Showroom 3-DOF Flat-bed Drifting simulator with AC motors [ Finished ]
Discussion in 'DIY Motion Simulator Projects' started by speedy, Apr 5, 2016.
  1. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,942Coins
    OK ... here is how it came out and how I'm going to use a nut while casting the polyester ...
    By oiling all the internals of the mold " as a release agent " and carefully screw a clean nut to its center holder " ... the oiled silicon will later slip out of the nut and just leave it there ...
    Notice the center guide for the drill bit on the bottom ...
    • Creative Creative x 2
  2. speedy
    Alexandria , Egypt
    7,942Coins
    The casted pulleys installed and the built back side is running on a 626zz bearings ...
  3. speedy
    Alexandria , Egypt
    7,942Coins
    prepared the base to receive the outfit flex cover ...
  4. speedy
    Alexandria , Egypt
    7,942Coins
    installed the base top cover ...
    my son wanted it to have a front headlights ...
  5. speedy
    Alexandria , Egypt
    7,942Coins
    base logos has arrived and installed ..
    • Like Like x 5
  6. speedy
    Alexandria , Egypt
    7,942Coins
    carpet flooring installed ...
    • Like Like x 5
  7. speedy
    Alexandria , Egypt
    7,942Coins
    leather dashboard and speakers ...
    exhaust computer cooling fans decoration ...
    enjoy these photos too ...
    • Like Like x 5
  8. speedy
    Alexandria , Egypt
    7,942Coins
    20160705_064138.jpg 20160705_064157.jpg 20160705_064208.jpg 20160705_064245.jpg 20160705_064303.jpg 20160705_064321.jpg
    • Like Like x 5
  9. speedy
    Alexandria , Egypt
    7,942Coins
    • Like Like x 6
  10. everaldo ramos da silva
    everaldo ramos da silva Member
    merchant
    são paulo- Brazil
    57Coins
    2DOF, 3DOF, DC motor, Arduino, JRK, 4DOF
    Speed Hello, good work friend.
  11. speedy
    Alexandria , Egypt
    7,942Coins
    And when I just wanted to shoot a video ... I hit the wall and the ball screw came out of it's mounting bracket ... :confused: .
    20160704_070435.jpg 20160704_070503.jpg 20160704_070717.jpg 20160704_070757.jpg 20160704_070512.jpg 20160704_070818.jpg 20160704_070956.jpg 20160704_070939.jpg 20160704_070848.jpg
  12. speedy
    Alexandria , Egypt
    7,942Coins
    removed these thin brackets ...
    and used a 6mm threaded rod bent to fet with well tightened nuts and washers ...
    this allowed me to use the green cab oiling valve back again ...
    20160704_082332.jpg 20160704_082353.jpg 20160704_095522.jpg 20160704_095528.jpg 20160704_095548.jpg 20160704_095611.jpg 20160704_125650.jpg
    this is the center motor fest ... removed from downside .
    everything under testing again ...
    patience guys I know what you need :popcorn
  13. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Love your design Speedy..........and the sim "LOOKS GREAT"...................Love the headlights for your son!!!
    Tom
  14. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    who said that WE are anxious for a video from your great sim in action :p
  15. speedy
    Alexandria , Egypt
    7,942Coins
    Now it is really smooth and the bearings are well aligned ...
    Calibrating the PID again ...
    test drive with the old settings of game engine ...
    • Like Like x 7
  16. Blame73
    Blame73 Well-Known Member
    8,303Coins
    Congratulations for the achievement @speedy, are you planning to add heave?
  17. speedy
    Alexandria , Egypt
    7,942Coins
    I have some ideas but it isn't an easy step at the moment ...
  18. speedy
    Alexandria , Egypt
    7,942Coins
    test drive 2 ...
  19. speedy
    Alexandria , Egypt
    7,942Coins
    TL clearly appears while tail sway follows the nose ...
  20. speedy
    Alexandria , Egypt
    7,942Coins
    It seems like we all have to taste the failure of the ordinary 10 turns pot ... me too started to have some erratic spots and decided to move on to the 180 degree hall effect pot ...
    So I think this idea might be good ... a worm gear 10:1 reduction gear ratio setup
    Any suggestions How this could be done ?
    A 3D printer maybe ?
