Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. aceinthesky
    aceinthesky Member Gold Contributor
    Pearland, TX
    387Coins
    I got everything working with this patch except for surge.I was able to use extra 1 and got the sway working with that but the surge does not work. Sway seems to work erratically at the beginning and in certain sections of the track and then just stops. Really frustrating because the effects that work are awesome. I tried all the fixes in this thread, including the modified patch and still nothing.
    ...quick update, after of lots of trial and error I got it consistently working by removing the patch and then reinstalling it. Then I start the game, go to graphic options and then video options. Under that I change the resolution and refresh rate to the highest my tv will allow and make sure full screen is checked. I read about a windowed mode bug on this thread and lead me to this. I'm on an oculus rift and still have to do this with the screen resolution. I'm running 8 buttkickers with sim commander, 4 in chassis, 1 in set,1 in pedals, 1 in wheel, 1 in shifter. I can not get the motion to work with simvibe. As soon a I turn on simvibe the motion does not work anymore. This game would have been the ultimate inversion for fun, but I guess I'll stick to assetto corsa, since that works perfectly.
  2. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Yeah, I have the same issues, never getting DR to run consistent,albeit monitor, or Rift....
    I actually almost have given up, hoping 2.0 will solve the issues
  3. Aloha21x
    Aloha21x New Member
    112Coins
    Bonjour, j'ai essayé avec le logiciel Xsim et le probème est le même. perte des données surge et sway sur les mêmes sections des mêmes spéciales... peut être que le problème vient du jeu.. c'est une version steam achetée sur le site instant gaming.
    et vous?
    Hello, I tried with Xsim software and the problem is the same. Loss of data surge and sway on the same sections of the same specials ... may be that the problem comes from the game .. it is a steam version bought on the site instant gaming.
    and you?
  4. Blame73
    Blame73 Well-Known Member
    8,304Coins
  5. Pastrana
    Pastrana Member
    Argentina
    165Coins
    I'm testing version 2.0, it does not work sway, surge and heave. When the vehicle is stopped pulls many values, but when it begins to advance the values of these axes are paused. The rest of the axes works. Which may be?
  6. SilentChill
    20,592Coins
    I have had this problem and I think I just rebooted my PC booted back up got everything running and it worked.
  7. Pastrana
    Pastrana Member
    Argentina
    165Coins
    Restart has not worked for me
  8. Pastrana
    Pastrana Member
    Argentina
    165Coins
    I have already found the solution. In windows mode, there are axes that do not throw data. You have to put the game in full screen and there if it works normally.
  9. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Using version 1.3 or 2.0?
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Are you using a single computer or 2?
  11. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    OK, you need to set the IP address in the software on both computers in the simtools software but first unpatch and then repatch the game.
    This will be in the sub menus
  12. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    You just need to click the patch button in the UI like you did when you patched...Youre not adding in the patch itself..remember where it has a directory you have to find sometimes? That is where.
  13. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    There is installing a patch and then there is applying the patch...you just need to unapply the patch..
  14. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    You need to click the patch button to unpatch
  15. MPG
    MPG New Member Gold Contributor
    Netherlands
    57Coins
    hello, how is it possible that the motion for dirt rally it may or may not do.
    Mostly not.
    I did everything in my opinion.
    Is there anyone with the same problem.
  16. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Not sure as your translation is broken. Did you use google translate?
  17. MPG
    Netherlands
    57Coins
    Yes,sorry. its google translate.
  18. Brett Horton
    Tampa FL
    118Coins
    I think he is saying,
    Motion for Dirt Rally is very sporadic in nature, some times it works, sometimes it does not.,
    I have the same issue as well.... More times than not when I boot up the game no motion is present at all... When motion does decide to work, Heave, Surge and Sway are very intermittent. Same with 1.3 and 2.0.
    I am running all on one machine though
  19. Nick Moxley
    Interesting, i cant say i have EVER fired up dirt and just had NO motion at all..........o_O:think:confused:
  20. MPG
    Netherlands
    57Coins
    Have the solution, it does not work with simxperience commander 4, at the same time.
    I use that for SimVibe Chassis mode
