My Sim Cockpit [2dof 24v]
Discussion in 'DIY Motion Simulator Projects' started by dedraro, Dec 3, 2016.
  1. ferslash
    ferslash Active Member
    4,798Coins
    woow, that is a grate beautifull problem.... motors with too much torque... it is music :D
    - i hope your shaft cranks for motors works.... it would be just grate if they do... i cant not make aluminium parts, but printings its way easier.
    best regards... keep posting
    fer
    • Optimistic Optimistic x 1
  2. dedraro
    dedraro Active Member
    105Coins
    Guys I'm doing other tests, unfortunately when I go with "PWMmax" values above 170, the sabertooth stops, can it be too much power? What parameters could I adjust?
    In description i have everything stock, i did not touch anything.
  3. Pit
    30,480Coins
    hi, did you solve the issue?
  4. dedraro
    105Coins
    I solved it thanks, not because I had the trigger at the maximum and gave 30v XD
    Unfortunately, I'm slowly working on the work but soon I'll have some update.
  5. dedraro
    105Coins
    Finally finished everything and found the right setup, fully satisfied with these motors, thanks to Wanegain for all the help !!
    Unfortunately the printed levers broke after some tests, I passed to the old aluminum, also reduced the lever of 20mm.
    Mounted 80mm fans under the motors and heatsinks on the end, so do not exceed 45/50 degrees, even after many laps on the Nurburgring :D
    I'm already thinking about TL, maybe with old 120W motors :D
  6. Francisco Junior
    Francisco Junior Member
    Curitiba - Brasil
    285Coins
    Wow .... fantastic sim.
    What happened to the old engines? Were they not strong enough to move the structure or overheated?
  7. dedraro
    105Coins
    The old engines were powerful enough, they heated up a lot, but this unfortunately I broke the shaft of one of the two, I think for the overweight with me, seat, seat structure and 3 bass shaker I think they abound abundantly 100kg
    However here is a video of the new system running! :D
  8. Francisco Junior
    Curitiba - Brasil
    285Coins
    very cool !!!
  9. Tiromancino34
    Tiromancino34 3dof traction Loss made in Italy
    Rimini
    498Coins
    bello hai fatto un buon lavoro che mi piace perché è molto cauto nei dettagli
  10. Limongi
    Limongi Member
    Vancouver, Canada
    - 7Coins
    Really like the choices you made along the way and it's exciting to see a high power 2DOF. I like the monitor "shade" at the top of the screens, what did you use for that ?
  11. dedraro
    105Coins
    I do not know the exact name, it is corrugated plastic, like cardboard, I bought for some euros in a local store.
  12. Limongi
    Limongi Member
    Vancouver, Canada
    - 7Coins
    Cool, we have a brand name Coroplast here used for signs and packaging, very useful stuff.
  13. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    I really like your work, congratulations
  14. dedraro
    105Coins
    Thanks, I'm planning the 3dof, soon with many upgrades!
