4DOF by gigifux
Discussion in 'DIY Motion Simulator Projects' started by gigi, Feb 7, 2017.
  1. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    • Like Like x 5
  2. nicolasp
    nicolasp New Member
    são paulo, brazil
    23Coins
    Hi Gigi
    Can you please send me the 4dof ino code you used and the image of the schematic of the arduino, h bridges , pots and gearmotors
  3. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
  4. nicolasp
    nicolasp New Member
    são paulo, brazil
    23Coins
    but this ino code and this schematic is for 2 dof, i need for 4 dof
  5. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    use two interfaces. one for each pair of motors and you will have totally 4 motors
  6. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    i rewrite what i wrote to you in pm:
    "Every arduino board connected to the sabertooth board commands 2 motors.
    So you for each sabertooth you need one arduino card
    sabertooth 1 card that commands the motors 1 and 2 :
    Pin 8 of arduino card TX data to connect to S1 Sabertooth 1
    Pin A0 of Arduino card - input of feedback positioning from motor 1
    Pin A1 of Arduino card - input of feedback positioning from motor 2
    sabertooth 2 card that commands the motors 3 and 4
    Pin 10 of arduino card - TX data to connect to S1 Sabertooth 2
    Pin A2 of arduino card - input of feedback positioning from motor 3
    Pin A3 of arduino card - input of feedback positioning from motor 4
    In schema10.jpg you can see sabertooth 1 card connected to arduino 1 card
    To connect sabertooth 2 card to arduino card you must use Pin 10 instead Pin 8,
    Pin A2 and Pin A3 instead Pin A0 and Pin A1
    That's all"
    If you only see schematic and not read what i wrote you will never understand how to do
  7. nicolasp
    nicolasp New Member
    são paulo, brazil
    23Coins
    OK, thanks for the help
  8. Ch_Yasir_Mustafa
    Ch_Yasir_Mustafa New Member
    Pakistan
    154Coins
    Merry Christmas and belated congratulations to you brother, very nice project, indeed you are motivating me to build one of my own 4dof just like you here in Pakistan
  9. micma80
    micma80 Member
    548Coins
    [QUOTE = "Ch_Yasir_Mustafa, post: 168987, membro: 29095"] Buon Natale e congratulazioni in ritardo a te fratello, bel progetto, in effetti mi stai motivando a costruire uno dei miei 4dof proprio come te qui in Pakistan [/ QUOTE]
    Hi all, the 4dof of gigi fux is motivating many people, even I'm planning a 4dof with so many solutions taken from this sim, in January I order engines, power supplies and linear guides. electronics and iron for the structure already taken,
    Regards
    Micma
