Wiggle on right motor in nascar
Discussion in 'DIY Motion Simulator Projects' started by Lorien31, May 5, 2016.
  1. Lorien31
    Lorien31 Member Gold Contributor
    IT System Specialist
    140Coins
    Hi all
    just noticed that my right motor which does not have that much load in iracing nascar, does wiggle sometimes.
    If i lean more to the right, it stops because of the load.
    I do not have this issue on the road courses, so i don't want to change much.
    As far as i know i can not add filters to different profiles right ?
    Which filter would be the right one, is it deadzone ?
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    I would start by isolating which effect it is happening on by trying them out one at a time. for example first surge then sway and so on. then try adding smoothing maybe ten at a time then testing. or go to tunning center and slightly increase the values of the effect that it is happening on. If it is sway then you are correct with deadzone. I run a value near 2 in I racing to reduce twitch in the corner and to dumb down the side to side snap a little as it feels strange on ovals coming out of the turns without it and smoothing together.
