  1. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    hi ! i'm newbie here. i want to know after i'm tuned in SMC software and i can use it immediately or i have to upload code (value in SMC software) again in arduino software ?(Arduino IDE)
    thanks
  2. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,321Coins
    If you used Windows SMC3Utils to change the settings then they are automatically saved in the Arduino EEPROM.
    You should not need to edit SMC3 code except for the initial MODE configuration.
  3. luky_90
    luky_90 Member
    276Coins
    excuse @RufusDufus, I try to make things clear .
    In the video with the MM I am using the RacingMat code, if I rotate the potentiometer see as the engines move .
    In the video with IBT2 I am using SMC3.ino MODE2 , as you can see if I rotate the potentiometer the motors are at a standstill .
    I hope I have clarified
  4. RufusDufus
    Adelaide Australia
    16,321Coins
    What does Windows SMC3Utils report?
    Does it connect to the arduino (ie show version number of SMC3 installed)?
    When you turn the POT can you see the green line move in the SMC3Utils chart?
    Have you configured the SMC3 settings using SMC3Utils?
    Perhaps post a screenshot or video of this.
  5. luky_90
    luky_90 Member
    276Coins
    I have not installed SMC3 utilities , expecting to make everything work and then do it !!what do you recommend version to download ? I just agreed to take a video .
  6. RufusDufus
    Adelaide Australia
    16,321Coins
    You need to use Windows SMC3Utils to configure the settings before using Simtools.
    It will help you find your problems as well.
    Download and details are in the second post of this thread.
  7. luky_90
    luky_90 Member
    276Coins
    I installed SMC3 utility , followed step by step instructions , but the motors are at a standstill , I tried to move the hand potentiometer and the green line moves, but the engine remains stationary .I also did another house right where there wrote Motor1 , motor2 , Motor3 if I press the power button does not switch to ON
  8. stevemontuno
    stevemontuno Active Member
    1,461Coins
    I think i remember once not being able to turn the motors on but after i reset my pots back to near center all was good again,,,,worth a try anyways.
    If that works reset your PWMmax etc back to zero and start your test again ,, you should start seeing movement when your pwmmax get up to around 20
  9. luky_90
    luky_90 Member
    276Coins
    as I reset my pots ?
  10. stevemontuno
    1,461Coins
    re-center the pots ,,,
  11. luky_90
    luky_90 Member
    276Coins
    @stevemontuno I hit the pot as you told me , then I raised PWMmax this video a result , the engines do not move again !!
  12. stevemontuno
    1,461Coins
    Make sure you've not got simtools running ,,,and also close the arduino software.
  13. RufusDufus
    Adelaide Australia
    16,321Coins
    The video shows that the motor is already in the target position (blue line and green line on top of each other, therefore the motor does not need to and won't be moved.
    It is best to do this test using square wave or sine wave output.
  14. luky_90
    luky_90 Member
    276Coins
    hello guys , after several tests I found that the IBT - 2 boards were broken .Today I did some testing with MM , I leave a video because I can not launch if motion in utility after a while it moves jumping power .look your help and thank you for everything !!
  15. RufusDufus
    Adelaide Australia
    16,321Coins
    If you can click the OFF button to ON then the issue is that the Arduino SMC3 code thinks the motor POTs are moving beyond the set limits. As it doesn't appear that way on the chart it could be noise on the signal that isn't showing up - it only needs one sample outside the limits to shut down. Try moving the POT wires away from the motor and 12 power wires, twist the 3 POT wires together, if the POT itself is dirty it could produce noise - try a different POT, try increasing the set limits using the SMC3Utility (red lines) so that there is a greater gap, try some capacitors between the POT input on Arduino and GND to filter noise spikes.
  16. luky_90
    luky_90 Member
    276Coins
    Thank you very much , all sorted now .
    I have a doubt , I will set the data that will remain on the utility also saved on simtool or the utility is only a test program for the engines ?
  17. RufusDufus
    Adelaide Australia
    16,321Coins
    The changes made using SMC3Utils are automatically saved to the Arduino EEPROM.
  18. luky_90
    luky_90 Member
    276Coins
    [Quote = "RufusDufus, posta: 114191, Membro: 8539"]. Le modifiche apportate usando SMC3Utils vengono Salvate Automaticamente Nella EEPROM Arduino [/ quote]
    My IBT2 have burned , changing the BTN with this model that I attach what you think ? It seems to be more powerful
  19. RufusDufus
    Adelaide Australia
    16,321Coins
    An initial quick look it appears as a suitable alternate for the now obsolete BTS7960B.
    I haven't checked in detail though.
  20. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    @RufusDufus Hi !
    I think i found a little error in the software . ( i am not sure, but i found it on my original version). Maybe it is already fixed. here is in the attached file. SMC3_07  Arduino 1.6.5.jpg
