Showroom 3-DOF Flat-bed Drifting simulator with AC motors [ Finished ]
Discussion in 'DIY Motion Simulator Projects' started by speedy, Apr 5, 2016.
  1. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,942Coins
    Thanks buddy @cthiggin ... Who Know ? you might need to add fans too on excessive use ...
    BTW ... How is your hands by now ?
  2. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Speedy,
    Still "mending" from surgery.........fusion on thumb joint is now 100%, still in therapy to get strength back and to get ALL post surgery pain to go away...........then hopefully, "off to the races" with
    my (our) sim. Thanks so much for asking. Blessings to you.
    Tom
  3. speedy
    Alexandria , Egypt
    7,942Coins
    @cthiggin get well soon buddy ...
    I've finished preparing the mounting for the screwball nut all three of them ... just modified the old ones .
    from this ...
    like so ...
    into this ... see how easy to move the entire cockpit back and forth "Dusty weather so squeaks will be lubricated " .
    Next ... to the lathe for end machining the screwball shafts bearing and motor coupling ... " I bought them by length - Not machined "
    the center shaft is 118cm ... the front and rear shafts are 91cm . "Custom + cheaper":D .
    • Like Like x 5
  4. RacingMat
    21,028Coins
    that's huge! big! great! :)
  5. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Speedy,
    "Looking Good!" -
    Your DOF = Surge / Sway & ????
    Blessings, Tom
  6. speedy
    Alexandria , Egypt
    7,942Coins
    Actually you'll find it was bigger in dimensions in the original skp file ... the base was 3 m. by 1.76 m. :)
    @cthiggin ... yes Surge/Sway/Traction loss like this one ...
  7. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    OK - Nice going Speedy...............excited for you!!!!
  8. speedy
    Alexandria , Egypt
    7,942Coins
    Painted and the ball screw shaft installed ... waiting for the SimTools sticker and some printed vinyl logos ;) .
    • Winner Winner x 7
    150,974Coins
    +11,025 / 56 / -2
    It looks superb @speedy :thumbs
    I am really looking forward to seeing your rig in action.
  10. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Beautiful work, as expected, Speedy. So very happy for you.
    Continued Blessings,
    Tom
  11. speedy
    Alexandria , Egypt
    7,942Coins
    I have a problem with this wire and roller feedback setup ... it is sometimes loses its position and causes the platform to crash to the frame front end ...
    So, I've decided to change it to a timing belt and a pulley ... wait for the cloning steps of the pulley :thumbs .
    Edit: the white silicon mold in the picture is an old shrinked one and gave me a smaller pulley that the belt is not compatible with .
  12. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Speedy,
    I know the pullies and belts are sure accurate on my platform...........think you may be happy.
    Good luck friend.
    Tom
  13. speedy
    Alexandria , Egypt
    7,942Coins
    For cloning the aluminium pulley which I need three of it ASAP ... I decided to make a mold for it to cast it with polyester + baby powder as a stiffing filler ... I know this trick will work as I've done this procedure hundreds of times long ago cloning broken printers parts and gears ... gust using the appropriate material for casting the final part that makes the difference ... So, let's start .
    1- I blocked the unneeded extra hole with a clay and lubricated the pulley teeth with a mineral oil like used in car motors .
    2- forced a good amount of silicon with my oiled fingers through the teeth and the main hole all the way deep to pop into the center ... that is to give me the interior negative shape output ... which will give me after cating hole where you put your eline key to fasten the pulley to the pot axis " a nut will be built-in and used here too" ... more details for this point on the casting post .
    3- Oiled the plan sides of the pulley and the plastic base and pushed the silicone a little down "Red Arrow" through the pulley center big hole to make a center drilling bit guide for future drilling the pot axle path with a 6mm drill bit .
    4- continued layering silicone with my oiled fingers and a plastic peace until a top leveled surface is achieved ... leave it to cure about 24 hours .
    5- prepared the nuts and the fastening screws for casting ...
    See you in the casting post ... :p
    • Like Like x 5
  14. SeatTime
    28,321Coins
    In building my actuators I tried lots of different methods for feedback, ended up also going for a timing belt and pulley setup - has worked perfectly for about 6 months now.
    • Informative Informative x 3
  15. everaldo ramos da silva
    everaldo ramos da silva Member
    merchant
    são paulo- Brazil
    57Coins
    2DOF, 3DOF, DC motor, Arduino, JRK, 4DOF
    Hello friend, can you explain how you can make as many laps with the sensor and still not miss the signs?
    Thank you very much
  16. speedy
    Alexandria , Egypt
    7,942Coins
    I'm using a 10k ohm 10 turns pot for the feedback signal ...
    So I have a full 10 turns from start position to the end on the pot axle ...
    then actually by measuring the full motion path required and dividing it /10 = > you will get the circumference of the required roller mounted to the pot axle and you can calculate the its diameter ...
    you can reduce that circumference by a 10% so you don't reach the actual mechanical breaking point of pot at both ends ...
  17. speedy
    Alexandria , Egypt
    7,942Coins
    Sorry guys : An honest mistake has been made ... that is due to the rush for putting all the steps in one post ... I didn't leave the silicone first layer to cure first thin give it the other layer ...
    so till now the internal layer still didn't hardened enough ...
    see you soon ...
  18. everaldo ramos da silva
    merchant
    são paulo- Brazil
    57Coins
    Velocidade Olá, obrigado por sua atenção, hall sensor de sempre utilizado.
    Eu quero desenvolver um novo projeto usando parafuso de bola e por isso, como você fez eu preciso que o sensor pode capturar as várias voltas.
    O que eu não entendo é como o software simtools pode lidar com as várias voltas do pote sem perder o sinal acima de 180 °?
    Se não incomodá-lo e pode me guiar em mais detalhes eu vou ser muito grato.
    Um amigo abraço grande.
    Inglês Desculpe, estou usando o google tradutor.
    Speed Hello, thank you for your attention, always used sensor hall.
    I want to develop a new project using ball screw and for it as you did I need that the sensor can capture the various turns.
    What I do not understand is how the simtools software can handle the various turns of the pot without losing the signal above 180 °?
    If not bother you and can guide me in more detail I'll be very grateful.
    A big hug friend.
    English Sorry, I'm using google translator.
  19. speedy
    Alexandria , Egypt
    7,942Coins
    @everaldo ramos da silva ...
    In a linear motion range like mine and like most of the supported games and plugins till now... The hall effect sensor will be attached to the controller not to Simtools ...
    The sensor here gives a feedback to the controller for what the motors are doing ...
    To solve the 180 degree ( half turn ) of the Hall effect sensor you may use a reduction gears that reduces the motion range into only half turn to the pot ...
    here is how to ...
    http://www.wikihow.com/Determine-Gear-Ratio
    here is some wooden gears that you can DIY .
    https://woodgears.ca/gear/ratio.html
  20. everaldo ramos da silva
    merchant
    são paulo- Brazil
    57Coins
    Thank Speed, I'll use the same that you are using, so will work without gear?
    I use controller Thanos.
    I will try, thank you for your attention.
