Project Cars UDP Alternate Plugin
Discussion in 'SimTools Plugins' started by vthinsel, Feb 16, 2016.
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
  2. jefesant
    jefesant Member
    Mechanic
    China
    16Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    I can path Projectcars on PC is with the last 9.0?
    Because I not get use others patch and put to work
    So I'm new to path stafs :(
    I get path mi first game is EURO TRUCK 2 but I want see my project car running,
    All my games is from Steam but I dont now if the folder that I'm tryng path is right.
    C\Program Files\Steam\?
    thank' in advance
  3. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    It works fine with v9. Create the file where you want, and point the patch to this file.
    Do not forget to launch notepad.exe to activate the plugin
  4. mys3lf
    mys3lf New Member
    Designer
    118Coins
    Do you have some tutorial? And how do you made to put the tm1638 to work?
  5. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    It is a regular plugin, so the usual process applies.
    GameDash is populated with correct data. It is then up to you to configure gamedash accordingly to your arduino which drives the TM1638.
  6. Jamburglar
    Jamburglar Member Gold Contributor
    Controls Engineer / Software Engineer
    Michigan
    186Coins
    Does this work with the latest Version of Project Cars? V10.2?
  7. mys3lf
    mys3lf New Member
    Designer
    118Coins
    Works great with all version since v7
  8. Jamburglar
    Michigan
    186Coins
    Thanks. Getting things set up. This is good to hear. I was seeing other games needed to be updated a bunch and I was worried this was the same. New to scene.
  9. mys3lf
    mys3lf New Member
    Designer
    118Coins
    If you have the V10 you are good to go...
  10. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    This is one good thing about UDP. More stable than shared memory, unless wanted changes occur. No bad surprises and probably easier updates as well.
    V10 ok on PS4
    Cheers
  11. BlazinH
    16,691Coins
    To elaborate, since UDP is a method provided by game developers for the purpose of receiving telemetry, etc., it should not “break” with updates to the programs code unless an update is made to the UDP system itself. Therefore, if a method for telemetry output has been provided by the developer, it’s usually best to use that method instead of using memory hooks.
    Therefore, this plugin should be considered a replacement and not an alternative.
    I assume at the time the Simtools 1.0 plugin was created, that UDP in Project Cars had not been implemented yet. Therefore, I expect the Simtools 2.0 plugin will now use UDP also.
    • Informative Informative x 3
  12. NoreiT
    NoreiT New Member
    Czech republic
    219Coins
    Hi, I have a problem with UDP plugin for simtools. With standart plugin Im able to got good movements of my 2DOF. Problem is with altplugin UDP, I got a movement. But even in simtools virtual tab movement is just too small (all axis moves just like 1mm). Can you help me with that? Thanks
  13. mys3lf
    mys3lf New Member
    Designer
    118Coins
    Did you capture Min/Max values in simtools - Tuning Center? I think you must to capture that values and save it...
    153,914Coins
    +11,154 / 57 / -2
    Please post pictures of all your settings.
    Here are the steps to refining a motion profile: http://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  15. mariana fino
    mariana fino
    It had the same problem in my game iracing and i just capture the min/max values ,problem solved!
  16. noorbeast
    153,914Coins
    +11,154 / 57 / -2
    You need to spend some time doing some research before posting basic questions, start with the official documentation: http://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    You will find even more details in the relevant FAQ section: http://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    The community expects that you be pro-active about using existing resources: http://www.xsimulator.net/community/faq/community-etiquette.82/
  17. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    Am I right in thinking i can use this for motion on xbox one?
  18. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Yes, you are right :)
    That's the beauty of UDP: same implementation across various platforms. I haven't tested it on XBoxOne as I don't have it, but I'm quite confident in the fact it will work. It works for sure on PC and PS4 :p
  19. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    I can't seem to find the info of what to do...
    SeatTime replied to my dedicated thread for this question:
    http://www.xsimulator.net/community/threads/pcars-xboxone-sim-tools-motion-howto-help-im-lost.8627/
    "If I remember this properly you need a scrip to also enable SimTools as it cannot tell when the game is active like it would if the game was on the same PC. Recommend you search for this in the relevant thread."
    Have you done it on Ps4? I guess it will be the same.
    Is this the relevant thread? or would I get more help asking on the UDP thread? http://forum.projectcarsgame.com/showthread.php?40113-COMPLETE-Companion-app-UDP-streaming
  20. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    @SBDESIGN i am not using this plugin so can't say for sure what to do but there is a installation guide
    the rest is here http://www.xsimulator.net/community/marketplace/project-cars-udp-alternate-plugin.159/
