My simulator 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by kwak, Jan 17, 2017.
  1. kwak
    kwak Member
    - 324Coins
    Here is my home simulator;)
    Thank you to the HSSC team for their valuable help;)[​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    Nice project!
    Maybe you can describe what parts you are using (electronics cards, power supply, etc...)
  3. lilted86
    lilted86 Member
    Malaysia
    489Coins
    nice..gudluck with the project!..can wait to see it finish
  4. kwak
    kwak Member
    - 324Coins
    I use 120w engines with a sabertooth 2x32 and a 24v power supply
  5. kwak
    kwak Member
    - 324Coins
    I would make a video as the system will be functional
  6. kwak
    kwak Member
    - 324Coins
    I have problems with Simtools V2 in local gamemanger remains Not Connected I test on the demo version on LFS
    153,890Coins
    +11,154 / 57 / -2
    Please post pictures of your your Interface and Axis settings, you have to define the grouping, which in most cases will be a, like this <Axis1a>
  8. lilted86
    lilted86 Member
    Malaysia
    489Coins
    what game you plan to use with the simtool 2.0?...you need to download the specific plugin..you also can test the cockpit without connect to the game...read the documentation on how to do so
  9. obobo
    obobo Active Member
    1,323Coins
    I find that the use of agglomerate is not sensible, because very fragile.
    The seat of renault espace 3 is well found, I no longer mine is true
    It lacks reinforcements to hold your planks together, otherwise they will break at the screws.
  10. kwak
    kwak Member
    - 324Coins
    The simulator goes on test I have added the a on the axes
  11. kwak
    kwak Member
    - 324Coins
    For now I want to test with LFS the plug-in is default in game manager?
  12. obobo
    obobo Active Member
    1,323Coins
    Moreover, your engine squares are too fine, you will have to reinforce them to avoid that twists.
    You did not put your engines in the same plane. You laugh at having strange movements in operation.
  13. kwak
    kwak Member
    - 324Coins
    Comment ça ?
  14. Pit
    30,510Coins
    I assume you have LFS already installed, so there is nothing more to do only to choose the game LFS from the drop down menu. BTW LFS is patched by default.
    PS: nice build. I like these DIY builds (also) with parts of recycled material, simple but nicely designed. :cheers
  15. kwak
    kwak Member
    - 324Coins
    Game manager remains in not connected
  16. Pit
    30,510Coins
    please can you upload any screenshots of all your settings?
  17. obobo
    obobo Active Member
    1,323Coins
    tes moteurs sont à 90° l'un par rapport à l'autre
    The motors are at 90 ° to each other
  18. kwak
    kwak Member
    - 324Coins
    Yes it is not a problem of engine because in test they walk
    153,890Coins
    +11,154 / 57 / -2
  20. kwak
    kwak Member
    - 324Coins
