SCN5 / SCN6 Hardware Thread
Discussion in 'SimTools compatible interfaces' started by egoexpress, Sep 29, 2008.
Thread Status:
Not open for further replies.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    SCN5 Adapters and Cables
    I've re-read this entire thread to make sure I'm not missing anything, and it seems that so far, the only adapter that anyone has posted that is for certain functioning with the X-Sim software is the expensive one from Marai. At one point there was a post suggesting that if someone wanted to buy a commercial adapter, that they post it here to find out if it is compatible. Then, when I did that, it was suggested that I wait for the custom made cables / adapter sets that egoexpress is making because the testing procedure for commercial adapters has not yet been defined.
    I'm about a week away from being able to hook everything up and begin testing, but I don't have an adapter / cable solution in place. I have found 5 different adapters that are reasonably priced, but it seems that if I bought one of them it will be trial and error and possibly wasted money? Also, I would still need to make cables. I thought I understood the cabling, but then discovered that Mirai uses two different color coding schemes when I re-read this thread.
    **Egoexpress - How are your adapters / cable sets coming along, and may I buy two of the USB<-->RS485 from you if they are about ready?
    If not, what can I do to help the process of defining a test procedure for commercial adapters, and documenting a wiring diagram?
    Regards,
    Bernard (bvillersjr)
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Re: SCN5 Hardware Thread
    That's not right. The comport converters suggested by Sirnoname do work and are fast enough as well. I've made 3 of them yet.
    As well I have made some adapter cables recently.
    So everybody who has his frame finished with SCN5 actuators, can ask me for cables now.
    Btw, everyone who has a COM-Port should go for the serial-converter. It is faster than USB, and you save an USB port for other devices. Once you've connected it, it does not make any difference anyway :brows:
    But sure, you can wait as well for Thanos' USB version, or go for a commercial one.
    Regards
    Christian
  3. bvillersjr
    Ohio, USA
    438Coins
    Great news! I didn't know that you were ready, but my frame is built, and I sent it off to be powder coated. I should have it back within a week, so I'm anxious to come up with a cabling solution. Could I please purchase two of your. I will just go with the Com Ports and cables if you think they will be faster and are already available.
    Regards,
  4. egoexpress
    421Coins
    Sure, you've got a pm.
    Regards
    Christian
  5. bvillersjr
    Ohio, USA
    438Coins
    Serial Card Options for Use with SCN5 actuators
    Hello all,
    My motherboard does not have serial ports, and I have decided to go with a RS232<-->RS485 adapter for connecting the SCN5 actuators to my system. Obviously, I need to purchase a serial card. I haven't had any need to do anything with serial devices since I last ran a BBS in 1994.....lol ;-)
    I though that choosing a PCI serial card would be easy, but it turns out that there are more options than I assumed, and advertised maximum transfer rates seem to vary quite a bit.
    Here are the specifications of a card that I am considering, which you can see here:
    Bus Type: PCI 5V / PCI-X 3.3V
    Maximum Data Transfer Rate: 460Kbps (Note: Crystal will need to be adjusted to achieve 460Kbps)
    OS Support: Windows NT4/98SE/ME/2000/XP/Vista Linux
    Chipset: Oxford OX16PCI1952
    128-byte deep FIFO per transmitter and receiver
    Automated in-band software flow control using programmable Xon/Xoff in both directions
    Automated out-of-band hardware flow control using RTS / CTS and/or DSR / DTR
    Maximum data transfer rate of 460 Kbps
    PCI 2.2 and PCI Power Management 1.0 compliant
    Two high performance 16C950 UART channels
    UART’s fully compatible with 16C550 type devices
    So here are my questions:
    1.)What is the optimal speed for use with SCN 5 actuators and the X-Sim software? (I've seen 460kbps, 980kbps...this one says 480kbps but requires a crystal adjustment)
    2.)Is there a particular chipset that I should be looking for? Moschip seems to be popular Oxford is on this StarTech product.
    Any input is greatly appreciated!
  6. egoexpress
    421Coins
    *last two posts joined to SCN5 hardware thread*
    I thought USB was slower than RS232.
    Afaik USB speed is ~10ms, while RS232 speed is up to 2ms.
    If using a USB->RS232 converter, the max speed would be dependant from the slower USB I guess!?
    Regards
    Christian
  7. tronicgr
    tronicgr
  8. egoexpress
    421Coins
    I've found some info on USB speeds on http://www.usb.org/developers/usbfaq/#sig1 that claims:
    Ok, the 10ms I had in mind, is the USB1 speed obviously :wacko:
    Regards
    Christian
  9. njracer
    njracer Member
    2Coins
    hey guys, frex has put the scn5 actuators on their site for sale, he has them individually labeled for the right and left actuator and is charging 348.95 usd for each one. that seems like a good price but idk if the wiring is the same as what we'll need. what do you guys think http://www.frex.com/gpshop/catalog/defa ... 68ecca871e
  10. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
  11. charlypro
    charlypro New Member
    California
    0Coins
    HI Adgun can you post the link where you find the SCN5-010-100 to that price thank yuo.
    Charly
  12. egoexpress
    421Coins
    Unfortunatly they just sell to asian corporate customers.
    The Frex SCN5 have modified power-connectors, and I guess they lose warranty because of that.
    So unless you dont have a Frex setup, you shouldnt buy the replacement actuators from Frex imho.
    Regards
    Christian
  13. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
    Hi Charlypro
    To find them: google with dyadic scn5,on page 4 you find tool-tobo ,and translate
    I tryed to post it yesterday but it,s to big.
    It's fore corporate customers i see now.
    This way i am not able to create a bridge.
    Regards Ad
  14. bvillersjr
    Ohio, USA
    438Coins
    I have a corporation that I should be able to purchase them through. I'm not sure if thats any kind of special deal though. I bought the 150mm's for $475 each. I believe that the 100mm were quite a bit cheaper.
  15. dre99gsx
    dre99gsx New Member
    0Coins
    Download the SCN5 manual from MIRAI. Page 56 details the pinout from the motor. Build your cable form there, or just snip the connector and use your own. MIRAI did state motor end-cable colors are not always consistent. Use the pinout for the correct wiring.
    I am interested in using the plug in for my SCN5s.
  16. egoexpress
    421Coins
    I've added the killswitch into the scheme.
    Regards
    Christian
  17. dre99gsx
    dre99gsx New Member
    0Coins
    Statement ;)
  18. dre99gsx
    dre99gsx New Member
    0Coins
    Any update? I am in the middle of building my setup. Being that I am in NJ (USA), I would like to get the cables+rs485 adapter ordered if they are completed now rather than later. I can then test them. Please PM me with details if you must. Otherwise, can you recommend a commercial USB-rs485 or rs232-rs485 unit from the web (google)? I can also make my own cables, but wouldn't mind buying these from you. Thanks.
  19. Mr Burns
    Mr Burns New Member
    0Coins
    You can get a serial pci card like this:
    http://www.tigerdirect.com/applications ... BLET03SHIP
    and no 232 to usb cable needed then.
    And 2 of these for 485-232 http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0298949916 . I don't know if it works, but I'll try it, only $13 for 2.
    Cables, get some of those small connectors from Radio Shack and some wires (they have them in with matching colors even) and you can make them yourself to extend the scn cables so you don't have to cut the original ones.
  20. egoexpress
    421Coins
    Good.
    Every adapter is usable, as long at it outputs RS485.
    USB->RS485 or RS232->485
    The SCN5 plugin supports them all.
    Regards
    Christian
Thread Status:
