Tutorial From AtoZ : 2DOF arduino wiper playseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 8, 2013.
  1. RacingMat
    21,049Coins
    Hello
    That's a pity you blown up your setup...
    It sounds like the pot was wired in the wrong way... Try to figure out how it works: it's tricky
    If target doesn't change, if the pot goes one way, the motor should turn reverse in order to keep the target...
    There's nothing to change to the code, sorry. It works fine for dozens of sim
  2. Everh
    Everh New Member Gold Contributor
    Yonkers NY
    134Coins
    hello friend thanks for your answer is a pleasure to know q is has great help
  3. Everh
    Yonkers NY
    134Coins
    I do not know if understood my question I and calibrated potentiometer and the motor to rotate in the same steering, if the potentiometer goes right engine goes right and likewise the contrary, I send orders from my arduino with RFF,LFF and commands received very well, even from the simtool. what and proven with the game and receives the data very well, the problem is when along the potentiometer and motor. and order a new potencimetros of recommending yourself to see if the problem is solved.
  4. RacingMat
    21,049Coins
    I think I have understood ;-) that's a rooky mistake
    reverse 0V and 5V of your potentiometer and try without mechanical coupling: hold your pot by hand "like" it would be coupled.
    Please post a photo...
    - Send an order
    - See how the motor turns (cloxkwise or anticlockwise)
    - Turn by hand in the same way... the motor should slow, stop and turn backward
    - if not (motors keeps turning full speed), reverse the 0V and 5V of pot
  5. Everh
    Yonkers NY
    134Coins
    Hi friend, sorry for writing so late but I did not get my potentiometers arrived now that they arrived and I echo what they told me and it worked. Revive all the orders and stop in time works well, but now I have another problem, what happens now is that there are moments that I do not receive order has to move one first and then the other if they move both at the same time they stop and I do not know why . Help me, thank you for everything
  6. RacingMat
    21,049Coins
    so the code is good eventually! ;)
    What is your power supply capacity? I suspect it's too low...
    can you please post pictures of your sim, it would be far easier to help you
  7. Everh
    Yonkers NY
    134Coins
    If the code is ok, I have a 750w neutron power supply.
  8. RacingMat
    21,049Coins
    Sorry, I have problem to understand you...
    Share as well your motors specifications
  9. Everh
    Yonkers NY
    134Coins
    Well I have two 1998 ford contour wiper motor
  10. Everh
    Yonkers NY
    134Coins
    Hi That way I have everything , I do not know if it looks good. image.jpeg image.jpeg
  11. Everh
    Yonkers NY
    134Coins
    image.jpeg image.jpeg image.jpeg My components are: arduino one, motor monster potentiometer P11 and two motors image.jpeg
  12. Johan Soegiharto
    Johan Soegiharto New Member
    Jakarta
    203Coins
    Thank you for your advice. I have shortened the lever to 5cm but it doesn't change much and the motor is still hot after I use it for 20 -30 minutes. Actually when the simulator is not tilted its weight is in center but when someone is on the simulator it is usually lean forward. Do you have any other solution?
  13. Johan Soegiharto
    Jakarta
    203Coins
  14. Johan Soegiharto
    Jakarta
    203Coins
  15. Johan Soegiharto
    Jakarta
    203Coins
  16. noorbeast
    152,045Coins
    +11,062 / 56 / -2
    You need to balance the rig with yourself in it plus all peripherals: https://www.xsimulator.net/communit...-of-gravity-to-balance-a-motion-simulator.55/
  17. RacingMat
    21,049Coins
    @Everh it looks good
    I do believe your PSU is too weak
    Try with a second PSU!
  18. Andrew Eccles
    Andrew Eccles aceinnz Gold Contributor
    New Zealand
    - 541Coins
    Hi - those heatsinks look a little small - cooked one of my motor controllers - ended putting fan heatsinks to combat this.
  19. RacingMat
    21,049Coins
    Thanks for your compliment! I'm glad you find it useful :)
    Indeed, you need to to change Axis1 and Axis2 to Axis1a and Axis2a with the new version
    Have a good demo! :popcorn
  20. masterhoo
    masterhoo New Member
    Peru
    370Coins
    Hi, @RacingMat, I'm building a 2DOF, I'm still in the wiring process between Arduino-MM & the pots. I just cannot understand very well the wiring. And how the pots are connected. I'm not mounting the MM on top of the Arduino, I would like you to help me to check if the wiring diagram I created is correct? I designed it following the pictures you posted only, but I still dont know if 100% correct, merci!!
    here is my components to wire.
