Seattime's CNC Router build
Discussion in 'DIY Motion Simulator Projects' started by SeatTime, Jul 15, 2017.
  1. SeatTime
    As requested by @noorbeast and to not throw too much stuff into my project thread I have started a thread for my DIY CNC.
    I have decided to go with a Fixed Gantry design and a frame made mostly of steel. Sort of a very much cut down version of what this guy built.
    Not much else to talk about at this time (as for most of my projects - waiting for stuff to turn up) - stay tuned.
    Placed it here as it is sort of project related :think.
    • Like Like x 8
  2. SeatTime
    Parts are slowly turning up :). Think I have enough now to start building the steel frame. Basically a 3D printer on steroids.
  3. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    What are you going to use as a spindle? I've seen wood routers with metal cutting bits attached used in some DIY setups.
  4. SeatTime
    I'm just going to use the wood router that I already own to begin with. Will see how that goes before investing in a specific CNC spindle. I have a 3D printer coming, which will help in building a few bespoked parts.
  5. SeatTime
    Started on the CNC steel frame - I use a mirror to ensure alignment. FI. Base will only be half the size of the shown 'T'. First corner built this way, as it makes it easier to get it straight/flat.
  6. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    Great project !
  7. matthew loomis
    matthew loomis Member
    rochester,ny
    603Coins
    I see you plan on using a router. But I was wondering if you might already have the stuff around to make the spindle as well out of a dc motor? Is it something you considered?
  8. SeatTime
    No - my plan is to go with a inverter driven water cooled AC spindle - likely 1.5KW. Similar to this - http://www.ebay.com.au/itm/1500W-1-...pe-/332190727417?_trksid=p2385738.m2548.l4275 You need high speed and a bit of torque for a usable CNC spindle :). Unfortunately a DC driven spindle would just be a toy.
  9. matthew loomis
    rochester,ny
    603Coins
    That is much larger :eek:. It looks like it's controlled with a vfd. Still looks right up your alley. Having a real cnc will be a huge advantage like the 3d printer. Enjoy.
  10. SeatTime
    It might be small, but it will pack a punch :). Build ticks along...
  11. SilentChill
    20,596Coins
    Nice work @SeatTime
    Is that the plan for your new platform drawn on the wood underneath ??
  12. Alexey
    Adelaide, Australia
    8,066Coins
    I'm so jelly
  13. SeatTime
    Yes it will form part of the mould. Two images back you can see part of the mould sitting on a mylar sheet.
  14. SilentChill
    20,596Coins
    You're gifted mate to be able to put your hand to all this :)
