2 dof seat mover with cv
Discussion in 'DIY Motion Simulator Projects' started by Raredog, May 31, 2016.
  1. Raredog
    Raredog Active Member
    Denmark
    25Coins
    2DOF, JRK
    Hi
    After following you guys for the last year or so, I have finally gathered the parts needed to build a sim :)
    I will start out with a 2 dof seat mover and see where it ends, but there is one thing that I can't really find the answer for: why not use a cv joint?
    I have tried mounting it to a plate and for me it looks like it is moving in just the same way as a u-joint. Being from Denmark where most cars are fwd,it is way easier to find a cv.
    Anyone?
    150,950Coins
    +11,025 / 56 / -2
    Many CV joint allow lateral rotation and if used require additional panhard style control rods to prevent unwanted twist of the motion sim. A uni joint prevents lateral twist so is a far simpler solution.
    It is worth hunting around and finding an old car to get the tailshaft and uni joint, just cut it to the suitable length, mounting the uni joint as close to the seat base as possible.
    • Agree Agree x 3
  3. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    From what have read a cv will work ok but you can have a small amount of twist in your motion and u might need to address that if you want the best feel.
    Edit @noorbeast beat me to it lol
  4. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Aah, thanks :)
    I have tried twisting it, but there doesn't seem to be any rotation, but maybe it will show up when mounted?
  5. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    there are Cv joints that doesn´t twist but if It does you can put one or two edge rod like in the picture and solved 2wnw9ps.jpg
  6. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    Is not a bad idea using a CV joint I found them more reliable and durable than the cardan joints.
    150,950Coins
    +11,025 / 56 / -2
    I have never heard of a car tailshaft cardan joint ever failing or wearing out on a motion sim, so what leads you to believe they are not as durable as a CV joint?
  8. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    The Cv joints are used for traccion and the cardan usually for steering, the forces for they where designed to are higher.
    150,950Coins
    +11,025 / 56 / -2
    I recommended a cardan from a car tailshaft, not a steering column. Those will never fail on a motion sim and greatly simplify the construction, as no panhard style rods are needed.
  10. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Ill try and let you know if its ok :)
    How much difference does it make with a single turn pot directly on the axle, vs a geared pot? I like to make it as simple as possible, as it is my first sim :)
    150,950Coins
    +11,025 / 56 / -2
  12. Raredog
    Denmark
    25Coins
    2DOF, JRK
    That's smart :) already ordered regular 5k because they are cheap, but then I might want to change them later, if it makes a big difference?
  13. noorbeast
    150,950Coins
    +11,025 / 56 / -2
    I consider the benefits of Hall sensors are worth the cost.
    You can direct mount using a flexible coupling, they are cheap and come in various sizes.
  14. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    I have a doubt about flexible coupling. that flexiblity doesn´t interfere in the precision of the movement?
  15. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    I mean, it isn´t better something like this? or is there another advantage i didn´t know on flexible couples? rigid.jpg
  16. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    Agree about the hall sensors easy to build, cheap and durables
    150,950Coins
    +11,025 / 56 / -2
    Do not use a solid coupling, the slightest misalignment can cause damage. A Flexible coupling maintains precise movement and also provides misalignment protection.
  18. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Thanks, I think I will use a piece of rubber hose as a coupler :)
    Cool to diy halls :)
  19. Nick Moxley
    17,056Coins
    a piece of hose is NOT a flex coupler. a hose can actually build up some "twist" as the motor's move and overshoot its position every time. (Not suggested)
    Flex couplers are a couple bucks a piece. (when you search)...I Highly suggest buying the right parts once VS buying thing's twice you "think" will work.
    http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20160601060611&SearchText=flex+coupler
  20. chu
    chu 2dof racingseat
    tecnician
    VITORIA
    937Coins
    And I don´t believe a rubber hose could support the strength of the motors working with high weigth(with any weigth, really think so). The guys on the forum really knows what they´re talking about, better to follow their advices, I know by my own...
