SimTools v2 - Remote Profiler v1.1
Live Game Tuning
  1. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Ok @yobuddy I found the problem, let me try to explain so someone could try to replicate it.
    I have the same issues on two different PCs where I tested it to be sure it wasn't one PC problem.
    I tested on Windows 10 and on Windows 7
    Let's start!
    After enabling remote profiling (!!!) and setting the IP in game manager, I launched the Profiler from the remote PC. It says to be "OFF" (RED) but actually it isn't. Accidentally I moved one slider in the Remote Profiler and found that the value changed in Game Manager too.
    The problem is that the Profiler just works in "set" and not in "get". It doesn't read values from Game Manager but it can set them. The problem is that it starts with all values at 0 (zero), so as soon as you touch one slider in the remote profiler, you reset all the other values in the G.M.
    The other big problem is that it doesn't show what profile is working on, but it changes the values of the last selected in the Game Manager, so if had Default selected (and not Assetto Corsa) it would change those values.
    All these problems don't appear if the profiler runs from the same PC. Here you can see the selected profile, and the profiler works in get and set.
  2. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hello...
    currently this SimTools 2.0 Remote Profile it is only compatible with Windows devices.
    It can be used on the same PC where SimTools is already installed or only on different devices?
    And also... we will soon have a Android version?
  3. Blame73
    8,305Coins
    It also works on the same Windows PC.
    As soon as we got the framework someone could write an interface for Android, I think I'll code one for browsers, so that could be accessible from anywhere
    • Like Like x 5
  4. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Great news this :thumbs
    We look forward to future developments!
  5. yobuddy
    51,234Coins
    Sweet!
  6. obobo
    obobo Active Member
    1,323Coins
    if it's possible to use an android tablet directly with browser, it's really cool and usefull
    • Agree Agree x 3
  7. yobuddy
    51,234Coins
    • Optimistic Optimistic x 1
  8. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Thanks for the new SimTools 2.0 - Remote Profiler v1.1 update.
    Also for this software, how we should proceed with its installation?
    Download the 1.1 update and simply overwrite the 1.0 version?
  9. yobuddy
    51,234Coins
    @Doctor Kruntz,
    SimTools 2.0 - Remote Profiler is just an exe file.
    There is nothing to install buddy!
  10. bodgy
    bodgy Member
    Australia
    86Coins
    If you have an android tab you could run the profiler on another PC on the network then remote desktop in from the android tablet. Microsoft has an official client on the play store, it works pretty well.
  11. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Very interesting news, but when you write useful information, it would also be appropriate to indicate the source where we can draw...! ;)
    Microsoft Remote Desktop Assistant link software download...
    https://www.microsoft.com/en-us/download/details.aspx?id=50042
    Android Microsoft Remote Desktop App download...
    https://play.google.com/store/apps/details?id=com.microsoft.rdc.android
    Instruction for installation, connection and Microsoft RDP apps use...
    https://technet.microsoft.com/en-us/library/dn473010.aspx
    https://social.technet.microsoft.co...your-pc-using-microsoft-rdp-apps?forum=winrdc
    So the news is more complete... I think :thumbs
  12. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
  13. Doctor Kruntz
    400Coins
    3DOF, SCN6
  14. long legs
    long legs Perfect Race is a perfect day
    teacher
    catalonia
    373Coins
    2DOF, SCN5, Motion platform
    a very good app. If i understand correctly, this app helps to change the main forces without stoping the game. is it true?
    And the easy method is use a teamviewer with a tablet and run this aplication. But if i run the game in my pc, ill see the game in the tablet and can't use the remote profiler i think.
  15. axenic
    axenic Member Gold Contributor
    IT engineer
    Brest
    - 17Coins
    The problem with teamviewer is you will certainly loose focus on your game when updating the profile, hence missing the point of this app.
    Works perfectly with a very old laptop running the game engine over lan.
  16. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Ciao @Blame73
    This morning I installed the Professional License of SimTools and I had this same problem.
    The thing is rather strange indeed. Sniffing the data traffic (see below), we can see clients and servers communicating correctly, but the anomaly is concrete.
    If you insert appropriate exceptions on the firewall policies of both PCs, the problem is partly solved; the Remote Profiler PC displays the "ON" status and the values assigned to the axes and to the Main Level are correctly read from the Remote Server (PC running SimTools 2.2.5), but it is not displayed which is the active profile and the image of the associated game ... very strange :confused:.
    I hope I've been helpful to someone :)
    I keep studying the thing ... :!
    @yobuddy : Any idea? Are the UDP ports used only 59691 and 61334, or did I miss something?
    Grazie and ciao a tutti! :thumbs
  17. yobuddy
    51,234Coins
    I'll take a look guys.
    Have you set the correct IP address in the Remote Profiler app?
    There should not be any firewall settings needed if the connection is all on the internal network.
    All of the problems you listed are caused by the remote profiler not receiving data from Game Manger.
    I'll check over the ports also, because I'm pretty sure the ones you listed are not the ones assigned to the apps.
    Take care,
  18. ilbiga
    Network Engineer
    103Coins
    Ciao @yobuddy. The ip adresses are correctly configured (the wireshark trace show correct interaction), but not All data are correctly exchamged (axis data are now ok, but not show the loaded profile and game picture... very strange).
    As an upgrade, In my opinion was intresting to integrate the “virtual axis” section in “Remote Profiler”. We can see and correct in real-time the data output from the game and tuning the Rig with Remote Profiler.
    What do you think about this idea?
    I apologize for my bad English.
    Ciao
  19. Floris-Jan Eduard Lip
    Floris-Jan Eduard Lip Build4Power Racing
    The netherlands
    - 233Coins
    4DOF
    is there a way to resize the window of the remote profiler tool? i have a 1920x1080 windows tablet and i would love to have the remote profiler fullscreen:D
  20. Floris-Jan Eduard Lip
    The netherlands
    - 233Coins
    4DOF
    anyone?:D
