News SimTools 2.0 Question and Answer
Discussion in 'News' started by yobuddy, Feb 29, 2016.
Thread Status:
Not open for further replies.
  1. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    @MWB ...
    I have managed to reproduce the error ... me windows 7 Ultimate x86 .
    In the Game manager write an IP 125.0.0.1 and save it press continue to reset the socket or may not needed as I was connected ... with that got me out "Not Connected" ... close and exit .
    Re-open Game Engin and Manager again "still not connected " and reinter the correct IP 127.0.0.1 and save it ... it should get you back to the connected status ... close and exit .
    Game patched and tested ...
    Let us know if that worked :thumbs ... Me just hate =>> windows 10 :grin ...
    • Informative Informative x 3
  2. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Thanks @speedy, I'll give that a go when I get home. Fingers crossed!! :thumbs
  3. konterror
    konterror Member
    System/Storage Administrator
    Hamburg
    176Coins
    I started using SimTools 2.0 as well and it is great! Thank you, especially @yobuddy very much!
    I changed up some things in my rig and wanted to look at the PID graph I can get in the JRK utility. There is a small problem I had though, with SimTools 2.0. As soon as SimTools 2.0 is connected with the JRKs I cannot manage them with the JRK software. It tells me the device is locked by a diffrent software and I cannot select it. That means I cannot look at the PID graphs while driving anymore. That worked with SimTools 1.3
    Is there anything I can do about that or get the graph elsewhere?
  4. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    i didn't read every page but i wonder if in V 2.0 the washout filter has been improved ?
  5. Nick Moxley
    17,056Coins
    Not currently, Its something we are looking into in the future.
    Yes it has, Tho Not many run it due to being more for Yaw than anything. I very much disliked the Feeling of washout with Traction loss.
  6. wDOCw
    wDOCw Member
    196Coins
    Hey guys, 2.0 just tested, very good work, nice improvement!
    Nice movement with jrk, and very fast configuration and tuning now. (tested AC, rf2, pcars and dirt plugin)
    Thank to all that have worked in this update and in all plugin and thanks also for the free key, my little project is now easier to manage.
    chapeau
  7. Raymann
    Raymann New Member
    278Coins
    When i have 2 Motors, must i set the interface setting to this?
    [A<Axis1a>][A<Axis2a>]
    I dont understand what A or B is.
    Many thanks
    P.S. I have 1 MotorMonster
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    @Raymann
    Yes,I am assuming you are using SMC3 sketch? a and b designates the motor to be used a and b are like 1 and 2 on that arduino
    for two motors with SMC3 sketch your interface output string (engine/interface) should read
    [A<Axis1a>][B<Axis2a>]
  9. Raymann
    Raymann New Member
    278Coins
    I using arduino with RacingMan sketch.
    When i understand that right,i must set this:[A<Axis1a>][B<Axis2a>]
    Right?
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    no for @RacingMat code it needs to look like this
    you will enter the correct com port in the comport field
  11. Raymann
    Raymann New Member
    278Coins
    Many thanks for your help.Now i understand.
    Now i will update tomorrow on 2.0.
  12. MWB
    U.K.
    424Coins
    Hi @bruce stephen, @speedy, @yobuddy
    I have tried what speedy recommended earlier, thing is the IP address will not change, if I click on tools in Game Manager the IP address in the top right corner says 192.168.1.196 if I click Engine IP set the IP to 127.0.0.1 and click save the IP doesn't change, if I then close Game Manager and reopen it the IP hasen't changed
    Also tried installing .net Framework 4.6.2
  13. speedy
    Alexandria , Egypt
    7,943Coins
    @MWB ... Maybe it is something with your router auto DHCP ... unplug the cable from the network and try ... or leave it plugged and try to make the IP's within the same subnet mask as your network card like 127.0.1.1
    edit : this post is 1 minute earlier than the next one :grin:grin:grin .
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    :grin@MWB ok do it like speedy said in both applications but this time put in the ip (upper right tab of tools in manager) then do the same for the engine like this
    see if that work around does the trick.
    EDIT: This is what I was going to have him do last night as both apps have to match. He was tired tho
  15. speedy
    Alexandria , Egypt
    7,943Coins
    @bruce stephen ... It seems like this is the only field that makes me unconnected ... no matter I change the other numbers to whatever ...
  16. yobuddy
    51,028Coins
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yes, I had used udp with smc3 is the reason for this
  18. yobuddy
    51,028Coins
    So it's working?
    If you don't use it on the same PC as game manager, you will need to set valid IP addresses.
    let me know buddy! :thumbs
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
    @speedy according to your screenshot if you set your ip as 192.168.0.100 in both apps it should connect. Same as 127.0.0.1. I just figured he was set at 127.0.0.1 out of the box and it wasn't working that way so try something different. Not really sure what It changes as this is above my understanding. I just know it works on my system.
  20. MWB
    U.K.
    424Coins
    Hi all, @yobuddy
    I removed my wireless dongle that seemed to alow both Manager and Engine to have the same IP address when the PC starts up, but if I try and change any of the IP settings I get various errors
    Both Manager and Engine with the same IP 127.0.0.1 no connection
    Error I get if I try and change the Engine IP
    IP on the Manager if I carry on regardless and close and open the program (192.168.255.255)
    So I tried putting IP 192.168.255.255 into the Engine, this happened.
    Try to open Engine, get this
    I have no idea what the problem is :think:sos
Thread Status:
