Simple Dash on Arduino+LCD with GameDash
Discussion in 'DIY peripherals' started by TOPMO3, Jun 22, 2015.
  1. TerminalKaos
    TerminalKaos New Member
    Australia
    260Coins
    Hi @TOPMO3
    Tha ks for updating the pics. Was trying to qork out the wiring if the buttons. But this simplifies everything. Thanks again
  2. TerminalKaos
    Australia
    260Coins
    Hi @TOPMO3
    I have downloaded and installed the Plugin (iRacing_Plugin 1.0.5.2). when I load game dash and select the plugin from the menu nothing changes (dash Headings). I have attached screenshot below. I have tried uninstalling, patching, restarting PC. Just can't seem to get this to work. Have you got any ideas?
  3. TOPMO3
    TOPMO3 Active Member
    Russia
    897Coins
    Hi @TerminalKaos !
    Do you get "Game Running" in Game Manager when you start iRacing session?
    If yes can you please check that you enabled Dash Output in Dash setting?
  4. TerminalKaos
    Australia
    260Coins
    Hi @TOPMO3
    Yes I do get game running as well as enabled the dash. I used the default 127.0.0.3 (I think) IP address beneth enable dash, as well as my PC IP address and still nothing.
    All the dash code has been written into game dash also as per your screenshot.
  5. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    @TerminalKaos if you are using one pc for simtools (game engine, game manager and GameDash ) IP should be 127.0.0.1
    and then you have to configure game dash as described in first post. the only thing that probably be different is the COM port. you have to find which port your arduino is connected to.
  6. Gabriel Vuelma Romanzini
    Gabriel Vuelma Romanzini Member
    SolidWorks User
    Nova Prata - Brasil
    558Coins
    Dear, managed to install all and upload the code.
    I'm just using neostrip and i cant manage to get it work!
    GameDASH read the data, but neopixel wont work....
    My interface output : R<Dash2>G<Dash3>S<Dash1>F<Dash6>
    TX Led turn on when i enter game, all ok.
    If i reset the arduino when the car is in idle some leds turn on....
    Wiring is:
    GND to neopix GND...
    Pin 10 direct toneopixDIN
    and 5V to neopix 5V
  7. mariana fino
    mariana fino
    Hi all,can i connect 2 arduinos to simtools at same time 1 for 2 dof and another one to dashboard ?
  8. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    yes you can connect a 2nd arduino but you have to configure it in game dash app not in game engine as you have done for your 2 dof rig
  9. mariana fino
    mariana fino
    Thanks ,time to start a upgrade to my playseat!!!!
  10. TOPMO3
    Russia
    897Coins
    Hi @TerminalKaos ,
    I agreed with @insanegr , you should try 127.0.0.1 address.
    Hi @Gabriel Vuelma Romanzini ,
    hard to say without any diagnostics. At first look, it seems you have a trouble with communication between GameDash and Ard. If you need to reset your arduino, please restart GameDash also. And please double check your GameDash settings - ComPort and BitsPerSec.
    Also for neostrip lights only you need only RPM data - ie R<DashXX>. or if you are using iRacing, then its better to use X<DashXX>.
    And do you check neostrip itself? by flashing some sample code, just to check neostrip itself is working
  11. mys3lf
    mys3lf New Member
    Designer
    118Coins
    @TOPMO3 this only works in iRacing? anyone have tryied other games like: Assetto Corsa or Project cars?
    BTW Great joob... :cheers
  12. TOPMO3
    Russia
    897Coins
    Hi @mys3lf ,
    Currently the sketch support these inputs:
    // S - speed, km/h
    // G - gear
    // R - RPM
    // F - Fuel, % * 10
    // O - Oil, C * 10
    // W - Water, C * 10
    // U - Fuel, L * 10
    // L - Lap
    // X - Telemetry driven RPM LED blink, % of shift point (iRacing ShiftIndicatorPct)
    // E - iRacing Engine Warnings
    Only last two are iRacing only, other are universal. You need to check though what parameters can output a plugin for your game.
    For example AC plugin support
    "DashApp Data:
    Speed [km/h], RPM, gear, shift light, fuel [lt], fuel [%], car model and track name."
    so in AC you can use Speed [km/h], RPM, gear, fuel [lt], fuel [%] and can construct something like S<DashX>R<DashX>G<DashX>U<DashX>F<DashX>
    Replace X DashX with corresponding dash
    PCars unfortunately doesn't support Dash telemetry yet
    "DashApp Data:
    Additional values for instruments are feasible, yet not implemented."
  13. Donavan
    Donavan New Member
    72Coins
    Great Job!
  14. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    @Donavan a 2 word reply this time, but at least it's a current thread congratulations!!
  15. mys3lf
    mys3lf New Member
    Designer
    118Coins
    My Modded lcd+ 2 TM1638 working on Project Cars (PS4 Version)
    I have 3 arduino boards running
    One TM1638 plugged to Arduino Mega
    Other TM1638 plugged to Arduino leonardo
    and Lcd to arduino UNO Rev3
    How that works?!?!?!?!?
    Simple :) . I have 2 virtual machines in the some pc running each one are running the software Gameengine, Gamemanager and Gamedash thats the only way to make the 3 Gamemanager connect to PS4 port 5606
    Thanks to @TOPMO3 for the project
    soon i will post some video
  16. it_pixy
    it_pixy New Member
    macau
    251Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, SimforceGT, Motion platform, 4DOF, 6DOF
    May I ask how a speed from m/s to km/h as the output
    Because the value of GameDash is m/s
  17. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,054Coins
    Arduino, 4DOF
    Basic math. 1 hour = 3600 sec.
    1m/s=3600m/h=3.6km/h
    Simpler: there is a button on tm1638 to handle that
  18. it_pixy
    it_pixy New Member
    macau
    251Coins
    If this conversion unit, the value will be out of precision
    Will there be other way?
  19. mys3lf
    mys3lf New Member
    Designer
    118Coins
  20. TOPMO3
    Russia
    897Coins
    Hi @it_pizy,
    Sorry, maybe I don't understand your problem. If your game output speed in m/s but you want km/h, then you just need to multiply the value to 3.6 , as @vthinsel already stated.
    For example If you have 11m/s, then it will be 39.6 km/h
    If you use integer variable to hold values in a sketch, then you'll get 39km/h
    but if you use for example long variable then you'll get honest 39.6 km/h
    Keep in mind however that operations with floating points is hard for Arduino chip and they are slow because of this.
    Do you really need this .1-.9 km/h? Its really hard to notice this difference in a race.
