Tutorial Another ButtonBox (Arduino UNO)
Discussion in 'DIY peripherals' started by vthinsel, Apr 25, 2016.
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,039Coins
    Arduino, 4DOF
    I wanted to share with you my USB ButtonBox, which I made with Project Cars on PS4 in mind.
    The design is quite simple and requires few things:
    - An arduino UNO : be careful, as it must have the small Serial/USB AVR located on the top left part (with USB connector on the left). This is an Atmel Atmega16U2 or Atmega8U2 . Some clones do not have it.
    - Two I2C I/O extender to make a 8x8 matrix in order to have upto 64 buttons :) I'm using some cheap PCF8574
    - Push buttons, start button (all NO ,normally open)
    Key Concepts:
    • Turn the arduino to a keyboard : The ATmega16U2 chip (top left) on the Arduino board acts as a USB/serial interface allowing programming through USB. It runs a software like any AVR implemeting serial/USB conversion that can be updated through a special usb protocol called DFU (Device Firmware Update). Some other software will allow you to turn the ATmega16U2 into a USB HID (keyboard, mouse, or any Human Interface Device). Be careful: when USB HID code is uploaded on the ATmega16U2, programming the arduino becomes impossible unless you revert to the original ATmega16U2 code (or program using an AVRISP programmer) So program the arduino first, then the ATmega16U2 using procedure describded here and the firmware Arduino-keyboard-0.3.hex attached to this post.
    • Button matrix : the arduino has only a few pins available. Not enough to make a decent button box upto 64 buttons. Using an Arduino Mega would be overkill, so we need to be smart and use a matrix. A button is not attached to one pin but to two pins organised in row / column. To detect a keypress, we need to find the col/row making the code a bit longer than just checking the pin low/high state. We are using 2 I2C PCF8574 daisychained in order to make a 8x8matrix. Each PCF8574 is assigned a different I2C address resulting in two slave address. Only 4 wires (SDA/SCL/+5V/GND) are used on the arduino. Easy part :p
    The difficult part : soldering. Once the buttons are mounted, you need to implement the row/col matrix. To make things easier, I decided to have 8 columns to make wiring more straightforward. I started by wiring rows using unprotected wire, then I moved onto column soldering without making shortcuts by using some stripped insulant. Note the A0 jumper on rows .
    The code also implements a keypress repeat : leave a button pressed for 400ms and it will be repeated quickly every 30 millisec
    Steps:
    - I glued a millimeter paper onto 3mm plywood and made some holes with a dremel. Then drill the proper pushbutton diameter and mount all buttons (apply a 3M carbon look before if you need). Align all buttons connectors to make soldering more easy.
    - Implement the matrix as describded earlier
    - Upload arduino sketch
    - Program ATmega16U2
    - Done
    Maybe I'll rework the sketch to avoid using I2C extenders, as you may not neet 64 buttons, like in my example (8 col / 4 rows)
    Works great with PCars on PS4, but not with Dirt Rally as it doesn't support (yet.. I hope) additionals USB keyboards
    Enjoy !
  2. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
  3. vthinsel
    FRANCE
    6,039Coins
    Arduino, 4DOF
    Yes, but the approach is different here. I use an arduino uno and I2C extenders which I had in my stock :p
    Consoles are not very friendly with encoders and switches; only push buttons here.
    As mentionned in the post you refer to, the most obvious choice is to go for teensy. TIMTOWTDI
  4. RacingMat
    21,052Coins
  5. vthinsel
    FRANCE
    6,039Coins
    Arduino, 4DOF
    Indeed. Excellent value/money. Got mine for ali. Used them to drive a LCD through I2C also: 2 wires instead of 8. Works very nicely.
  6. TOPMO3
    TOPMO3 Active Member
    Russia
    896Coins
    Great work, @vthinsel ! :thumbs
    just my 2 c
    if you use ON-OFF-ON spring return switches (ie those not locking but returning to central position after releasing them) you can wire them as usual buttons in your matrix, because technically they are 2 push buttons in one case
    Almost the same about encoders. Of course you need to process them differently in your sketch, but from PC point of view they also act as buttons - one for CCW and other for CW rotation
  7. vthinsel
    FRANCE
    6,039Coins
    Arduino, 4DOF
    Thanks. You make me realize this is what I should have done for some of the switches : 1 switch instead of 2 buttons to move seat position front/back for example. Even no code change in that case.
  8. HecticZA
    HecticZA New Member
    South Africa
    189Coins
    I'm very interested in this project for the same reason you did it (PS4/ PCars 2)
    I have no knowledge regarding Arduino . I yesterday bough a pro mini, Nano and Uno because I did not know what I needed.
