Elite Dangerous Horizons Plugin (Non VR Version) [Deleted]
Discussion in 'SimTools Plugins' started by value1, Dec 22, 2014.
Thread Status:
Not open for further replies.
  1. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,238Coins
    hi @SilentChill / @value1 / @mohammad
    can any body tell me the value ranges for the DOFs from elite ?
    I want to catch the values with CheatEngine, but i dont have any idea what i've to looking for
    are there float values or 4 bytes values ?
    which ranges ? -127 to +127 ? or maybe -32768 to +32768 for the DOFs ?
    thanks for help
  2. SilentChill
    20,584Coins
    @kermitkong
    There you go find the pointers and happy dayz :D
    Or just wait for me lol
    • Optimistic Optimistic x 1
  3. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    It's too bad too, because they're simulating an entire futuristic version of our galaxy. It would be nice to have API hooks to make all kinds of things- motion sims, light-up panels and such for people not into VR, you name it... Feeling impacts when shot at, thumps from landing... They're missing out on some amazing PR (e.g. youtube videos, etc) for their game at the very least :)
  4. SilentChill
    20,584Coins
  5. SilentChill
    20,584Coins
    • Winner Winner x 3
  6. kermitkong
    1,238Coins
    hey Captain @SilentChill
    super quick work, faster than i could find something.
    and, it works on my side, just tried...
    hug:hug:hug:hug:hug:
  7. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Bloody hell mate, you updated that plugin faster than the time it takes me to dock!!!
  8. mohammad
    mohammad Member
    iran
    159Coins
  9. mohammad
    mohammad Member
    iran
    159Coins
    hi @kermitkong
    float type and
    for roll range (1.8 to -1.8)
    for pitch, heave, yaw, sway , surge range (1.1 to -1.1)
  10. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    Thanks again
  11. Imeleon
    Imeleon Member
    Construction Engineer
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    Thanks for keeping this updated @SilentChill.
    All works great. I do get some erratic movement in supercruise. Only once I've been supercruising for a while.
    I might have to redo the min max file thingy for my set up.
  12. kermitkong
    1,238Coins
    Hi @Imeleon
    I've the same sporadic movements in super cruise between planets some times.
    1st I thought it is a bug in my motion seat firmware , but this comes from the sim-tools maybe they forward these data from Elite.
    Could also be possible that the movements are correct because the movements are in a certain way synchronized with sound . Maybe there's some areas between planets with gravitation irregularties/storms and that's the reason for the unexpected movements.
  13. Bordiin
    Bordiin Active Member
    Brazil
    159Coins
    Hello, a few weeks ago i had downloaded the elite dangerous plugin to a demo version x32 this still working, yesterday I did the download the new version to x64 and when i try pacthing the game he showed a message (picture in attachament), I try copy the files to the simtools folder but always showed the same message, if i click OK and start the game the Simtools Game manager stop. I'm using a steam version
  14. SilentChill
    20,584Coins
    Start again and run in admin mode
    Also this is for Horizons only
  15. Bordiin
    Brazil
    159Coins
    hello @SilentChill
    I tried run the sim tools plugin updater in admin mode and a can't add the new plugin, so i added in the normal way, and i ran the sim tools GameManager in admin mode and he showed the same message.
  16. SilentChill
    20,584Coins
    Hmm sorry but it works for pretty much everyone else. Read back through this thread lots of people had issues but most got resolved eventually
  17. George Dobransky
    Hungary
    - 33Coins
    Hi there!
    Is the newest plugin will work for Horizons 2.2 also?
    Cheers,
    George
  18. George Dobransky
    Hungary
    - 33Coins
    Bordiin,
    I had the same issue as you have, I finally solved the problem.
    Take care about the followings:
    1.
    You have to set the game engine and game manager running in admin mode, -I suggest you give admin rights to installer also-, just right click on the icons, compatibility, then click on running as admin.
    Be sure about if you moved the shortcuts to your desktop, it has to made by 'make a shortcut to the desktop', not just drag and drop to your desktop.
    It will only work in win7/64 if you get the message at starting the programs 'you are running in admin mode.' Thats good.
    2.
    Be sure that you have set the real directory of the game. If you have installed by steam, it should looks like, Program Files (x86)/steam/SteamApps/common/products/elite-dangerous-64/
    The most important to find elite directory, called:/elite-dangerous-64/
    By the way you can set manually your path in win7 at:
    C:\Users\*yourname*\AppData\Local\SimTools\GameManager\GamePathSaves\elitedangerous64.cfg
    It has to be working!
    Cheers,
    George
  19. George Dobransky
    Hungary
    - 33Coins
    Bordiin,
    Another thought: If you run updater in admin mode, just drag and drop the zipped file into the updater, has to be workin!
    George
  20. George Dobransky
    Hungary
    - 33Coins
    Hi @SilentChill,
    Tomorrow we get the next update for ED, should the current plugin will work for the upgraded ED version also?
    Regards,
    George
Thread Status:
