2DOF compact race / flight with Oculus Rift
Discussion in 'DIY Motion Simulator Projects' started by reko19, Jan 9, 2015.
  1. reko19
    reko19 Active Member
    electrical engineer
    usa
    38Coins
    No, they work under fanatec game controllers screen outside of the game, but not once you are in the game
  2. Nick Moxley
    That leaves me very confused, Has this always been the case " or how did you originally have stuff hooked up ? What Driver's have you installed when you first got the gear ?
    Delete your AC "controllers" folder under my documents, Run an Integrity check and try again.
  3. reko19
    electrical engineer
    usa
    38Coins
    Nick, was able to get everything to work. All I had to do is to assign proper channels to the pedals inside AC. For some reason default assignment was working while the pedals are connected through the base but not when connected to the PC via USB. Thank you for your help.
  4. Nick Moxley
    Awesome, now go enjoy those extra Steps in linearity on the Throttle/Clutch.
  5. reko19
    electrical engineer
    usa
    38Coins
  6. Nick Moxley
    I have a feeling thats because the particular user that is associated to is no longer a part of the forum. :confused:
  7. reko19
    electrical engineer
    usa
    38Coins
    is there any way to download this guide, if not i'll figure something out
    153,890Coins
    +11,154 / 57 / -2
    More detailed information is available.
    See @eaorobbie's guide for basic JRK configuration: http://www.xsimulator.net/community/faq/jrk-setup-guide-eaorobbie.14/
    How to tune your JRK PID: http://www.xsimulator.net/community/faq/a-laymans-analogy-guide-to-pids-pid-tuning.219/
    And how to refine a motion profile: http://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    @Pit added some Arduino information to the original guide, so if you want you can still go through it, just disregard the Arduino specific information: http://www.xsimulator.net/community/faq/guide-to-set-up-simtools-arduino-and-write-profiles.47/
  9. Pit
    30,510Coins
    this?
  10. reko19
    electrical engineer
    usa
    38Coins
    thanks everyone, enough info to have my head spinning :)
    153,890Coins
    +11,154 / 57 / -2
    It seems daunting at first but take it one step at a time, and ask if you get stuck or need clarification.
  12. Nick Moxley
    I asked a million questions to @eaorobbie ....im sure he will testify to that one...lol
    also physically Talking about thing's help too....reading blocks of text doesn't always click with some guys.
  13. reko19
    electrical engineer
    usa
    38Coins
    First off, emergency stop is a very good feature to have :)
    Now that I got this out of the way, getting stuck at the very last step of setting JRK guide. After I press Detect Motor Direction I get to the prompt "center the output, then click OK". I click OK and nothing happens at all, my only option is to cancel. Any ideas?
  14. Nick Moxley
    that's fine, its just detecting the direction's...with a small bump of the motor which sometimes doesn't even happen. No worries continue on.
  15. reko19
    electrical engineer
    usa
    38Coins
    Was able to sort it out with Nick's help, just needed to manually adjust pots so that they are within the range and line up with the motors (target lines up with feedback)
  16. reko19
    electrical engineer
    usa
    38Coins
    Slowly moving along. Question on simtools. What are the numbers under game engine / inteface settings / startup and shutdown output. Some people have <221><63> and <255>, some <223><63> . Also, the axis assignment is obviously different for each game. So if I chose AC from the games pull down list, create a profile, and save it that is the profile that will be used when I start AC? I don't have to go to simtools and chose it before I start AC?
    thank you guys
  17. Nick Moxley
    No Simtools will automatically load up the proper setting's when you click "Race" in the game menu....... Assetto doesn't grab a hold of the Rig until you jump on track for the first time, then If you Copy your Start up cmd to your Shut down Command, you will get the rig holding your Default (0 position) in between games or track/car selection.
  18. reko19
    electrical engineer
    usa
    38Coins
    NIck, so what exactly <221><63> and <255> stands for, is there an explanation?
  19. Nick Moxley
    No idea and i cant say ive ever seen an explanation. :cheers
    153,890Coins
    +11,154 / 57 / -2
