Question Triple tv screens suggestions?
Discussion in 'New users start here - FAQ' started by Mku707, May 7, 2017.
  1. Mku707
    Mku707 New Member
    Philippines
    306Coins
    Hello! Im building a triple screen but i am not using monitor instead ill be using 49" or 55" but having hard time looking what brand and model is best for sim racing. The lag time and ect. Someone help me please? And is 60hz okay or do i really need a 120hz? But all tv screens even its 4k only supports 1080@60hz only a few model does but either so big or too expensive. Thanks!
  2. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    I use 39" 1080 tvs and while I'm sure there are better options I'm super happy with them over 3 27" monitors. Tvs are rca smart tvs just because that was what was on sale at the time
  3. gin69
    gin69 New Member
    331Coins
    I don´t know the exact model number, but there are some Sony 4K TV´s that support 1080 at 120hz.
  4. Nick Moxley
    17,056Coins
    The Sony Gina is referring to is likely the Sony X830C
    as shown here.
    http://ca.rtings.com/tv/reviews/sony/x830c
    PS
    0.2% 1080p @ 120Hz
    So as i said in your other thread, 1080 and 120hz is A VERY small % of unit on the market.
  5. Chris WirenutKv
    Chris WirenutKv New Member Gold Contributor
    New York
    - 271Coins
    3DOF, SCN6, Arduino
    Hello, I used three LG's 32 inch 1080's 60hz and they are fine. Cheap and effective. Having the right size, distance, and combination position can actually simulates a windshield.
  6. Chris WirenutKv
    New York
    - 271Coins
    3DOF, SCN6, Arduino
    Also maybe you should stay away from 4k since it requires lots of GPU. Right now I still believe its overkill until the prices drop. Put the money somewhere else on your build where its needed.
  7. Scoyyth1
    Scoyyth1 New Member
    Yarram
    245Coins
    Gday from down under.
    Mate I use 3x24 voc gaming monitors and they are great. If you set up your fov correctly it feels like a 1 to 1 car. Don' think like a woman bigger is not always better. Lol
  8. Jerry Atrick
    Sydney Australia
    1,414Coins
    4DOF
    Hi Mku707, in my opinion; cheaper and better pixel quality to use 3 1ms monitors than to go with Tv's that have a lag of 10 ms or more.
    Not to mention the weight, you will need a motor just for the TVs.:grin
    But the screen, whatever it is will certainly have some real estate!:popcorn
    Regards Jerry.
  9. Nick Moxley
    17,056Coins
    Last time i checked, sitting in my Car, I Cannot see both L+R mirrors at the same time, Therefor 1:1 it is not. Larger Screens offer this depth of immersion with FOV that smaller monitors will never be able to match not matter how fast said screen may be.
    So while you feel 24's are ideal, I Do Not. If we had quality 32" TV's/Monitors for a reasonable $$ that would be the happy middle ground.
  10. Scoyyth1
    Scoyyth1 New Member
    Yarram
    245Coins
    Gday Nick. You must have a head Luke a shark. Lol . Check out field of view vids on YouTube bud .
    To get proper immesion(180degre veiw)you must set up your monitors corretly. I have mine set like this.
    Center is 550mm from my eyes and the sides are set up at 45degres from that. No the outer edges of the outside monitors are at the end of my perifial vision. Witch gives you 180degre veiw. If you set your field of view correctly it dose not matter the size of monitors you have you move them closer or further away to get the same immesion.
    Yes my hands are close to my monitors but they are set correctly . I can't post vids yet but when I can I will show the importance of correct fov for full immesion.
    It was a $ thing for me $150 per 1080p 1ms 24 inch monitor @75htz or 4 to 500 for 32 inch tv' of around the same stats.
    Hmmmm 3 monitors for the price of 1 and they weigh 3 times as much as well.
    Imo bigger would probably be better but if its a $ thing like me do some research and you will find the same thing I did you don' have to have the bigget to be the best
    Cheers scotty
  11. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,065Coins
    Projector wins!
    Linky : http://www.projectimmersion.com/rig.php
    We can all go home now.
    Seriously though, buy the biggest triple screens that you can afford with a resolution that your computer can handle.
    No point going 4k or 120Hz if you have a potato graphics card. 60Hz is perfectly fine as higher refresh rates are mostly advantageous for FPS games as opposed to sim racing/ flight sims.
    Response times below 10ms will be completely fine again. With TV's you have to be careful about input lag though as some cheaper TV's can have input lag of around 200ms!!! The better TV's can offer what is called "gaming mode" which reduces input lag considerably but slightly increases response time.
    Isn't technology just fun!
    Either that or buy occulus/vive :D.
  12. Jerry Atrick
    Sydney Australia
    1,414Coins
    4DOF
    Hi Alexey, wow thats how you do it! (a curved projector):popcorn
    Jerry
  13. Nick Moxley
    17,056Coins
    Sweet setup Alexey, Seeing my hands on the projection would drive me Banannas. lol But ya that looks Bad A** i must say. Any way to prevent that issue ? like an Icarus setup or how is that drastically different to yours ? Single projection VS double i guess right ?
  14. Alexey
    Adelaide, Australia
    8,065Coins
    If you were really tricky you could have a cutout placed in front of the projector to block that part out.
    This isn't my setup if that what you were thinking.... But I can dream :D.
    2 or 3 projectors would be awesome though, as It would enable you to encompass your entire view to give a really great immersive experience.
  15. Nick Moxley
    17,056Coins
    Ah kk, thought you went and upgraded and didn't tell anyone.:p
    Yes the Icarus or w/e its called Wrap around screen multi projector setup looks Rather eye pleasing, the price however, Not so much. o_Oo_O:sos:grin
  16. gSeat
    gSeat Member
    usa
    910Coins
    This blows my mind, the whole thread, because yeh, wondering why using this tech instead of oculus/vive. However, many motion sim rides without 3d glasses, say Disney/Universal Studios, have used this style for years, and it looks and feels AMAZING for those that don't barf...like how AR wants to be, but is nowhere close to.
    @Alexey definitely curious, do you feel immersed fully, as if there...if focused on your race and stimuli, don't see why not. Cool stuff in this thread
  17. gSeat
    gSeat Member
    usa
    910Coins
    Right, the hands on screen, so long throw vs. short throw or angles with the screen/ceiling(projector)/body positioning? I'm definitely building for VR, but saw this thread caused wonder :D :D
