Tutorial Arduino code for 4DOF and 1 DIRpin Hbridge board
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 7, 2013.
  1. noorbeast
    153,938Coins
    +11,158 / 57 / -2
  2. AlexinChina
    AlexinChina Member
    China
    371Coins
  3. RacingMat
    21,082Coins
    Yes, this code is working for 4DOF :)
    Just check your HBridge has only 1 pin direction
  4. luky_90
    luky_90 Member
    276Coins
    I'm continuing with work and I wanted to understand one thing , I am using the code 4dof racing mat with 2 monster motor, reading the features of the card read :
    ● Voltage Max : 16V
    ● Maximum current rating : 30A
    ● Practical Continuous Current : 14 A
    ● Current available to Arduino analog pin sensing
    ● on-resistance MOSFET : 19 M: ( per leg )
    ● Maximum PWM frequency: 20 kHz
    ● Thermal Shutdown
    ● Undervoltage and Overvoltage shutdown
    If I have a 12v engine that develops continuous current 14A , the motorcycle monster card can attack only one right engine ?
  5. RacingMat
    21,082Coins
  6. zylle
    zylle New Member
    Denmark
    124Coins
    I can second your experience with that cheap h-bridge, it lasted me 5 minutes of low-amp- playing around before it sparked and began to smoke! :D
    2x pololu h bridges are now ordered and on their way :)
    Your code works flawlessy with 2 motors btw, its awesome, thanks a lot!
  7. RacingMat
    21,082Coins
    Bad news... Hopefully your arduino has not been destroyed like mine did when these Hbridge blew up.
    Thanks for your feedback :)
  8. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Hi Mat,
    Could you tell me the Arduino Uno pin outs for DIR3, PWM3 and pot3.
    I am using three Pololu 24v 21 drivers. https://www.pololu.com/product/2995
    It could be already stated on your posts... Just can't find it sorry.
  9. RacingMat
    21,082Coins
    your driver is One pin direction and One pin PWM
    so it's compatible with the code
    Code:
    #define potL A5
    #define potR A4
    #define potY A3
    //#define potW A2  // no PID needed for Wind -> no Pot on a wind motor
    int DIRpin[4] = {
      2, 3, 4, 5};  // if HIGH/LOW then motor runs Forward/Reverse (depending on wiring)
    int PWMpin[4] = {
      6, 9, 10, 11}; // PWM vary between 1 (slow speed) and 255 (fast speed)
    DIR3 -> 4
    PWM3 -> 10
    and pot3 -> A2
  10. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Thanks Mat!
  11. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    Hello Mat,
    Thank you for this great work. Yesterday I tried your code with the configuration and set-up below. I want to ask you what must be the wires for 4th motor? I tried on A2 to Dir 5 and Pwm 11 but it didn't work. What could be the wrong thing?
    Arduino Uno => Pololu #758 (18V25)
    Pin A5 => DIR pin 2 , PWM pin 6 Ok, It works
    Pin A4 => DIR pin 3 , PWM pin 9 Ok, It works
    Pin A3 => DIR pin 4 , PWM pin 10 Ok, It works
    Pin A2 => DIR pin 5 , PWM pin 11 Unfortunately It didn't works
    You mentioned that to use 4 motors Simtools set-up:
    R7FL7FY7FW7F
    R<Axis1>L<Axis2>Y<Axis3>W<Axis4>
    R7FL7FY7FW7F
    Burak
  12. RacingMat
    21,082Coins
    What is your fourth motor?
    If you need to read its potentiometer, uncomment the line (= remove // at the beginning)
    #define potY A3
    //#define potW A2
  13. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    Thank you for fast reply, I will try it on Monday.
    I am using 1 Arduino, 4 Pololu 758, 4 motor, 4 pot.
  14. panfilo
    panfilo New Member
    Australia
    - 9Coins
    I think this is awesome I have ordered some motomonster cards for $25.15eaAUD and will give your code a try keep up the great work.
  15. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    my wind simulator fan didn't work, no output but the other Dofs are working.
    What could be the problem? please help.
    My interface settings are:
    R7FL7FY7FW0
    R7FL7FY7FW0
    On Arduino Uno
    5-11 and GND are wired to Pololu DIR-PWM-GND
    On Simtools Axis assignment, the 4th Dof is set to %100 Surge
  16. RacingMat
    21,082Coins
    Can you please post some setup screenshots and photo of your boards?
  17. liuyidao
    liuyidao New Member
    china hubei wuhan
    171Coins
    Thank you, very helpful
    But I might want to consider using 2 cheap motors to try
  18. noorbeast
    153,938Coins
    +11,158 / 57 / -2
    @Everh please stop spamming posts, @Pit can you please clean this thread up when you have time.
  19. lemaitre
    lemaitre Member
    - 111Coins
    merci racingmat pour ton travail et ton partage
    j »i un simu 2dof avec ton code que je viens de refaire complètement en 3dof
    mécaniquement, je n'ai aucun problème, mais programmation je suis pas top du tout
    j »i un arduino et 2 monstershield et le progamme qui est dans ta signature est pour une direction alors que les monster on besoin de 2
    comment modifier ton premier programme 2dof en 3dof?
  20. lemaitre
    lemaitre Member
    - 111Coins
    j ai fait une erreur , ça ne marche pas car les monter shield sont prévu pour 16 volt max et pas 24 volt, donc mon problème est résolut , faut des sabertooth 2x32
