Pillowsack's First Motion Sim
Discussion in 'DIY Motion Simulator Projects' started by pillowsack, Feb 22, 2017.
  1. pillowsack
    pillowsack New Member Gold Contributor
    Programmer
    Vancouver, WA, USA
    371Coins
    First time builder here looking for guidance and places to start for planning and ultimately building a motion sim. While I would love to go all out and do a 6dof sim, I am wondering if it would be better to cut my teeth on a 2dof sim.
    I am familiar with SketchUp and will be drawing up something there. I already have designed and ordered 80/20 for my first stationary cockpit. I will live with that while I plan a full motion sim.
    Would love some introductions from anyone and any starting points that you can offer.
  2. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    Hello easiest is the seat mover . that requires a pivot point usualy a universal joint (ideally 2 flanged) unless you can weld yourself see in marketplace for "double flanged military universal joint".
    you would need 2 motors for basic motion of the seat . the easiest is SNC5 (more expensive) or 12 volt DC motors with JRK polulu as controller . Cheapest than JRK controller would be Arduino with monster moto or sabertooth . The disadvanteage of Arduino is to have some elementary skills with the codes and Arduino . advantage of Arduino is the amount of output (up to 3 motors) whereas only one motor for JRK
    Now with this in mind go check the FAQ with those elementary guidelines
    good read !
  3. pillowsack
    Programmer
    Vancouver, WA, USA
    371Coins
    I was thinking that might be a good starting point. I have an Arduino R3 and handful RC servos (RCs being my other money pit).
    I am trying to follow @eaorobbie and his code and settings but feels like it's incomplete or I am missing something as I am not getting any movement from my servos from game or output testing.
  4. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    game have to be patched
    for one thing
    game manager should turn green when connected to game engine
  5. pillowsack
    Programmer
    Vancouver, WA, USA
    371Coins
    I am trying to use output testing in game engine. Settings and sketch are attached.
    FYI, I do have a patched game (american truck sim) and see values change in the tuning center.
    153,914Coins
    +11,154 / 57 / -2
    If you are using SimTools 2 in the Interface Settings change <Axis1> to <Axis1a> and Axis2> to <Axis2a>
  7. pillowsack
    Programmer
    Vancouver, WA, USA
    371Coins
    I just tried that (found mixed variables concerning axises and noticed timestamps of posts would refer to previous versions of SimTools) and was coming to post!
    Thanks for the confirmation!
  8. pillowsack
    Programmer
    Vancouver, WA, USA
    371Coins
    While this isn't motion enabled at all, I wanted to post up some progress photos of static rig in it's phase 1 configuration. Subsequent phases will grow from a 2dof to 6dof.
    I still have the steering column to do but that will have to wait since I just sent my Fanatec wheel base out for repair. Otherwise she feels great. Seat is bit too narrow for my frame but I get used to it after sitting for awhile.
    First time using 80/20, cutting metal, and tapping threads but it all turned out very well so far and is super sturdy.
    Phase 2 of this rig will probably have a subframe with a pivot in the CoG and 2 worm gear motors at the back.
    Phase 3 is too complex at this point to even think about other than taking the feet off and plopping it down on top of a stewart platform lol.
  9. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    my first rig was something similar to that although not with 80/20. i made a platform and clamped it to it. the platform was connected to frex actuators in the corners but it depends on your budget. it was pretty straight forward though.
  10. Nick Moxley
    Nice start, Tho I hope there's more pedal support's being added at some point ;)
  11. dualclick76
    dualclick76 Active Member
    italia
    19Coins
    I really like the work done so far, I really like the indicheresti seat where you bought it?
  12. pillowsack
    Programmer
    Vancouver, WA, USA
    371Coins
    Amazon special. Whatever was available for Prime Shipping :D.
    Those pivots clamp down pretty hard. I can press on that brake pedal with all that I can muster and it doesn't budge. Once I torqued down every joint, it became rock solid. Was weary at first but now I have 100% faith in the rigidity. I'm 300lb+ guy so I definitely put it to the test.
  13. pillowsack
    Programmer
    Vancouver, WA, USA
    371Coins
    Still no motion yet but phase 1 is complete! I will put a few laps on it and see where any weak points are but so far feels really rigid.
    Phase 1.5 will happen over the weekend with some bass shakers. :D
    P1010193.JPG P1010194.JPG P1010195.JPG P1010196.JPG P1010197.JPG P1010198.JPG P1010199.JPG P1010200.JPG P1010201.JPG P1010202.JPG P1010203.JPG P1010204.JPG P1010205.JPG
  14. bodgy
    bodgy Member
    Australia
    86Coins
    Nice work. Love the look of these 80/20 rigs. Makes mine look so... bodgy.
  15. pillowsack
    Programmer
    Vancouver, WA, USA
    371Coins
    Function over looks is usually my motto. Can always improve the looks after it is tuned.
  16. bodgy
    bodgy Member
    Australia
    86Coins
    I like to get to the finish early, just ask my missus!
