bit is interesting news. glad it is working on the software side now. GL with your hardware issues. What kind of PSU are you using?
  12. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    12 volt power supply till I can control the shaking HP DPS-600PB B two resistors
    100 count encoders on the motor end of 24 volt wheelchair motors. had 600s thought I was over running the 80,000 ps count.
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
    what brand/make is the encoder your using? does it have an index? If you don't mind, I dont mean to sound nosy:)
    EDIT are they the us digtial ones @Hoddem used?
  14. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    TY for posting. Less expensive alternatives are always welcome. I just like the digital alternative to pots. Similar results. I am getting the e2 200count encoders from us digital. I am getting them for $52 each plus shipping. I ordered them without the mounting tools( they sent them regardless ) and ordered 5 at once. So with the price break it stings a little less.
  16. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    Ended up being a bad 2x32. Sent back for repairs.
  17. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    Sending back the 2x32. 100% ok! :)
    Bought another 2x32 to compare. Same plugs works fine, so far. ?!
    Took the time to rebuild my rig. Same concept, new design.
    I'll post a video when I get it working
  18. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    So close. Finished the upgrade on the rig. got through tuning of the 2x32. Started Simtools and.....No luck. Won't center. Kind of strange. I turn on output Testing. #2 motor goes for a split sec and shuts off. Motor #1 centers with the limit switch properly. only #1 motor moves after that. Any ideas?
    Only a picture for now.
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
    Is it working in describe?
  20. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    Tried #2 motor says it might be in a runaway condition. I don't know what would cause that to only one motor.
