[DIY] OpenSimwheel.NET | Selbermacher Servo-Lenkrad
Discussion in 'DIY peripherals' started by bberger, Aug 13, 2014.
  1. bberger
    bberger Member
    306Coins
    My FFB output is purely API based and for the input device I solily relied on vJoy (non FFB version).
    I planned to port the code to support the new vJoy version wich has FFB support, but when MMos released his controller the need for it kind of vanished.. I may again pick up this topic at some point, but for now I don't see a strong reason to do so as the need for it is very very small..
  2. Francisco C
    Francisco C New Member
    Modena Italy
    349Coins
    DC motor, AC motor
    Scuse me, I was talking about the firmware side, I mean, I found this rep in github
    https://github.com/OpenSimwheel/ArgonServoDriveFirmware
    with the sources for the firmware that handle the FFB, but I can not find the device descriptor.
    Is not yours this repository?
    What I want to make is adapt my device to make windows watch it like a FFB device
  3. bberger
    bberger Member
    306Coins
    Communication to the Argon in my OSW firmware with OSW Commander is done via the proprietary SMv2 serial protocol. There is no HID USB device involved.
    Argon gets an absolute torque setpoint and returns the current encoder position in return.
    The only HID compatible device in the chain is vJoy. There is no Direct Input based Force Feedback involved. OSW commander takes actual calculated torque from the sim via API and translates it into an absolute torque setpoint sent to the Argon. vJoy is only responsible for receiving the returned encoder position and moving the game device axis accordingly.
    You'll be able to find an FFB descriptor in the current version of vJoy (2.3+) though. The code is published on sourceforge under a public domain license.
  4. shrav
    shrav New Member
    texas
    61Coins
    Very nice
  5. cfischer
    Colorado
    2,783Coins
    Is there any reason not to use a smaller(lighter) and perhaps cheaper motor/drive. It seems like a huge jump from less than 100w to 1kw. Im thinking I would rather have something in the 300-500w range. Anybody else ever have this thought?
  6. Pit
    30,499Coins
    IMO in comparison with all the other hardware needed for the OSW the small mige is not too expensive. It meets our condition especially the reactivity, linearity and at least the speed, the MIGE is on a different league and worth the cost. (PS: the Lenze is again on a different league in comparison with the Mige)
  7. RacingMat
    21,062Coins
    Back in 2011, the first DIY Wheels trials were led on RacingFR.com forum. After many trials, Mige has been found with low cogging and affordable price. Since then, the choice has not been beaten.
    Big Mige has bigger inertia ratio which is counter-productive.
  8. Pit
    30,499Coins
    For what I know and for my part the big Mige makes only sense in combination with the IONI Pro, the "small" IONI can only drive the small Mige to full potential (and beyond), for the large Mige and its higher current requirements the IONI Pro is mandatory. IMO the statements done when only the "small" IONI was available are now obsolete because of outdated.
    PS: we should not forget the encoder, the Mige fitted with 5K PPR encoder makes a difference to the original 2.5k one. Because we are talking about "cheap" DD wheels you can be sure that the Mige servos are worth the money, they do the job as you expect and for many years.
  9. Pit
    30,499Coins
    Addendum @RacingMat: if you did not sell your small Mige yet, we could make a personally comparison one day ;)
  10. RacingMat
    21,062Coins
    I did sell it...
    The comparison had been made with software monitoring "Wheel check"
  11. Pit
    30,499Coins
    Wheelcheck from iracing?
  12. RacingMat
    21,062Coins
    sorry WheelTest :confused:
    but by reading specifically the thread, the tools itself is not very reliable... so the controversy is still open!
  13. Pit
    30,499Coins
    agree, same I was building up a hypothesis by provoking the theory at the assetto corsa community that wheelcheck does not typically work with the OSW...
  14. Pit
    30,499Coins
    did a test using a drift steering wheel (350cm diameter, 10cm depth) and got these results:
    Actually we should test without wheel - every wheel is different.
  15. Pit
    30,499Coins
  16. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Hello, can anybody confirm if an ioni based osw works with nascar racing 2003 or Grand prix legends?
  17. bberger
    bberger Member
    306Coins
    NASCAR 2003 - yes.
    Not sure about GPL, but since it's the same codebase I'd say yes too.
  18. bob williams
    IT
    Ermelo, Netherlands
    113Coins
    Thanks bberger! Well if nascar racing works, chance is GPL will also work. There is also a ffb upgrade patch for GPL that filters out all canned affect. More info here http://srmz.net/index.php?showtopic=4226
    I think this patch will do dd wheels good!
    I have purchased a ioni based osw kit from Tomo. So I will find out soon how it is working.
    Most of the osw postings on forums and youtube are from iracing. It would be nice to have a list of all working games with some setup tips.
    Cheers
  19. bberger
    bberger Member
    306Coins
    Basically anything that uses the MMos Firmware for the STM32F4 board should work in theoretically all games a Logitech/Thrustmaster/Fanatec/Bodnar wheel works too. There may be bugs in some legacy games that the big companies might have worked around, but from the historically important titles the wheel should work.
    The only thing that I know is a challenge sometimes are Codemaster games. Or for the fact any game that might have had a documented history of struggling with solutions that are not Logitech based..
  20. bob williams
    IT
    Ermelo, Netherlands
    113Coins
    Well I can confirme both GPL and NR2003 are working good. They behave quit similar. I am definitly not completly familiar with all the settings yet for finetuning.
    I have used a simple gamepad to connect the buttons from the steering wheel. Its located directly behind the wheel.
    So far I`m very impressed with the OSW, it really puts my rig to another level! IMG_5809.JPG IMG_5810.JPG
    • Like Like x 5