    I today ordered some On Off On momentary toggle switches and some momentary push button switches, but it will take a week to arrive .
    Would you mind if I contact you for some help regarding this project or should I rather post questions in this thread?
  9. HecticZA
    HecticZA New Member
    South Africa
    189Coins
    I see now that this is an old post.
  10. vthinsel
    FRANCE
    6,039Coins
    Arduino, 4DOF
    So what ? :p
    The older a post gets, the better it becomes, like good wine .... and I'm not aware of expiry date on threads ;)
    You also need to order I2C extender as shown in the picture. Then time and patience will become your friend. This project is not the simplest to start with, but you can give it a chance.
    Good luck !
  11. HecticZA
    HecticZA New Member
    South Africa
    189Coins
    LoL, no I thought that the OP would't be around any more to take questions or give advice.
    So glad to see you are still active.
    I will see if I can find the extender. and also read a bit more about the process.
  12. Andi4x4
    Andi4x4 New Member
    isle of man
    211Coins
    Hi Guys,
    Sorry to resurrect this thread, but, I'm just about to embark on this project and need to know if I need to install libraries for the I2C extenders or will they work directly from the sketch in the download file.
    Thanks guys !
  13. Andi4x4
    Andi4x4 New Member
    isle of man
    211Coins
    Hi Guys,
    Sorry to resurrect this thread, but, I'm just about to embark on this project and need to know if I need to install libraries for the extenders or will they work directly from the sketch ?
    Thanks guys !
  14. Andi4x4
    Andi4x4 New Member
    isle of man
    211Coins
    Sorry for the double post - first one didn't appear to show til I posted the second !
  15. vthinsel
    FRANCE
    6,039Coins
    Arduino, 4DOF
    Check the sketch for dependencies, or try compiling it :):
    #include <Wire.h>
    #include <pcf8574.h>
  16. Andi4x4
    Andi4x4 New Member
    isle of man
    211Coins
    Hi vthinsel,
    I haven't tried uploading the sketch yet, but, those two lines of code are present in the sketch. Just wondered if there was anything else I needed to include as I had to install a l2C library to use a LCD on another project.
    Will give it a go as it is to start with. Will it work as a keyboard before I flash the ATmega for testing purposes ?
  17. Andi4x4
    Andi4x4 New Member
    isle of man
    211Coins
    Ok, uploaded sketch to Arduino UnoR3 and got a "missing library pcf8574" so downloaded one from internet.
    Now getting the following error message when I try to verify/upload -
    (sorry guys, I am a complete novice with Arduino and code so any help gratefully received ! )
    Code:
    Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
    C:\Users\laptop\AppData\Local\Temp\arduino_modified_sketch_135813\PS4_ButtonBox.ino: In function 'void setup()':
    PS4_ButtonBox:172: error: 'class PCF8574' has no member named 'write8'
       PCF_COL.write8(0xff);  //Pull high
    PS4_ButtonBox:173: error: 'class PCF8574' has no member named 'write8'
       PCF_ROW.write8(0xff);  //Pull high
    C:\Users\laptop\AppData\Local\Temp\arduino_modified_sketch_135813\PS4_ButtonBox.ino: In function 'void loop()':
    PS4_ButtonBox:186: error: 'class PCF8574' has no member named 'write8'
         PCF_COL.write8(~hex_data[r]);
    PS4_ButtonBox:187: error: 'class PCF8574' has no member named 'read8'
         uint8_t valueCOL = ~PCF_COL.read8();
    PS4_ButtonBox:188: error: 'class PCF8574' has no member named 'read8'
         uint8_t valueROW = ~PCF_ROW.read8();
    exit status 1
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
  18. Andi4x4
    Andi4x4 New Member
    isle of man
    211Coins
    Finally !
    Got it sorted - the PCF8574 library I had was not suitable, so, a couple of hours spent trawling the internet eventually yielded one that did, then issues with the Atmel Flip flash software slowed me down another couple of hours.
    Now, however, just over 4 hours later, it is all working !
    Yay !
    Button box construction is well under way - box is drilled, carbon effect vinyl applied, switches fitted - just gotta solder it all up !
    Will take some pics and start a separate thread for that in the appropriate place !
    But now - well deserved Bed Time !
  19. marc burns
    marc burns New Member
    illinois
    233Coins
    Do i still need 10k resistors for this project?????
  20. vthinsel
    FRANCE
    6,039Coins
    Arduino, 4DOF
    There are no resistors in this design..
