2DOF+Traction Loss Project
Discussion in 'DIY Motion Simulator Projects' started by phreezee, Feb 2, 2018.
  1. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Just came home from vacation and got my universal joint from Amazon and my power supply from Mouser in the mail.
    Not really part of my build, but I also got my Thrustmaster F1 wheel add-on :)
  2. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Pricing for my motor order didn't work out so I'm going to start an order with Kenny Deng on Alibaba.
    350W 24v 45Nm at 50rpm with 50:1 worm gear and 12mm diameter/50mm length double output shaft 90WZYJ08 x 6
    Goes for $600+$250 Shipping.
  3. Nick Moxley
    lets see the details.
  4. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Motor specs attached
  5. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    I'd appreciate some comments/advice around the shaft specs. I went with 12mm diameter, 50mm length double shaft with screw. There is an option for keyway though.
    Since the minimum order was for 5, I went with 6 so I would have a capability to go to 6dof in the future. The other option would be to build 2 rigs, one following the dofreality design and the other following the Simukit design ala momoclic. That would give me the best of both worlds and see what I prefer, heave vs sway.
  6. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    • Funny Funny x 2
  7. Nick Moxley
    • Funny Funny x 2
  8. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Been banging my head against the wall trying to decide on the shaft specifications until I stumbled upon this picture uploaded by @CLEOPHUS .
    Since I had ordered the 12mmx6.35 couplers, I thought I had to stick with 12mm shaft diameter. But with a center hole I could screw a bolt/screw with 12mm head and have a beefier/stronger shaft of 20mm.
    So I messaged Kenny Deng and asked for 2omm diameter, 70mm length, keyed, with center whole. Hopefully it's not too late.
  9. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Sweet, got a reply from Kenny pretty fast with an "OK". :grin
  10. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Might as well add a picture. Played a few races and I swear I'm a bit faster :)
  11. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    New shaft specs attached. Happy with the service and communication from Dakemotor.
  12. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Reaped the benefits of work decommissioning some old servers. I can run these in series to get 24V for my second rig.
    4x HPS-750RB A 12v 62.5A 750W
    3x HSTNS-PL14 12V 38.3A 460W
  13. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    Got my IBT_2's in. Funny how I instinctively bought 6 at the time when I was only planning on buying 3 motors... guess I'll have to buy more backups!
    Are other members just taking off the heatsink and reappling new thermal paste, or are they adding small heat sinks on the other side like with the moto monsters?
  14. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
  15. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    So I tried a motion simulator of the first time using iRacing on the VRX:
    I didn't think it was all that great lol. I felt the shifts and bumps, but it lacked any real sensation when turning.
    I think I want the maximum amount of roll I can get out of my rig and will have to design accordingly.
    I also tried the Vive at the Microsoft Store and LOVED it. I'm going to pre-order the Pro as soon as it is released.
  16. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    I try to Dbox style set up and felt the same as you. My SCN system seat shaker provided much more feedback especially an acceleration and breaking. I even felt my dc motor system held up well against the dbox feeback for 1/10 of the cost.
    I think you will find it is sway that will give you greatest turning sensation as opposed to roll.
    And welcome to another canadian. Im only 3.5 hours out of calgary.
  17. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    My Auras and amp came in from PartsExspress. They are bigger than I thought and I will have adjust the rig design to incorporate mounting plates at the 4 corners. Not sure if even I needed 4 and thought about using 2 in the home theatre. Anyone with an opinion one way or the other?
  18. noorbeast
    153,041Coins
    +11,116 / 56 / -2
    4 will let you set them up to simulate each wheel, which is preferential, but it is up to you.
  19. phreezee
    phreezee Member
    IT Guy
    Canada
    425Coins
    153,041Coins
    +11,116 / 56 / -2
