Showroom 6DOF racing platform 12v dc 3.6kw arduino and mm/SMC3
Discussion in 'DIY Motion Simulator Projects' started by bruce stephen, May 3, 2016.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
  2. wannabeaflyer2
    london uk
    8,341Coins
    Wow you guys really do push the benchmarks up a notch, dam just when I think 3D printing is only for light load bearing stuff bang you guys show otherwise ... that's really nice workmanship @bruce stephen another project that shows a great option for securing ballnut to the carbon or metal tube .... have to add that's an impressive exploded assembly as well ...Thanks for Posting ...keep em coming were loving this :) .... I always chime in with this my pet advice topic, and that is, Don't underestimate the forces these babies will produce in a runaway situation ( these generally happen during initial testing LOL ...ask me how I know Doh ) so make sure you have adjustable limit switches fitted ( which can be repositioned i.e shorter distance for testing and longer once you aim for max actuator travel) and be aware that these actuators carry a lot of momentum even after tripping each limit switch ... I will be adding some rubber bump stops inside the actuators to at least take out the worst of the over run travel ( if it occurs ) and to prevent metal to metal or metal to plastic clashes ...these bumpers should not reduce the overall travel by any great amount and may save damage to the ballnut .. Just a thought guys
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
  4. Fluke
    Fluke Member
    Stafford, United Kingdom
    822Coins
    Thanks for the files, this has given me the confidence to have a go at building an actuator.:thumbs
  5. Fluke
    Fluke Member
    822Coins
    Do you have a list of parts for your actuator and where you got them from? Thanks
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
    @Fluke The major components are 1605 or 1610. Ballscrew with bk12 bearing block. Gfl 25 bearing from IGUS. 25od x 22id x 500mm carbon tubing. 10x13 plumb coupler. 2 20 x 60 x 500 vslot rails. An e 30 150 motor from ebay. This list will grow there are a few things not added yet. Also pm me before you print because im updating these files almost daily. So make sure you have the most current iterations. Ill update thingi periodically.
  7. Fluke
    Fluke Member
    822Coins
  8. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    [QUOTE=" An e 30 150 motor from ebay. [/QUOTE]
    Hey Bruce, why not Bodine motors? Not fast/strong enough?
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    I took one apart to see but I dont think its an option. I love my bodines I have 9 of them. but they cannot handle the forces without damper help. don't get me wrong my rig runs great with many hours in between breaks. I just want more.. plus its fun to be building something. better addiction than drugs though its probably about as expensive.
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    got limit switch brackets drawn, printed and installed.
    I need to clean up the parts a little. i was printing them too fast/hot.
  11. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    What printer are you running? The design and execution looks great, are you finding that every time you print a part out you immediately see a way to improve it. I know I had a lot of rev changes on my build, but having it all in cad helps a lot.
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    LOL the worst part is the wait for the next version to print. I am using a Prusa i3 kit I purchased off ebay a few years ago. I upgraded the bed to pcb and e3d bodin printhead. I'm using solidworks. it updates my assemblies automatically I like that.
  13. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    @bruce stephen
    Good to see someone with a limit switches where you actually hit limits, it has time to do something like stop rather than having a limit at the very end where it it already has hit a hard stop.
    I also prefer using solidworks, a lot more user friendly especially if you don't want to take classes in cad drawing.
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    others have warned against over run and backdriving so hopefully this will help by letting me tune the position. I am thinking i may lengthen and thicken the wings that hit the limit switch.
    @Fluke I started to upload some of the parts that are working you can find them here: https://www.thingiverse.com/thing:2789060
  15. Fluke
    Fluke Member
    822Coins
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    I started printing the parts in PETG. It has about 10 times the strength of PLA so I am confident this will hold up to the stress. I ordered an encoder, sabertooth and kangaroo X2 they should be here this week. I should be testing soon.
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    More goodies showed up. Just need a few more components to begin testing.
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    It moves.. i should probably add grease to the ballnut. It was screaming a little. This is at 12 volt with the 1605 so its at about 1/4 of 75% of the max speed. The encoder is way easier than pots. I ordered a proper rs232 adapter (delink from dimension). Then i can connect to pc as what i have here won't work. The carbon shaft has been removed for safety.
  19. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    Congrats, you are now fully committed
  20. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yesterday afternoon after ordering the delink to connect to the kangaroo x2 I was looking at a job. well it just happened to be only 2 miles from micro center. I needed some more petg/black filament so i stopped in and also grabbed a ftdi/rs232. when I got home I plugged it in and it connected with DEScribe on the first try. so then after a couple more hours of messing around and picking/reading through @Hoddem's thread again (probably the tenth time, TY) and Dimension engineering docs, I got it to connect with Simtools. I struggled with the settings at first. The kangaroo wouldnt connect at 9600 and simtools would give me an interface error. so i upped the baud rate on the kangaroo in describe to 115200 but left the sabertooth at 9600(when i changed the sabertooth to anything else it didnt connect). The type of tune you do may make a difference and this could also have been the simtools connection issue. I used the teach tune the first time and it completed just fine but when it was done it split the lines, half positive numbers and half negative numbers IE: -1800 to 1800. Simtools didnt connect properly. I then used the physical stops tuning method as @Hoddem had explained. it completed without any issues and at the end it gave me position numbers 0 to 3600. I plugged the 3600 number into the units command in the simtools start up. I opened and started output testing and BOOM, MOTION! I used LFS and heave and got a very good response. Even at this early stage I can honestly say I will not be using pots anymore. In the next few weeks Ill be ordering more supplies and finishing up the design of the top and base mounting solutions. I feel like might have to sell a kidney to pay for this lol.
