12V DC Motor 6DOF Motion Sim Project
Discussion in 'DIY Motion Simulator Projects' started by Racing Mike, Apr 27, 2016.
  1. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    I think I got one more reason to speed up my 6DOF project.
  2. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    I loved to use my sim with the DK2, 99% of the people that tried enjoyed it, just one of my friends can't hold for more than 10 seconds.
  3. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    Hi, have you tried to play RIFT without SIM? or your friends. Do you think how much does the SIM help to reduce VR motion sickness?
    5 friends played project cars with rift, all have vr sickness, include me.
  4. mariano68
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    No more than the 5% of the people that tried the dk2 got any kind of vr sickness, with or without the sim. I think most of the vr sickness comes from demos or games running under the recommended specs (below 75fps for dk2).
  5. SilentChill
    20,601Coins
    I think the movements of my rig helped a lot as some of the people who have used it get motion sick really quick. I havn't had anyone actually be sick yet but they have felt a little queezy. I don't suffer at all so it with motion sickness so doesnt matter how bad it is I cant tell.
    It does get wierd though when first setting up a profile and you have everything reversed it proper messes with your mind and if you were to get motion sick it would be instant projectile vomit i think :D
  6. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    when I play Lucky or EVE I have no VR sickness, but when I play Project Cars it appear, maybe because Project Cars are more vigorous.
  7. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    I think I need speed up my project.
    153,938Coins
    +11,158 / 57 / -2
    Racing sims in particular have a lot of very fast relative movement, so the user is moving relevant to the environment and there things in both the fore and backgrounds that can be static, like trees and signs, or also moving on their own trajectory, like other cars. For people prone to VR sickness that is a lot happening all at once.
    With the likes of Pcars don't push yourself to the point of feeling sick, as soon as you feel the slightest bit weird stop playing. If you do that repeatedly you will find that you can play for longer and longer, as you build up a tolerance.
  9. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    Before I test LFS in my old laptop, the SIM is shaking even the car is stop, and the SIM works unordered,
    today I tested in my new Gaming PC, and it's the same. looks the SIM TOOLS receive some wrong signal form LFS game.
    I looked at the tuning center, even the car is stoped, the value in tuning center is changing from minus to plus. Someone met this same issue before?
    153,938Coins
    +11,158 / 57 / -2
    It is a good idea to post all of your axis and tuning center settings. My guess is that some may be set to be overly sensitive. You can go through each in turn and turn them all off except for one axis to find out which.
  11. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    let me check it again. thanks for your suggestion.
  12. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    I'm so careless, I didn't notice the language bug in FAQ, and all my test and research I did before are wrong.
    Today I changed the language to English now works reasonable, and I got some more understanding.
    But there is still a problem I don't why, when I drive some times the yaw signal is wrong, most of time it show 100% or -100%, even the car is stopped.
    I will try to unpatch and patch the LFS again.
    below is the setting and Video.
  13. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    when I stop the car, all the signal except yaw will reset to 0,
    why YAW didn't reset? is it normal?
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    Try extra 1 for traction loss instead of yaw.
    • Agree Agree x 3
  15. Historiker
    9,205Coins
    Think of yaw as a compass heading, that is why it doesn't reset to zero. As @brucestephen said; use extra 1 for traction loss rather than yaw. Yaw doesn't translate well for racing games.
    Glad to see that you are making progress! :)
  16. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    But I think traction lots can't simulate turn direction.
    Is it possible let SIM tool or SMC3 consider changed value of yaw instead of absolute value?
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yes its named traction loss. Try it, it really does work well. You can change the motors axis %to adjust the center and the distance of the twist. More in the back motors feels like traction loss or oversteer. An even set of numbers will set the center of the twist back a little further on the rig
    Edit: I set up tl with 0 movement on the front two motors, about five on the middle and 15 on the two rear motors. Then adjust dead zone and smoothing to feel.
  18. Historiker
    9,205Coins
    Hi Mike, perhaps if you explained exactly what you are trying to accomplish we may help?
    If you are trying to simulate understeer or oversteer Extra1 (Traction Loss) will simulate oversteer. You are building a 6DoF so you are not looking for 360 degree turning ability correct?
    If you want Yaw for an airplane simulator you would look to the plugin for the particular game as yaw for those plugins are handled differently (so I understand).
  19. Racing Mike
    Racing Mike Member
    Chile
    348Coins
    Thanks. @Historiker @bruce stephen
    This noon I tried extra 1 as you suggestted, it works fine. But I need come back to office work, tonight I will take a video.
    I'm a new guy at SIM, at beginning I thought if the car turn left, there should be a yaw signal, when directions back to straight the yaw signal reset. But @Historiker explained to me yaw is like compass, the signal is compared with the starting angle.
    My 6dof will be used for racing games and also flight games. So I need consider how to simulate turn direction signal for flight games.
    Now I'm waiting my big motor from China, the else materials are ready.
  20. SeatTime
    Hi @Racing Mike good to see your sim is coming along. Note that pitch and roll are similar to yaw Ie. Output based on a rotational angle, not a force - Eg. when you stop the car the angle for pitch and roll will be dependent on the actual banking of the track, which may or may not be 0 degrees: For more info https://en.wikipedia.org/wiki/Six_degrees_of_freedom . I although am not understanding your settings in Simtools? Maybe it is the way you have wired the motors/feedback pots? For at least 'Heave': If you have wired all your motors/feedback the same, the six axis's should all be set for 'Heave', driving at the same percentage and in the same direction.
